SOURCE: Feed dogs not feeding material
Make sure that you did not disengage the feed dogs by accident. You should have some type of button that allows you to control the feed dogs.
SOURCE: the feed dogs on my elna are not moving the fabric
it could just be knocked out of gear,,, or the drive to the drive dogs has sheared off??? if thats the case its for a repair man to fix it
the drive gears are inside the machine!
SOURCE: The feed dogs will not move the material
check the feeddogs & see if there in the up position, if there not move the lever or knob to the up position
if the lever is up then there is something wrong with the feeddogs & it needs to be serviced
SOURCE: feed dog not moving
if the feed dogs are not working correctly, then the machine needs to be serviced
Testimonial: "thank you that's what i thought but where i live is really hard to find one i would have to drive for more than an hr away =("
SOURCE: The Feeder Dogs are not moving forward or backwards on my sewing machine.
Are the Feed Dogs dropped? Check your manual for the location of the switch. .... otherwise your mechanism has been compromised. Take it in for repair.
