Question about Garden
Motor runs, but blades dont move - Garden
MY ELECTRIC 22" BLACK AND DECKER BLADES DO NOT MOVE. MOTOR HUMS
Posted on Aug 10, 2009
With engine off, take a screw driver and manually move the blades to make sure that they are not jammed. Then spray the blades down with wd-40 oil and they should move freely again.
Posted on Jul 30, 2009
3 Suggested Answers
  • 640 Answers
SOURCE: hedge trimmer blades dont move
Likely the pin in the gear has sheared. You will need to replace it. It is designed to shear to protect the motor.
Posted on Aug 26, 2011
  • 5 Answers
SOURCE: homelite hedge trimmer , motor runs but blades do
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
Posted on Jun 09, 2010
I have a TS300 table saw and the blade does turn immediately when power upped, the blade speed seem low, and the blade easily stall when cutting - even 1/4" ply.
There are two windings in the motor, a starting winding and a running winding. There's also a centrifugal starting switch in the motor that switches from the starting winding to the running winding once the motor gets up to speed. Sometimes the switch can get stuck and you almost have to give the blade a spin with your hand to get it moving-- and then it moves slowly till it picks up speed.
A rating on that saw complains it doesn't have a whole lot of power, but yours doesn't sound like its under-designed -- it sounds like there's something wrong. Does it smell hot when running? Does the arbor turn freely? Are you using a long extension cord? (dont!)
I hope you don't need a new motor ($255)
If you do, I'd sell the thing for parts on CraigsList and look for another saw in the same place. I bought one table saw on craigslist for $60 and another for $45. (You might have to watch the listings every day for a year or so to get those kind of prices.) Both of the ones I bought are belt-drive contractor's saws with a 1.5 hp motor outside the box on the back side of the saw.
Oct 17, 2014 | Saws
Replaced wiper linkage but wipers still dont work 1997 civic
both dead?
there are 2 wipers and 1 motor and simple linkage.
does the motor run?
does it make sound.
does it turn? (look at it)
if the motor runs, then make sure the linkage moves. does it?
if the linkage moves, then the spindle drives must turn , do they
if they turn the blade arm turns, do they not?
Jan 26, 2014 | Honda Civic Cars & Trucks
Wipers stopped working on 2008 saturn aura
Look at the motor to see if it is still connected to the wiper arm linkage.
Jan 09, 2014 | 2008 Saturn Aura
Hedge trimmer blades dont move although the electric is still getting to the motor you can still here the motor turning but no movement from the blades
Aug 23, 2011 | Garden
Our hampton bay fan has stoped spinning but lights still work, why would the fan itself all of the suddent stop working? thanks
One of the biggest problems I have encountered with ceiling fans has been the wearing out of the manifold, the rubber device that holds the fan blades to the motor. I have never seen them fail where all blades fall off at the same time, but I guess it is not impossible. If this has failed the blades would still be hooked to the outer ring, but not move even when the motor runs. If you can hear the motor running and the blades are not moving it may be the manifold. If the motor is not running it seems obvious that it is a motor problem or a motor controller/remote controller problem. Not easy to repair.
Aug 29, 2010 | Dryers
Homelite hedge trimmer , motor runs but blades do
What I did:
And it worked!
May 16, 2010 | Homelite Factory Reconditioned 26cc...
Wahl KM-SS pet shaver motor runs but cutters dont move
it seem that shunt arm that move the cutter blade is broken or off it's guide without look at it it's hard to tell what wrong, try Contact mannyssharpening@yahoo.com they are a Wahl Dealer they have all the parts for Wahl clippers. they can help.
Mar 05, 2010 | Wahl 8892-002 Kennel Pro Clipper Kit
98 ford expedition wiper problem
check the transmission assembly at the motor it may be stripped or a c clip came off
Jan 11, 2009 | 1998 Ford Expedition
Front blades not working fuse ok
The motor is usualy central to the wiper arms and either bolted to the firewall or inside the plenum chamber at the bottom of the windscreen.If you can hear the motor you can find it, track it down by listening.Your probly right about linkage however if that is the case you should be able to move the wipers with your hand and they should move freely if they dont you may have other problems.
Dec 17, 2008 | 1996 Nissan Altima
Garden Logo
674 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
