I have a panasonic PT-51HX40 and the picture is good but occasionally the tv will just turn off. If you leave it for a minute and turn it back on then it works again. What can I do to fix it?
  • 10,594 Answers
Sounds few electrolytic capacitors in power supply and deflection section are weak / bad and require to be replaced.
If you are familiar with electronics stuff repair. please take off back cover of TV and look for bulged/ leaky electrolytic capacitors on main board, also check / repair dry solder joints underneath main board.
You can download repair manual of PT-51HX40 from HERE for small fee that has exploded views and schematics.
Thanks.
Posted on Jul 28, 2009
My panasonic PT-51HX40 turns off by itself
There can be several causes for this, few of which you can do anything about. However, a few things to try:
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
I hope this helps. Joe
Jan 14, 2010 | Panasonic PT-51HX40 51" Rear Projection...
Tv wont turn on> is there a reset switch?
reset button can apply when the tv turns on. first the tv has a short circuit and has to be repaired in order to be able to reset the tv to the original settings created in the program as brightness, color etc.
your tv now needs a visit to the workshop first, to turn on.
Apr 14, 2009 | Panasonic PT-51HX40 51" Rear Projection...
Panasonic PT-51HX40 Wont stay on
could possible be bad conections
I had a set that was doing that the bad conection was at the relay but you always check all conections
hope this helps
Jan 31, 2009 | Panasonic PT-51HX40 51" Rear Projection...
Red tinted double image above the normal image.
hello consumer MG,
you need to change your STK392-110. Replacing those 2 chip will fix your set.
best regards
circuitcity
www.interactiverepair.com
Jun 08, 2008 | Panasonic PT-51HX40 51" Rear Projection...
Tv trouble
Stk392-110 Convergence IC's bad.....requires chassis pull &
good soldering ability.......................T.
Jan 28, 2008 | Panasonic PT-51HX40 51" Rear Projection...
It shuts off all by its self but not all the time
If I was working on this set I would look for cold solder joints on IC501 Vertical output IC.
Sep 03, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Color shift
There is going to be 2 ICs. Both should be replaced at the same time.
May 12, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Multi color snow
The most common problems with Panasonic's is the "DG" board. It usually is not the leat expensive module to replace and cannot be repaired it has to be replaced.
May 02, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
