Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
Can not find a part for my stove #9755075 is on the circuit board this is a hot/cool whirlpool polara
  • ariel santos
    ariel santos May 11, 2010
    this part number may not be the right part number you require, what is the name of the part?, sometimes manufacturer changes part numbers let me know so i can bettre assist you
What's causing my oven to stay hot HOURS after I've turned it off?
If you have the older type stove with the oven knob that has the temperature setting around the outside of the knob, then that part could be bad. It is called a thermostat. That part usually comes with sensor attached. The sensor is the long skinny looking tube that goes through a hole and into the oven.
If you have the newer type electronic stove where you program in the temperature you want, the electronic circuit board could be bad. But the electronic stoves have a over temperature protection built into the circuit board, so that would have engaged, shutting down the stove.
Either way, it is a potential fire hazard and needs to be addressed.
Nov 07, 2014 | Hotpoint Ovens
Have a whirlpool stove model # wbp88800. There is
F8Board failureReplace control board (also called ERC or clock).
May 14, 2011 | Whirlpool Ovens
Have a stoves 720 es main oven fan does not stay on to cool oven after switch off> also the oven will not trun back on when it is still hot or warm ? will
First things first. There are two fans. One in the bottom oven and one to provide background cooling. The background cooling fan turns on when anything is turned on. (Fan oven/top oven/grill). Just operate the top oven for a moment and this should cause the cooling fan to operate. There is a printed circuit board that controls the cooling fan and for how long the fan should stay on once everything has been turned off. (About 7 mins). If this fan is not running then the fan/motor could be faulty, or the circuit board or the resistor on the fan terminal block. The reason the oven will not turn back on is that the residual heat in the oven unit as a whole against the fan oven, is probably too high which causes the overheat device to operate.
You will have to take the oven out of the kitchen carcass, take the top and rear panels off and get an electrician to test and found out which item is not working/failed. Try espares for parts.
Jan 24, 2011 | Stoves 720EF Electric Double Oven
My Stoves 720EF oven blows the trip when cooling fan stops
The fan timer printed circuit board controls the cooling fan and there is also a resistor on the terminal block of the cooling fan. One or both of these could be suspect. If the fan still runs, then the resistor hasn't gone open circuit and is still providing continuity. The only way to prove out the circuit board would be to change it, but that could be expensive especially if it doesn't cure the problem.
Aug 23, 2010 | Stoves 720EF Electric Double Oven
What does Pr mean
Hi
If you are referring to the marker on the oven - PR stands for Polara Range.
Thanks for using FixYa.
Oct 28, 2009 | Whirlpool Ovens
This time the oven
it sounds like it is the circuit board. i still use my mothers old viking stove, the old ones have none of these things that keep on braking.
Jul 22, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
How do I light the oven on a gas stove
If this is a newer stove (that does not have a pilot light...and most newer stoves don't), you shouldn't have to light the oven manually (if you think you need to, you have a faulty stove). Manual ignition of a stove is also potentially dangerous as larger amounts of gas in the oven can cause small explosions. Most modern gas stoves use a very hot glowbar to both regulate the amount of gas entering the oven and igniting that gas. If you have a faulty glowbar, it will not allow enough gas to enter the oven and may not be hot enough to ignite the little gas that does enter (that is why you may smell gas). It sound like you may need to replace the glowbar (or visually inspect the glowbar to see if it gets red hot. If it does, it may still be faulty (not drawing enough power). The only way to test this is to use a clamp-on ampmeter and test the current flow through the wires feeding the glowbar. They should read between 3.1 and 3.7 amps. Anything lower means the glowbar should be replace. If you cannot see the glowbar get red hot, you have an electrical problem or a circuit board problem.
Jul 11, 2009 | Maytag CWG3600A Gas Single Oven
I have a whirlpool polara oven that kicks whenever
you can google sears appliance parts and order it from them I found them to be the cheapest for parts .they come out of canada. The error codes are mostly right and you probaly can do it yourself.
Apr 21, 2009 | Ovens
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
