Question about RCA Scenium D40W20 40" Rear Projection HDTV
How to enter service mode to resize grid.
When the TV is on the picture is larger then the screen. Had a tech over several years ago and he went into a setup mode where a grid appeared and he was able to change the size of the picture. Can anyone tell me how to get the TV into that grid mode so I can resize the picture?
  • Anonymous Mar 11, 2008
    picture larger than the screen
  • toby100985 Jan 10, 2009
    would it be possible for someone with a d40w20 to post the geometry settings for 1080i mode ,i messed mine up
    Champion:
  • 206 Answers
Many a good set have been destroyed by stumbling around in the service menu. One wrong thing and boom no more Tv. But we'll try to help you here, turn the set off. hold both the volume down and chanel down on the front of the set. hold them both in till the set turns on Then from this menu go to geomatry and you should be able to adjust from there , and for Gods sakes write down the values before you change them so you have a refrance point should things go terribly wrong
Posted on Feb 14, 2008
Reset factory settings
To reset the TV to its factory settings, you have to enter its service mode option. Reset option can be selected in this mode. If you wish to get more details about how to enter, adjust and exit the service mode, check this site. http://electronicshelponline.blogspot.com/ Pull up previous posts or type in the brand name and model number to of your set, to its search box, and press 'Enter'.
Aug 22, 2013 | Olevia LT32HVE 32 in. LCD Television
AOC L24H898 - Several problems. 1)Only 3 Display modes - AV, HDMI, PC. 2)In PC mode screen is white with barely-discernable Desktop. 3) Menu button does nothing (pressing Channel + and - together lo
This sounds like a common problem on these TVs (it's happened to both of my AOC TVs a couple times). Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Nov 17, 2011 | AOC L24H898 24 in. LCD TV
I have a HL-P6163W, hooked to dish network hd
Fire the TV Tech! Your problem is the adjustment to the color wheel timing. To correct this: With TV OFF -> on remote, press MUTE, 1, 8, 2, POWER. The TV will come up in service mode: ( Left / Right arrow keys for item selection, Up / Down to change values, Menu to return to previous menu, Power to exit Service Mode)
Enter the submenu of item 1. DDP1011. Now, adjust item 4. INDEX DELAY to correct the "clay facing" problem you are having . Default value is 47.
You should have a "problem" image paused to check you work if possible. I hope this was of some assistance, best wishes.
Apr 12, 2010 | Samsung HL-P6163W 61" TV
There is a wave/bow in the bottom and top of the picture on the screen of my Toshiba 70HX50. When I am in the grid screen in the service mode, it looks like the center is 'bowed' out. How do I adjust this...
Slight error in the alignment of a projection TV is pretty much normal. If the problem cannot be seen on a normal TV picture, I would not spend the money.
However, if the problem is severe and causes colour double images, it is convergence and will need parts replaced - about $200-$600 depending on service call, parts, labour, etc.
Minor adjustment takes a skilled technician. attempting it yourself will likely cause the set to stop functioning. (Digital adjustment is not forgiving)
Mar 30, 2010 | Toshiba 43H70 43" Rear Projection...
Picture size
Hello! You need to put your tv into service mode and adjust the horizontal and vertical size. You can find info on how to enter the service mode for some brands at epanorama.net. Good luck.
barneyluc
Oct 10, 2008 | Televison & Video
Picture problems with the Sanyo Vizon 42" Plasma TV
can you contact Sanyo tech department and ask them, it maybe as simple as a menu button got switched.
Oct 03, 2017 | Televison & Video
Sound no pic
Convergence ICs are STK392-110 you will need two of them they are available at the link I am posting and they give free instalation instructions with pics and free tech support so you can do the repair yourself.Heres the link.
http://servicemanuals.vstore.ca/
May 01, 2008 | Mitsubishi VS-50501 50" Rear Projection...
PT5499HD Covergence Akai
Yes, you have a size problem you have horizontal and vertical size. Either its' in the service mode or somewhere on the set, with this set it's probably in menu. Must be set too high. I will look for menu codes! Is this an Akai or Panasonic set?
Oct 04, 2007 | Panasonic PT-47WX49 47" Rear Projection...
RCA P52921 Color/Alignment Grid
What your looking for is called the service menu. This is not an adjustment you should attempt unless you first read the service manual as the wrong button pressed while in this menu will cause permanent damage and an expensive repair. My best suggestion is for you to call in an authorized RCA repair person to do this for you, or purchase a service manual before you attempt this alignment procedure. Good Luck
Sep 28, 2007 | Televison & Video
Image from HD receiver larger than TV screen
Most satellite boxes have a zoom,stretch mode that might be incorrectly set. i would check that first before dooming an issue with the TV.
Apr 22, 2007 | Samsung HCL4715W 47" Rear Projection...
RCA Scenium D40W20 40" Rear Projection HDTV Logo
228 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
