Question about Zanussi TD4212W Electric Dryer
Td 4212 w Drier is not heating
Our drier td 4212 w is 6 years old but isn't heating. Can I fix this myself
Check if it still turns but no heat. If it's a kenmore or whirlpool, it's like a fuse in back of dryer. I would need mor info if it's not these models
Posted on Jul 28, 2009
Drier is running hot, smells like my clothes are burning, and it keeps blowing the fuse in the main panel.
Most probably a venting problem and probably caused the heating element to ground out in its casing. Easiest way to verify is turn your timer to 30min and if dryer starts heating without pushing the start button you got a bad element caused by bad venting most of the time.
Apr 16, 2013 | Estate TEDX640JQ Electric Dryer
Drier won't heat
try replacing hearter wire under drier
Apr 08, 2012 | Whirlpool Dryers
96 lhs has drier leaking can the seals be replaced , do i need to remove/ replaced the drier ?
Yes you can replace the seal only,Its only a bag in there that attracts moisture, do you need to replace it not really,Just replace the seal and ensure there is no leak.But if you open the system you ll need to draw out the air before you refill with freon
Apr 28, 2011 | 1996 Chrysler LHS
LG- CONDENSING DRIER- TD-C70080E DRIER IS NOT HEATING UP AT ALL CAN YOU HELP?
I think you're talking about gas Dreyer
Check the entrance of gas
Dec 28, 2010 | Dryers
My hotpoint aquarius tumble drier is making a very lound griding sound as it turns. What can it be and can it be repaired by myself? the drier is over 8years old is it time for a new one?
This is the plastic "wheel" on the motor that drags the drive belt to spin the dryer. you will need to push back into place with something thin. under the right hand side of the dryer there will be a grill under the motor. look for a black plastic "wheel" and move it away from the casing with something that can fit through the grill.
May 16, 2010 | Dryers
Hi, I have the Asko dryer T721. It's about 6 years old and is starting to emit a gas smell when it is on. It also seems to be taking a lot longer to dry. I have followed the manual to clean it and it works...
Umm, i think its time to say goodbye to your drier, i had a drier, when it got past the 4 year mark, it made a weird smell, then it kind of set itself on fire, call asko if you can, ask them....
Jul 20, 2009 | Asko Dryers
My drier is a Maytag, it is not heating up the way it should be.
There is a chamber that the air blows down before hitting the vent pipe. It may need to be cleaned. But you want to make sure when you push your dryer back, that the vent doesn't kink. good luck. Overall you drier works, your just having a venting issue.
Apr 04, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Roper Drier no heat and continuous run for two hours
Your drier heating elements operates on 220 voltage, the drum and clock operate on 110, so you either have a blown fuse in one side of the fuse box ( easy fix )some time the circuit breaker will just need to be reset by turning it off and back on, or your heating elemant has opened up and will be more expences to fix, or it could just be a wire end has burned off. unplug plug from outlet remove back from drier and have a look see, and if bychance you have forgotten to clean your link trap if could be a high temp safety that has open and sometimes can be reset by pushing the reset button, all this is inside the back of the drier, if after that it may be time to call your friendly repair shop
Oct 20, 2008 | Roper REX4634KQ Electric Dryer
Maytag Drier, doesn't turn, doesn't heat, but dings.
hi thanks for the question i would check the power coming to the dryer it looks like its only getting 110 check that the appliance doc
Sep 17, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Zanussi TD4212W Electric Dryer Logo
356 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
