Question about Toshiba Satellite M40-S417TD Notebook
Compaq presario V5000 has no power
Notebook has no lights, no power, no cursor.
When I push the on power button, a little orange light flashes on the front bottom left of the notebook, second icon from left on a clear, small screen but this is the only indication of power--no fan or anything. Any ideas? Thanks.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
The light that you said is on is the battery charge light.Check your adapter.It could be the dc jack that is bad.Pull the battery out and try again.
Posted on Jul 29, 2009
Compaq Presario V5000 does not come on
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
http://www.chargerbuy.com/replacement-compaq-presario-v5000-ac-adapter-65w-18-5v-3-5a.html
Nov 20, 2012 | Compaq Computers & Internet
I am opening my pc and after 2 second it went off i have a blinking light like a orange flash light
I imagine the orange flashing light is over the battery? The compaq laptops have a little blue light that will typically light up when it's plugged into the wall. If it is plugged in ensure that the little blue light is on. If it isnt you may have a n issue with your power supply unit, or there may be an issue with the port where the plug is plugged in. Thus causing the battery to be dead and the computer not power on. If you have any other compaq computers you can also try plugging in that power adapter, or try picking up a universal or another hp/compaq charger from somewhere such as best buy to test it out.
Mar 07, 2011 | HP Compaq Presario C500t Notebook
Compaq presario v5000 won't stay
sounds like overheating , probably due to the cpu or gpu fan/heatsing loosing contact, even a little knock could have caused this
Jul 16, 2010 | Compaq Presario Notebook
Hi.. I have a Compaq Presario M2000. How do I turn on the wireless. Or does it even have that. It has a wireless symbol but it's not lit up. Thanks..
Yes, it has wireless and blue tooth. Simply download the owner manual of their website. Here is a link
http://search-manual-online.com/compaq-presario-v5000-notebook-manual.html
Apr 26, 2010 | Compaq Presario M2000 Notebook
Presario V5000 - Thee machine was borrowed out
look it may be a static charge on the motherboard but there are alot of things that make this kind of problems to cut them out try to plug the notbook on external monitor and if it worked you will have a problem with your screen if not then there is a problem in the motherboard
Nov 08, 2009 | HP Compaq Presario V5000Z Notebook
My compaq presario v5000 a 5240NR was working fine
Fn+F1 Decreases the display brightness. Fn+F2 Increases the display brightness
Oct 01, 2009 | HP Compaq Presario V5000T Notebook
No Power, Cannot open
contact ur dealer..its hardware problem!
Dec 27, 2008 | Compaq Presario 700 470024-192 Notebook
Boot into Setup and run the TOOLS / PRIMARY HDD TEST / SHORT TEST.
If it fails, try another HDD.
If OK, verify Boot Order is Floppy, CD-ROM, HDD. Exit Setup.
Print Table 1 Low Level Format instructions from http://support.microsoft.com/kb/106419
Boot with a DOS disk that contains Debug. Run the Table 1 script. Turn V5000 Off.
Boot with the HP Operating System CD. XP install should now proceed normally.
Good luck.
Sep 12, 2008 | Compaq Presario V5005us Notebook
This series of compaq laptops have an issue with current draw on the mainboard, you will need to send it to compaq for a new mainboard.
Feb 18, 2008 | HP Compaq Presario V5000Z Notebook
My compaq presario v5000 shut down and wont restart
Depending on your Bios Version I think later then V44 fixed a bug that would cause your computer no to start if the battery was dead with the V5000. Remove the battery and try booting from just AC power.
I have also had the same issue when my bios battery is loose or dead. The battery can be accessed from the memory area. Once you open it on the left should be memory and on the right will be the wifi card. You don't need to unplug the cables just remove the wifi card and examine the battery. The battery is held by a very very flimsy piece of platic and really easy to break. The best thing I have found is using a little piece of cardboard from a box or something and using it to keep the battery tight, just dont go shaking the laptop alot and it will hold it. It might also be possible your bios battery is dead.
From what I say I would hit power it would power for about 3 seconds the power light would flash then turn off.
Nov 01, 2007 | HP Compaq Presario V2000 Notebook
Toshiba Satellite M40-S417TD Notebook Logo
695 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
