Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Riding lawn mower keeps flooding
When i try to start my rider gas will spit out of exhaust then flood. can get it to un for 30 seconds then it floods out.spark plug gets gas on it.wait for 25minutes and keeps repeating this.runs then stops.sounds like im getting to much gas
    Sniper:
  • 95 Answers
It sounds like the inlet needle seat is not closing all the way,allowing fuel to overfill the carburetor.The inlet needle seat may have dirt in it.You will have to remove the carburetor bowl and check for dirt or debris in bowl,if so remove the float assembly and check for a peice of dirt between the inlet needle and seat.If there is none you may have to replace the carburetor or rebuild it with a carburetor kit.You should also chang the engine oil because the overfilled carburetor drains to the crankcase,filling it with fuel,check the oil level and see if it is high,that would indicate fuel is in the oil.Hope this helps
Posted on Jul 30, 2009
    President:
  • 704 Answers
It would appear that the fuel float might have a hole in it and is causing too much gas to flow into the fuel bowl at the underside of the carb. You can remove and check for a bad float or check to see if the float is sticking and isn't allowing the needle valve to shut off the fuel supply when the bowl is at the right level. You can check all of this pretty easily, just be sure to shut off the fuel tank and have some rags handy to catch the fuel in the bowl when you remove it. You can use some carb/injector cleaner to remove any residue or deposits (shellac-ing) that may have occurred that is causing this problem
Either that or the fuel adjustment is set too high on the carb, which is letting more gas than needed into the bowl and thus the carb allowing for the excess to blow out the exhaust. Readjust the flow by turning the knob all the way in in the center of fuel bowl and slowing turn it out until the engine runs smoothly.
Posted on Jul 28, 2009
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 34 Answers
Could be one of two things your inlet valve is stuck open due too bad gas from being left untreated during the off season. what happens gas being left in during off season gums up needle valve and lets gas continue to pour into the carburetor..Easy solution remove carburetor its a simple job and remove float and valve and clean with carb cleaner.Or second thing would be float has hole in it and causes it to sink when the gas fills the carb causing the valve to stay open...
Posted on Aug 09, 2014
Hard stating flooding
Search Results
    Rider mower carburetor flooding - help ! - YouTube
    ? 1:30
    https://www.youtube.com/watch?v=ZYqtKvLXYtY
    Sep 29, 2010 - Uploaded by Joyce Boncal
    It won't start. ... Rider mower carburetor flooding - help ! .... ( HOW TO ADJUST VALVES) FIX HARD TO START Lawn Tractorwith OHV Briggs ...
    How to stop a Briggs crankcase from flooding with gas Order ...
    ? 11:34
    https://www.youtube.com/watch?v=VhEiLMtPR5M
    Aug 5, 2013 - Uploaded by doublewide6
    If your tractor keeps leaking gas into the crankcase see how you can fix the problem by ... The hard starting is caused by fuel filling the cylinder.
    Basic Troubleshooting - Lawn & Garden Tractors - Cub Cadet
    cubcadet.custhelp.com/.../basic-troubleshooting---lawn-%26-garden-tract...
    Sep 13, 2002 - Engine fails to start, Engine flooded, Crank engine with throttle in FAST... Engine runs erratic or stalls, Tractor running with CHOKE activated ...
Jan 25, 2016 | Garden
638 rl gas spitting out exhaust
It's flooding.. Either the Float in the carburetor has a hole and sinks or the Needle valve is not working properly and not stopping theflow of gas to the carburetor bowl.
Sep 07, 2013 | Yard Machines Garden
My riding lawn mower is splilling out gas when i start it.
If it is coming out of the exhaust muffler then you need to clean the carb, it is most likely float needle valve sticking open and causing flooding.
Aug 09, 2011 | Garden
Snapper rider gas flooded engine wont start?
Why did it flood? That problem may need to be delt with. But for now remove plug, crank over to clear cylnder, Replace or clean the plug making sure it is clean and dry. Try to start.
Oct 06, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Gas shooting out top of carboratore on a 20 h.p turbo twin cylinder craftsman lawn tractor , idles fine but past idle starts spitting gas
This tells you that the carb is flooding out and needs to be rebuilt. Most likely the float in the carb has a leak and is sinking in the bowl.
May 05, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Engine seems to be flooding out. I have spark but if you take the plug out it is soaked with gas.
if it's flooding out try starting it without using the choke. if it still floods then the float in the carb is stuck open and you will need to remove and rebuild the carb. they sell complete carb kits for all makes of engines..good luck
Mar 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 19.5 - keeps flooding getting too much gas
I think that you have a sticking float in the carb. You probably will have to rebuild it. hope this helps
Sep 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Murray riding mower 12.5 hp briggs & stratton spitting oil & gas out of carb & muffler when trying to start
Drain oil... it is full of gasoline due to a bad float pin and rubber gromet in your carb. When your float pin and gromet fail, gas just keeps flowing into your carburetor, eventually flooding your motor with gas and oil mix.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
4,456 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
