My computer recently lost all video when I start up I get a series of 2 short and one long beep upon start up
  • 596 Answers
The code you get is usually a BIOS error code for falure to initalize the video startup. If you are able to enter the BIOS, try resetting everything to default setting and restart the pc.
Please keep in mind, this is a general solutions. Some manufacture have thier own codes for each product. If you are unable to solve this with what I have recommended, post the model of the motherboard and I will get the correct solutions information for you.
Franklin
C2Solutions
Posted on Jul 28, 2009
Beep problem
Depending upon which BIOS chip is installed on your motherboard the POST beep codes indicates -
one long, two short beeps
  • System board failure
  • Video adapter problem
  • LCD assembly failure
one beep, three short beeps
three short beeps, one beep
  • Memory problem: bad DIMM or bad DIMM slot
Aug 11, 2012 | Computers & Internet
AMD sempron power supply
I would venture that "shows winfast on monitor" indicates the type of Video Card that your PC is using. Thereafter it should go to POST showing the motherboard, BIOS, memory count and others.
Since as you posted, after Winfast nothing follows, I can only suspect that you have a motherboard problem or at least a BIOS corruption.
Please post back the brand and model of your computer or at least what motherboard.
Good luck and kind regards.
Thank you for using FixYa.
Mar 16, 2008 | Computers & Internet
Compacq 3 beeps? at start up?
Depending upon your BIOS this could mean -
May 29, 2012 | Computers & Internet
1 long beep 2 short beeps
sounds like you've got a dead graphics card
May 16, 2012 | Nvidia Geforce FX5500 5500, (256 MB)...
I have recently built a new PC with an Asus P8H61-M and upon turning the PC on I am recieving no Visual on either of my monitors
Hello
If this is the first time to turn you on your computer check first the power supply of your computer if connected to their proper connector. Check your memory if clip properly in there memory slot. If you are using Video Card check it if it is properly connected to the connector. Then connect your VGA connector at the back of your computer when you have video card connect the VGA Cable of you monitor to the video card VGA output if does not have connect it with the onboard VGA output. Then press the power switch if the unit is still no visual in monitor try to search or hear a beeping sound in your computer by its on board buzzer. Find which beep you hear from your computer.
No Beep- No Power, Loose Card, or Short.
One Short Beep- Normal Post,, Computer is OK.
2 Short Beep- POST error, review screen for error code
Continues Beep- No power, Loose Card, or Short
Repeating Short Beep- No Power Loose Card or Short
One Long And Short Beep- Motherboard Issue
One Long and Two Short Beep- Video (mono/CGA Display Circuitry) Issue.
One long and three short beep- Video (EGA) Display Circuitry
Three Long Beep- Keyboard/ Keyboard Card Error
One Beep, Blank or Incorrect Display -Video Display Circuitry
Hope this help with your problem. Keep on touch in fixya
Jul 19, 2011 | ASUS P8H61M Intel H61 TX Motherboard
Getting a single beep upon startup, no video signal going to monitor.
One beep means everything posted right
I would start with the video card and pull
it out of socket then reinsert it you could
have a bad card or bad cable or the
mother board cant handle vcard
No Beeps
Short, No power, Bad CPU/MB, Loose Peripherals
One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Jan 14, 2011 | ASUS M4A77TD Pro Motherboard AM3 AMD 770...
When you turn on the computer it makes a series of stringed beeps for a second also when turning it off, keyboard and mouse does not work
what's the beep pateren it does? here is the basic beep codes:.....
Error Code: Faulty Component:
1 short beep None (Normal Boot)
2 short beeps POST error
Non-stop beep Power supply or system board
1 long beep and 1 short beep System board
1 long beep and 2 short beeps Video card
1 long beep and 3 short beeps Memory
3 long beeps Keyboard
Non-stop short beeps Power supply or system board
(a key on the keyboard might
also be stuck)
None Power supply, system board,
or system case built-in speaker
Oct 01, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
1long 2 short beeps, No POST/Visual display
Hi there
One Long and Two Short Beeps = Video (Mono/CGA Display Circuitry) issue.
If you are using a PCI Express graphics card remove it and use the on-board VGA/DVI port
If it is the on-board graphics you are using clear the cmos
d015d7b.jpg<<<<< you will see in the picture a plastic jumper (in this case coloured green), move it to the other position and hit the on/off button, then put it back in its original position and power up the machine again. Hopefully the issue will have been sorted.
Good luck and thanks for using Fixya!!
Feb 18, 2009 | MSI K8N Neo4/SLI Motherboard
Computer beeps when I try to start up
No Beeps
1 Short Beep
Normal POST, computer is ok.
2 Short Beep
POST error, review screen for error code.
Continuous Beep
One Long and one Short Beep
Motherboard issue.
One Long and Three Short Beeps.
Video (EGA) Display Circuitry.
Three Long Beeps
Keyboard / Keyboard card error.
Video Display Circuitry.
Jan 05, 2009 | HP Computers & Internet
Computers & Internet Logo
167 people viewed this question
David Payne
David Payne
