Question about Stanley Bostitch N80s Nailer -rebuild Parts O`ring & Seal Kit
When trigger acuated it goes thru the actions but no nail comes out. Prior to this happening it would not set nail.
  • 142 Answers
One of 2 things....1. need oil in a bad way, or 2. needs a new set of head seals
Posted on Jul 29, 2009
Have stinger cn100 nail gun, stopped plunging nails in wood, when pulling trigger, nothing happens?
There is a roll pin that holds the trigger in place. Remove the roll pin with a punch or a nail filed flat. The trigger valve will then come out. Clean, lubricate and reinstall. It should work.
Dec 16, 2017 | Air Tools & Compressors
My new porter cable RN175B nail gun won't discharge a nail
If the trigger is set to single fire, you will need to place the gun against the work then pull trigger as you have done. Try setting the trigger to bump fire and try again. If hear a thump inside the gun, remove the head and check that the head valve in not stuck from lack of lubrication. Easy test, remove the nails, remove trigger pin, remove trigger and manually push trigger firing valve. If the gun fires then suspect faulty trigger or safety arm not lifting enought to activate the trigger valve. Good luck
Nov 21, 2012 | Air Tools & Compressors
Nail gun problem
This is a bottom fire tool. (NV83A2) You need to hold the trigger down and then as you place the nailer to the wood the safety will depress and it will fire once. This is usually done in one, swift action. If you do this in the opposite way by placing the tool to the wood and then pulling the trigger they often will double fire.
Jul 05, 2012 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
DOESN'T FEED,IT MIGHT MISS SHOOT A TIME OR TWO THEN GET A NAIL THEN NOT FEED.I'M SHOOTING A 1.5"TECO NAIL. ANOTHER GUN DOESN'T SHOOT EVERY TIME LIKE THE DEPRESSOR ISN'T LETTING THE...
Usually miss feed happens when the driver does not return to top position not allowing the nails to feed into position. Easy to check, point nose of nailer up then down again to see if the driver is loose in the cylinder. If loose, the driver will be in the down position when the side door is opened. If driver is down, replace driver oring. If driver oring is good, look for spring tension on feeder and check feeder spring on the door side. If piston oring good and feeders have good spring tension, suspect lower bumper cracked(remove head and piston to check bumper).
On gun with depressor (safty foot) not actuating trigger, look for worn trigger (trigger inner lever could be worn) or loose or worn firing pin in the trigger valve above the trigger(valve # tva6). Replace as needed. To check for proper gun action, remove the nails, remove the 3mm roll pin holding trigger and dry fire the gun by depressing the tigger pin. Good luck
Sep 21, 2011 | Stanley Bostitch Coil Framing Nailer
I have a N-60 finish nail gun. It is leaking from the trigger and it is trying to fire a nail and discharges the rod to drive the nails and the rod stops and will not retract. I think I need to purchase...
the trigger valve could be causing a lot of your problems, you are correct in ordering the o rings and trigger valve, make sure to lightly coat the o rings before installl. If you have trouble with the valve I have detailed instructions in the TIP section on how to remove safely.
Aug 15, 2011 | Stanley Bostitch Nail Gun
Porter Cable FN250c wont shoot with every trigger pull. sometimes it shoots correctly (10% of the time), other times it just pops (no nail) and other times it shoots two nails at once. Also when it...
Worn trigger and or worn firing valve. Remove the trigger and look for wear on contact surfaces (worn pin that holds trigger, worn inner lever inside trigger, worn or loose firing pin in valve ). Easy test for worn trigger. Remove the nails, remove trigger, fire the gun against wood with finger to test for proper action. If it works better without trigger, consider replacing trigger with new (I would also order the oring repair kit that includes the firing valve )
Jul 26, 2011 | Porter Cable-Cable FN250C 1-inch...
I have a 12 volt black and decker nailer (BDNB1202 Type 1) and it will not shoot nails. It just quit working, the battery/jam light blinks when I insert the battery, but when I press up against a board...
Since the jam light blinks, have you considered that it might be jammed?
Try removing all the nails, checking the action, and they reinserting?
Other than suggesting taking it in under warranty or taking it apart to check switches and sensors, I can't think of what I could suggest.
Feb 26, 2011 | Black & Decker Tools & Hardware - Others
When hose is hooked up, driver goes down and air continually blows thru nail gun, out the top
could be a problem with the trigger valve assembly or the firing valve. I would check the trigger valve assembly first for sticking not allowing the air to release and retract the driver.
Feb 20, 2011 | Tools & Hardware - Others
I have a Item #9100 Powershot Pro Electric Staple & Nail Gun. I have lost my manual. Please tell me how to load staples.
I just purchase the powershot 9100 I can't get the trigger to work for the staples to come out. What am i not doing correctly?
Sep 18, 2010 | Powershot Tool Company Cobra 8000 Forward...
I have a hitachi nv 65 ah that will shoot two nails at time
I hope this doesn't offend you. What I'm suggesting is that you may not be using your nail gun correctly. Some people keep the trigger pulled and bounce the gun onto the wood. This technique works okay, but placement accuracy of the nail suffers. The other technique is to place the gun on the wood and pull the trigger USING TWO HANDS! This is the technique suggested by the manufacturer. The problem with this technique is that if you apply insufficient pressure to the gun (USING ONE HAND) the safety is not engage so you don't shoot a nail. What usually happens - I just witnessed this a couple of weeks ago - is that not enough pressure is applied while pulling the trigger so you push harder and end up bumping the gun which shoots a nail - because you have the trigger pulled, but the nail shot was a surprise so it causes another bump (and is more apt to bounce because you're using just one hand). Because it is a machine and can operate faster than your reflexes - it shoots another nail. This happens before you can lift it off of the wood, or remove your finger from the trigger. That's the reason I keep the trigger pulled and bounce it. I know that after the bounce I've set a nail, and can remove my finger from the trigger. When I need to accurately set a nail I always use two hands, press hard and pull the trigger, and release quickly. Only pull the trigger when you know you're about to set a nail, and are poised above the workpiece.
Dec 09, 2009 | Air Tools & Compressors
Stanley Bostitch N80s Nailer -rebuild Parts O`ring & Seal Kit Logo
233 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
