Question about Nintendo Wii Remote Controller
My wii remote cursor works fine until i get to the main menu of the new game i bought. the cursor doesnt show up. i tried hitting the remote and "bull whipping" it but its still not working.
  • 98 Answers
Make sure your wii controller is properly configured, go to your wii system settings and make sure all the settings are correct and your controller is properly configured. Your proximity to tho sensor bar also plays a role in this, dont get too close :)
Posted on Aug 03, 2009
Wii Remotes not showing up on TV
you can try two things if you havent already go to the options and switch the wii to HDTV from the options menu (if you have a HDTV) or if you have a glare anywhere that hits the tv or is hitting your remote block sunlight from that area if these two do not work you sensor bar is broke or your wii remote sensor is broke.
Dec 23, 2009 | Nintendo Wii Console
My wii cursor died?!
Try changing the batteries in the controller.
Jul 28, 2009 | Nintendo Wii Console
Wii cursor not working in Mii and home menus
you might be using the second remote instead of the first
Apr 05, 2009 | Nintendo Wii Console
Wii remote cursor not working in Wii Menu
I find it very irratating to navigate the wii menu as well. It seems our problem is the remote is very very sensitive to the sensor bar. You have to swing the remote around a bit to find the 'hand' you use to click on where you want to go. also, I find that I first have to press A when the menu comes, then almost have the remote 3 inches from the sensor bar. I have also tried putting the sensor bar in different loactions. Like, if we are playing standing up, we put the bar atop of the tv, otherwise if it is a game we can play while sitting, we put the sensor bar under the tv, on the stand (this is a 20") Try moving yours around and find out what works best for you. But it is frustrating as I too find that the remote is too dag 'on sensitive!! Even though I know it's fussy, we still have the problem daily, doen't get any easier! I hope this suggestion helps.
Sep 02, 2008 | Nintendo Wii Console
Nintendo Controller Will Only Work on Menu with Classic Controller
well iv had this problem it could be the remote you might have to buy a new thts what happened with my brand new remote for it or it could be that it has crapy batteries
Mar 01, 2008 | Nintendo Wii Console
Console itself....
You should try to reset the game data by hitting home and rest while playing your game, if that doesnt work go to Wii main menu, THEN hit reset button on the Wii system. And that should do mthe trick it worked for my family!
Feb 27, 2008 | Nintendo Wii Console
Cursor does not appear
exchange it
    Cursor not appearing
    Please note that our experience shows that this troubleshooting is best performed using only one (1) Wii Remote at a time.
  • Some games do not use the cursor feature of the Wii Remote; Make sure the game you are attempting to play uses the cursor by reading the game's instruction manual. You can also exit out of the game to return to the Channel Menu and use the Wii Remote to see the cursor. If the cursor still does not appear, continue with the steps below.
  • Trying to use multiple Wii Remotes in the Mii Channel or Photo Channel? These Channels only allow the Wii Remote designated as "Player 1" to function.
  • Verify that the Wii Remote's pointer lens is free of obstructions and contamination (stickers, heavy smudges, etc.). The pointer lens is the tinted rectangle at the end of the Wii Remote.
  • Check the battery power level by turning off the Wii console, then opening the battery cover of the Wii Remote. Press and release the red "SYNC" button to check battery strength. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength. Our experience has shown that as your battery strength decreases to one (1) or less lights flashing, the cursor may not appear. For troubleshooting, if possible, try using fresh batteries so that all four lights illuminate. For guidelines on using batteries, please click here. If after inserting brand new batteries, you are still seeing less than all four LEDs flash, then your Wii Remote will need to be repaired. Please click here for repair information.
  • Is the Wii Remote properly synced?
    Press the POWER button on the Wii Remote to see if the Wii console powers on.
    • If it does, the Wii Remote is synced with the system. Please skip to the next section.
    • If the power doesn't come on, power on the system manually and try syncing the Wii Remote.
      • If the Wii Remote will not sync, there is likely a problem with the Wii Remote. Please click here for repair information.
      • If the Wii Remote will sync and the cursor still does not appear, try another Wii Remote if possible.
        • If at least one Wii Remote is working, there is likely a problem with the first Wii Remote and it will need to be repaired. Please click here for repair information.
        • If you have only one Wii Remote, or none that are working, please continue troubleshooting.
  • Make sure that the Wii Remote is being used between 3' and 10' directly in front of the TV and that there are no bright light sources affecting the Wii Remote's operation (review Game Play Guidelines for more information), and that the Sensor Bar is placed properly (see Sensor Bar setup).
  • Check the cord on the Sensor Bar for any frayed wires or kinks, and verify that the Sensor Bar is free of obstructions.
  • Check the button functionality, and that the Sensor Bar is operating correctly, by accessing the Wii Main Menu. Use the "+" and "-" buttons to scroll side-to-side through the Wii Channel screens.
    • If you are able to scroll with the "+" and "-" buttons, but the cursor is not appearing, then there is likely a problem with the Sensor Bar. Please click here for additional Sensor Bar information.
    • If there is no response, there is likely a problem with the Wii Remote. Please click here for repair information.
Dec 11, 2007 | Nintendo Wii Console
Discs wont register on wii system, remote wont work either
You need to sync the remote with the console.
Remove the battery cover from the remote and press the red
button until the blue lights start to blink. At the same time,
press the the red button to the front of the console.  You
can access this button by removing a small cover on the front
of the console. This will reset the machine and you should
start to see th cursor in the tv screen. Repeat this if necessary
and you should be on your way. Good luck
Sep 25, 2007 | Nintendo Wii Console
Nintendo Wii Remote Controller Logo
336 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
