Question about Ricoh Office Equipment & Supplies
Scan to folder using ftp not working - Ricoh Office Equipment & Supplies
  • bradfisher Jul 28, 2009
    Ricoh Aficio 2051
Hello
What is the model of the Ricoh fax machine?
Posted on Jul 28, 2009
How do I Scan from a C2020?
In regards to scanning from a Canon ImageRunner to a Mac, this used to be done via SMB. But then Apple modernized the SMB protocol in Lion & Mountain Lion & Mavericks, and Canon decided to remain in the dark ages with their old-fashioned SMB protocol support. So therefore, Canon ImageRunners are now incompatible with Lion (OS X 10.7) & Mountain Lion (OS X 10.8) & Mavericks (OS X 10.9) & Yosemite (OS X 10.10) & El Capitan (OS X 10.11) for scanning via SMB.
The solution is that we now have to use the FTP protocol for scanning, when scanning from a Canon ImageRunner to a Mac running Lion (OS X 10.7) or Mountain Lion (OS X 10.8) or Mavericks (OS X 10.9) or Yosemite (OS X 10.10) or El Capitan (OS X 10.11).
To use the FTP protocol, you first need to enable it on your Mac by going into the Terminal and typing this command:
sudo -s launchctl load -w /System/Library/LaunchDaemons/ftp.plist
After enabling FTP via the Terminal, go into the Sharing system preference. Enable File Sharing in the left margin. Add the shared folder where you want the scans to end up. We usually like to create a folder on the Desktop entitled "Canon Scans", so you can just drag this folder into the list of folders. Click on the "Options" button to make sure that AFP is enabled, but you do NOT need to enable SMB.
Now you can go into the Network system preference where you will need to manually assign a static IP address for your machine. The Canon ImageRunner will need this static IP address so that it can find your Mac.
Once you've done all of the above, you can now create a new "one touch entry" on the Canon ImageRunner printer to scan to the shared folder on the Mac.
To do this, click on the physical button on the copier that says "Additional Functions", then press "Address Book Settings".
Then, on the Canon ImageRunner screen, press "One Touch Buttons".
On the next screen, press an existing name to edit it, or press a numbered button to edit a new name. (You can scroll through the pages with the arrows on the right.) You must press the "Register/Edit" button to add or edit that button.
If you're adding a new button, then on the next screen, you'll have to press "File".
Then you'll be taken to the next screen. The information to type in is the following:
Name: Give the button a name
One-touch Button Name: Give the button a short name that will fit on a button.
Protocol: FTP
Host Name: The static IP address that you assigned to the Mac. Do NOT use any special characters or slashes... just enter the IP address.
Folder Path: shared folder name. The trick to this is that you have to give the path from the starting point of the home folder. So if the shared folder is named "Canon Scans" and it sits on the desktop, then type in this file path: "Desktop/Canon Scans" (without the quotes).
User: the full account name of the account which owns the shared folder.
Password: the password for the account which owns the shared folder.
And that's it! You are now all set to scan from your Canon ImageRunner to your Mac!
I hope you enjoyed this article. If so, please donate a small amount via Paypal so that I can continue to post blog articles in the future.
Jul 15, 2014 | Canon for IMAGERUNNER C2020 C2050 C2058...
Everything depends on how you have it set up through the web interface of the Xerox. If you're using the SMB protocol for network scanning be sure that the folder you are trying to scan to is shared and that the user that you have set the xerox machine to use has LOCAL read and write access to that folder. Occasionally i've seen a firewall issue, but it's rare. All of this assuming that the OS on the PC your scanning to is running XP,Vista, or Server 2003. If you're running Windows 7 or Server 08, forget about it and switch to a FTP protocol and install Filezilla or add IIS through the add windows components and set up an FTP site. With either SMB or FTP, be certain that the username has read/write/delete access to the folder you are trying to write to (domain username will not do with this model). I hope this helps.
Nov 17, 2011 | Xerox WorkCentre Pro 123 Copier
Scan won't send the files to the network folder
1 - If connecting via the IP adress, please check that the IP address for the destination's folder hasn't changed (if it is an automatic ip address, i'll recomment placing a fixed one,
2 - Check the folder's permissions, you can try to allow anyone for that folder, write and execute for all users.
