Question about Frigidaire FEF336BC Electric Kitchen Range
Oven does not come on
  • Torgy Dec 25, 2007
    I have the same issue with the oven and broiler elements not heating up.
    I disconnected the power, tested the elements with an ohm meter and received continuity on both elements. The bottom element though did have some contact damage since it was bent down into the enamel at the bottom of the stove. Again, both bottom and top elements measured ok.
    Question, is a basic ohmmeter ready a good enough test, or does the appliance repair shop perform a more enhanced test ?
  • 833 Answers
First, reset your circuit breakers. This is generally a pair of breakers with at least a 30 ampere rating. It is not your kitchen breaker. Turn them both off and back on. If this doesn't do it, you've got to look at the heat element. Does it look damaged, deformed, discolored? If so, remove it and bring it to the appliance guy to get it tested. Generally this is a couple of screws. Make sure power is off when dealing with this. Not the element? Then you've got the control board.
Posted on Dec 13, 2007
I bought Frigidaire Electric Range CFEF 358EC2 in2005. Now Electric own touch buttons not working and oven range not working
Posted on Dec 25, 2007
While baking my fridgidaire oven started beeping with the code F5, does anyone know what this means and how to make it stop?
Oven temp sensor shorted.Press and hold any key down to clear and make it stop beeping.
Feb 07, 2011 | Frigidaire Ovens
My fridgidaire oven shows a f3 error code
F3 Open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Nov 06, 2010 | Frigidaire Ovens
How do I self clean my gallery series fridgidaire?
Some of the self cleaning ranges require that the door be locked before the self-cleaning cycle will work. If your oven door has a manual locking lever then make sure it is completely latchedthen press the self-clean button. Also make sure the dooris completely closed because if there is not a manual latch then it will be a auto latching system. If not then there could be a problem with the button on the control panel for the self cleaning option.
Jan 14, 2010 | Kitchen Ranges
My fridgidaire "FMV157GB" microwave has no power. is there a breaker?
HI, this is an unfortunate power board failuer. there has been a major burn out within the capacitor set and a diode as well. you will need to replace the power supply board in this unit asap if possible.
May 26, 2009 | Frigidaire FMV157GM Microwave Oven
I have Fridgidaire 30'' wall oven. Tried to bake something but only the broiler will ignite. NOT the oven! AHHHH...I want to cook my meatloaf. Help?
your model says its a 24"
but the hot surface igniter for oven is bad
it should have a seperate one for broiler
check here on fix ya ( hot surface igniter)
Mar 09, 2009 | Frigidare FGB24S5DC Gas Single Oven
Cleaning between oven glass
You must unscrewed inner door,there is screws around edge door inside,try it.
Feb 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
It is most likely the pop came from a relay on the control board if the elements checked ok but not getting power to them. This is fairly common on fridgidaire ranges. Replace the oven control. Usually the control overlay is sold as a separate piece.
Nov 12, 2007 | Kitchen Ranges
Frigidaire FEF336BC Electric Kitchen Range Logo
358 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
