Question about LG RUMOR Cellular Phone
CRACKED SCREEN FROM INSIDE ONLY
MY COUSIN WAS PLAYING BALL AND I WAS HOLDING THE PHONE TXTING AND HE KNOCKED IT RITE OUT OF MY HANDS WITH THE BALL ! i cant afford to get a new phone i just got it 3 weeks ago !
    Sergeant:
  • 277 Answers
Wellcome,you can change the screen of the phone ok.
Posted on Jul 28, 2009
I was txting off of my iphone and all of a sudden the screen whent white then black and doesnt show anything on the screen i can hear tht am still reciving txt ,and calls but the screen is black
Iphones are notorious about the screens going out because they locate the batteries so close and their batteries can run hot their actually a joke for the cost they are when torn apart and seen from inside i would dump the i phone and change to something else.hate to be crude but the only great thing about i phones is the security
Apr 26, 2017 | Cell Phones
I replaced my tierod on the passenger front.there is still some play in the left to right there is also a humming sound at speeds 40+mph. it's coming from the hub bearing or ball joint.
Any wear or play in a bush or rod usually gives a 'knock' or causes vibration, not a humming noise.
If there's play in the steering wheel that may be due to a worn steering rack and pinion.
A worn ball joint can cause a 'crack' noise and depending on the wear, vibration that will be felt through the steering wheel. A worn ball joint can also cause the car to pull to one side.
A humming noise suggests it is either a brake rotor/pad, or a worn driveshaft or wheel bearing.
Feb 17, 2016 | Cars & Trucks
What to when my Alcatel 991D does not sense at all when touching the screen?
I don't think this is a breadmaker but rather a touch screen mobile phone. Check the screen for cracks . I have a mobile phone that I dropped and cracked the Liquid Crystal Display. It does not sense the right hand side of the screen. It took me 2 days to figure out the screen was cracked as it was hard to see the crack.
Nov 26, 2014 | Kitchen Appliances - Others
Knocking Noise from Front End Toyota Corolla 2004
Ensure the wheel nuts and Axle nuts are properly torqued to the specification. Lift up the front wheels, place supports under the car and do the following:
- Sit if front of right wheel, slightly move it right and left and feel any abnormal noise if coming out of it. If click-click or Tuck-Tuck sound is observed it could be due to the excessive play in the tie rod end, rack end, ball joint wheel bearing or U joint. Next hold the Tire with your one hand at the top and with other hand at the bottom. Shake the Tire inside out and feel any noise or play. If play is observed, it could be the worn out ball joint or the wheel bearing. Now hit the Tire at the top with rubber hammer and observe any rattling noise coming from near the center of the wheel. If you could listen to the extra noise it could be due to the dried up caliper pins. Grease the pins with graphite grease. If all is found fine, similarly check the left wheel and repair as necessary.
Sep 15, 2013 | Toyota Corolla Cars & Trucks
Squeaking noise when turning rite
Its most likely a dry ball joint or tie rod end. I would have your front suspension greased if it is serviceable, otherwise you should have your ball joints inspected for wear and replace them if they are dry or beyond their service life.
Jun 17, 2013 | 2000 Suzuki Esteem
Crack inside screen blue red green lines
You have cracked your LCD screen (the screen that displays the picture). The glass on top of it is called a Digitizer Screen (the screen that recognizes your finger). This is a fixable problem, but the cost to repair will depend on the phone, insurance or lack of, and who you get to repair it for you....hope this helps you some.
Nov 28, 2012 | Cell Phones
Cat knocked evo unto ceramic tile floor. Screen is cracked but also looks like large growing ink splotches on the inside. Is this just screen and LCD
It sounds like not only was the glass screen cracked, but the LCD has been damaged as well. My suggestion is to find a local cell phone repair shop and get it replaced. It should be pretty easy to fix and shouldn't cost too much. Unless of course you have insurance on the phone..if so then just order a new one.
Mar 12, 2011 | Cell Phones
CRACKED SCREEN
there is no other way around it you need to replace the LCD screen, go to your nearest service station an have it replace
Jul 28, 2009 | HTC G1
Starting to get a knocking noise from front right hand side
Check if you Discs is cracked, You can even take it for a cut, thats all I can Think of hop this helps.
Dec 30, 2008 | 2003 Ford Focus
My phone keeps freezing and restarting
it will end up costing you about 15 dollars but take it to a repair shop for the provider you use and they should be able to save all your info and flash a new version of the software onto your phone but it won't be free, that's the only way to fix that without buying a new phone.
Dec 28, 2008 | Verizon Communications enV2 Cellular Phone
LG RUMOR Cellular Phone Logo
67 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