3 - If you transfer files via the FTP protocol, then you should enable file sharing with the ftp service active (port 21):
Thias is what i have found for windows xp:
"XP includes a built-in FTP service component that lets FTP clients connect to the machine and read or write files; however, this service doesn't install by default. To install the FTP service, perform the following steps:
- Start the Control Panel Add/Remove Programs applet (go to Start, Control Panel, then click Add/Remove Programs).
- Select Add/Remove Windows Components.
- Select Internet Information Services (IIS), then click Details.
- Select the File Transfer Protocol (FTP) Service check box, then click OK.
- Click OK to close all dialog boxes."
hope these things help
Dec 19, 2010 | Toshiba e-STUDIO 4511 Printer
I my pc there is a virus and because of that i am not able to install my antivirus
Try online scan from Trend Micro,it will help you to remove virus
http://housecall.trendmicro.com/
Also, try root kit buster. http://www.trendmicro.com/ftp/products/rootkitbuster/RootkitBuster_2.80.1077.zip
Clean up all your temp files
Go to Start->run - > type temp and hit enter
it will open up a folder, delete all files in temp folder
Again, Go to Start->run - > type %temp% and hit enter
After scanning and deleting temp files, restart the system once and try installing again
May 18, 2010 | Panda Antivirus Pro 2009 - 3 User for PC
Can't download iTunes, IE 8, HP Printer...Fatal Error MSI Scan is the usual statement, although I've gotten numbered failures too. But Fatal Error is the main one.
Hey
The SCAN.MSI that comes up about your HP printer, that is located on the CD in a special folder.
It would be best for you to completely uninstall all HP programs from the computer related to the printer.
http://www.revouninstaller.com/revo_uninstaller_free_download.html
unplug the printer first
use the free(ware) version. Download the program, start it, go to the uninstall programs part, find the HP related items and uninstall, Use medium setting and delete all files and items it finds, just click on select all and then delete.
When that is done restart the computer, then use the CD or I'll direct you to the full feature download to reinstall it.
I've delt with this scan.msi issue quite a few times here and I know how to solve it. If this doesn't work for whatever reason you would have to go to the cd (right click, open) and find the scan.msi file, when the error comes up asking for the scan file, direct it there (Exactly to the file in the cd, it may be hidden inside a few folders) and it should solve that one.
May 08, 2010 | Computers & Internet
I've connected my IR1023iF to the network. The printer and fax work fine but the scanner doesn't work at all.
If you've hooked up the copier via ethernet cable then it needs to be setup for scan to email, FTP or scan to folder (smb). This can be done through the copiers web interface which is accessed by typing the copiers IP Address into your web browser. If you've hooked the copier up via USB, then there is 'toolbar' software that you would use for scanning. If you need the software, let me know and I can post it on an FTP site. Just an fyi...I'm pretty sure that you can't hook up both ethernet and USB at the same time.
Nov 11, 2009 | Canon imageRUNNER 1023iF Black and White...
Ftp and upnp problems with dns-323
Try to do the following:
1. Login to your DNS-323 in the same network
2. Make sure FTP is turned on and a user is configured to perform FTP to it
3. Ftp to your DNS-323 using the admin account
If this still does not work, read up on Fonz's fun_plug application and install it. This should let you access the linux firmware in the 323 for troubleshooting. Be aware that you need to know linux before you attempt to do this as you may brick your 323 if you are not careful.
Mar 17, 2009 | D-Link Dns 323 2-Bay Network Storage...
Software driver for vidar true scan select plus
Try this:
1. To obtain the driver, go to ftp://ftp.vidar.com/pub/sti drivers/ and
download "autocd.exe".
2. Run "autocd.exe" and the contents will be extracted to a folder.
3. In the Windows Control Panel, open the Device Manager (Control Panel->
System->Hardware Tab->Device Manager) and select the Driver tab within
the Vidar Scanners properties.
4. Click on "Update Driver" and browse to the STI folder (unpackaged from
autocd.exe).
May 09, 2008 | Office Equipment & Supplies
Help with scanning on mour Ricoh Aficia 2035.
Since this is a  network printer, you can scan to folder,FTP site or email. alot will depend on your network enviroment. SMB is the simplest. The folder you are scanning to need permission to write to the folder. If you have email you need to enter your smtp server IP address in the user tools and an senders email address. the manuals with the copier will help or download them.
Oct 12, 2007 | Office Equipment & Supplies
35 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
