The image is Backwards
I have accidentally pressed something that has made the image backwards so words read ''fael'' instead of ''leaf''
  • 2,237 Answers
Go into the menu and reset the settings to factory default, or just go into the image settings and chose "front". it's set to "rear" right now.
Posted on Nov 06, 2009
I have a Panasonic projector style TV that was donated to my nonprofit but the words all appear backwards. Is this an easy fix? What if anything can be done economically?
Press the menu button w/the projector on ,projecting a image.There is a reverse image selection that you just need to undo :)
May 26, 2014 | Office Equipment & Supplies
Words are showing backwards
Your projector has been set up for rear projection - you need to change it to front projection. Access the setup menu, then use the option to flip the image horizontally. Viewing the image in a mirror may make it easier for you while navigating through the menu options
Mar 27, 2014 | InFocus Office Equipment & Supplies
Words are spelt backwards
Your projector has been set up for rear projection mode (projecting the image from behind a translucent screen. You need to access the setup menus and reorientate it for front projection. Using a mirror to view the image whilst navigating through the menus may help :o)
Mar 27, 2014 | NEC VT465 Multimedia Projector
Error code backwards C then C
Are the C's very angular, like ] [ instead of OC (pardon the O, I don't have a backwards C). If you're seeing ] [, they're telling you you need to switch the bobbin winder off. Then the machine can stitch.
Mar 05, 2014 | Singer 5500 Fashion Mate Sewing Machine...
When I print something instead of comiing out completely opposite like the printer is Dyslexic. In order to read it you need a mirror to see it like a normal print. Even the words in the shapes are...
Hi
In your printers properties
you have change printing properties
and you have choose mirror printing
just go to the menu and change it
Pls vote us to keep us alive
Nov 17, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Image is upside down and words backwards
malfunction in the camera and will need repair
olympusamerica.com/repair
Oct 17, 2008 | Olympus FE-210 Digital Camera
Nec vt 675 projector
Hi there
Simply go into the menu and flip it back in the subfolder that will either read Mirror or Horisontal / Vertical Positioning
Apr 09, 2008 | Office Equipment & Supplies
Printer prints backwards/upsidedown
This sounds like an advanced setting on your printer setup. When you get to the print dialog, hit Properties for your printer, then look around there for a "mirror" or "reverse" setting. Different printers use different drivers, so your configuration options are difficult to predict.
Apr 18, 2007 | Brother MFC-5840CN All-In-One InkJet...
My Screen is upside down and the words are backwards
The first thing I would do is a reset. Read your manual about this process, which often requires pressing two buttons at the same time or take your batteries out, wait a minute and put them back. See if resetting helps. Not being familiar with your camera, speciffically, Ithis sounds like the firmware in the camera is reading the info back to you backwards when it processes the image (from memory) for you to view. That means it is the firmware in the camera that is defective and sometimes you can update or reinstall that. I would check the manufacturer's site for updates or recalls and if it is under warranty, send it back to be fixed.
Jan 28, 2007 | Fuji FinePix A120 Digital Camera
815 people viewed this question
jasbo
jasbo
