Question about Hotpoint HTS16HBR Top Freezer Refrigerator
Ctx16 cibnlww freezer not working; fridge is ok
5 Suggested Answers
  • 17 Answers
SOURCE: fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
the problem is there is a build up of ice insid of the freezer .
What you need to do is take out all your draws in the freezer and you will see a plastic backing held on with about 8 screws . undo all the screws and the back should come aay and you will see all the ice built up . just use a hair drier to melt the ice and that should cure your problem.
Posted on Dec 10, 2007
  • 351 Answers
SOURCE: ER 8034-1 fridge not working but freezer ok
you have either a defrost problem or a bad evaporator fan motor
Posted on Jun 24, 2009
Fan not working, fridge not cooling anymore, freezer seems ok
Hotpoint Fridge Freezer RFA52 BUT I DONT KNOW WHERE IS THE FAN CAN SOMEONE HELP ME TO TELL ME WHERE IS THE FAN IN MY FRIDGE SO I CAN DEFROSE IT.
PLESAE EMAIL ME ON: RAFIK02UK@YAHOO.CO.UK
MANY THANKS
Posted on Mar 01, 2010
  • 884 Answers
SOURCE: Fridge part working freezer not
The fridge is just the end of the freezer evaporator. If the freezer isn't cold inside, check the rear panel. It is probably frozen solid with no air getting through. Switch off, leave doors open for 24 hours and be prepared for lots of water to come out. Clean the condenser and make sure the fan inside is ok. Reset the thermostat to middle of the range and be sure to come back to tell us how you get on.
Posted on May 19, 2012
Bosch kann58a50gb/o8 fridge not cooling freezer seems ok
See or hear if the fan inside is working. Im not conversant with your model. Some units have 2 fans , 1 in the freezer and 1 in the fridge. Some only have1 , which will be in the freezer only. If the fan fails, the fridge cannot blow cold air into the food compartment. Generally, when an evaporator fan fails, the fridge doesn't get cold and the freezer overfreezes causing an excess ice buildup in the freezer.
Feb 23, 2015 | Bosch Refrigerators
I have a Whirlpool wbm46mw Fridge, the freezer is working ok but fridge not getting cold, any suggestions,Thanks
Empty fridge and if possible put steam down vent behind the cover in the freezer section. or hot water. it will com out in the fridge so be carefull. this unblocks the aif feed from the freezer to the fridge section. also make sure the fan is working.
Oct 04, 2013 | Engel Freezer 22 Qt. Fridge/Freezer
May 17, 2012 | Hotpoint Refrigerators
Creda R335NW Fridge/Freezer. The fridge section is not cooling down anymore, The freezer is working ok. Any ideas please?
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Jul 03, 2009 | Refrigerators
Candy frost free fridge freezer .freezer working ok
The thermostat might be turned up too high or is faulty. It should click when turned up and down from the setpoint.
May 12, 2009 | Freezers
I have a schreiber fridge freezer. Display is showing H for fridge, freezer is ok. Can anyone help? Thanks Anne
APM6855 Built in fridge freezer If Fridge is not cooling & freezer is ok then try a defrost by switching off for 24 hrs Then switch back on. it should be OK. If this does not work it is probably the door switch faulty , this should switch on the fan when door is closed. The fan is then controlled by thermostat sensor which switches fan off/on when required.
Nov 15, 2008 | Refrigerators
I have a refrigerator model # CTX14CYSJRWH. My landlord says that this is a 16 cubic feet fridge & we say it is 14 cubic feet. I need documentation as to which is correct.
ctx14cys**** the 14 is a give away, it would be a ctx16 if 16 cube. heres a sire just pop in the model number ittl clearly stae it, ifthe link doenst work, i went to www.ge.com, ad nfound it through there
http://genet.geappliances.com/DocSearch/Dispatcher
Apr 08, 2008 | Refrigerators
Fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
Nov 04, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hotpoint HTS16HBR Top Freezer Refrigerator Logo
67 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
