SOURCE: Hyundai TV Code
there is a help line number in back of code book and they will tell you codes for your tv...or do the auto search which should be in instructions for if you cant find your code in the list
SOURCE: Remote control set up code
Try searching for the code
To search for your television code:
1. Switch your television on (not in standby).
2. Press and hold down MAGIC until the ONE FOR ALL
1 red light blinks twice (the red light will blink once
then twice).
3. Press 9 9 1. The red light will blink twice.
4. Next, press POWER.
5. Aim the ONE FOR ALL 1 at your Television. Now press
CH+ over and over, until your Television turns off
(every time you press the CH+ key the ONE FOR ALL 1
will send out a POWER signal from the next code
contained in the memory). You may have to press
this key many times (up to 150 times) so please
be patient.
If you skip past a code, you can go to the previous
code(s) by pressing the CH- key. Remember to keep
pointing the ONE FOR ALL 1 at your Television while
pressing this key.
6. As soon as your television
SOURCE: bought remote from dollar store no instruction
I've bought the same remote control w/ out brand, and I've been using that for a long time. When I bought, it came w/ a manual w/ many codes... but u can use the general search that for me is better.
For example, you wanna fix a TV
1st - press SET button and the TV1 button AT THE SAME TIME (the RED light might be turned ON)
2nd - Press the SET buttton, and you'll see the red light shine, twinkle. (it means that the remote control is trying all codes)
3rd - while the red light twinkle, try pres the ON/OFF button... you should press the ON/OFF button many times, and when the TV turns off is because you found the code, so press TV1 button to stop the research in your remote control.
***PAY ATTENTION!!! If you don't stop the research at the same time that the remote control find the code, you'll lose the code... so you need restart everything again.
I hope it gonna help you!
SOURCE: REMOTE CONTROL CODES FOR ASTAR TV
Have you tried a Code Search with your remotes. If that does not work try calling or emailing Astar they may be able to help.
Astar Electronics
Tech Support:: (626) 851-2528
[email protected]
www.astarelectronics.com
SOURCE: BASE TV UNIVERSAL REMOTE CODE
I have had the same problem with my BASE TV, i purchased a DIGITECH AR-1727 remote which has an Auto Scan function. It took me a while to find the right code but came up with '173'. Not sure if it is the same for all remotes but try and see!!!!
