Question about Dometic Rooftop RV Air Conditioner
How do you get in to clean the fan. we have mud dobber nest on the blade
  • Dometic Master
  • 6,674 Answers
Going to have to remove cover on roof. Will need to remove all Philips screws around near bottom. If you have/had wasps in there, take a real good look before you pull cover of, and try to do it on a cool, cloudy day, or at dusk, just in case there's more there. If you do it early in the morning, watch for slippery roof. Take a can of wasp/hornet blaster with you as it's not unusual to find more nests under that cover. Been there, done that, many times. Good Luck, keep me posted on results.
Posted on Jul 28, 2009
Fan is making loud noise. it is cooling
probably from the outside fan
check for leaves touching the fan blades or unbalance caused by a mud wasp nest on a bade ( back side of a blade )
Jun 11, 2016 | Amana Heating & Cooling
Sounds like fan is clicking on roof top dometic RV ac unit, but fan is not hitting anything.
check fan shaft and blade to make sure mud dober or mouse didn't build nest in there. if they did remove it and see if it works.
May 30, 2015 | Dometic Rooftop RV Air Conditioner
Engine won't start- I have changed gas, I have a good spark, and no air blockages
Put a nice new spark plug in the engine and clean the carb with carb cleaner. Spray some cleaner in the carb throat, and put some liquid carb cleaner in the fuel tank.
Mar 05, 2014 | Troy-Bilt Super Tomahawk Chipper Shredder...
2007 yamaha GP 1300R, spout not shooting water out
Make sure that the water intake is clear. I once had a mud dobber build a nest in my intake tube causing low flow.
May 28, 2012 | Water Sport
When i turn it on it shakes like something is loose. The shaft is straight,could the fan brackets be loose? ...
Could be, be also you need to check both fan blades. One could have a dirt dobber nest or something ellse on it. This will cause the motor to be off balance.
May 18, 2011 | Heating & Cooling
The AC in my RV works and cools but rattles the whole camper and is extremly noisey. I think it is either one or both of the fans. Are they replaceable?
You have something in or on the fan blade. If you live where there are dirt dobbers, they will build their nest right on the outside blade. You will need to take the cover off to inspect. Also, as for the inside blower wheel, it could have something sucked up into it throwing off balance.
May 13, 2011 | Dometic Rooftop RV Air Conditioner
Ryob1 BC30 won't run
Check your muffler screen in the exhaust ! I have seen carbon or mud dobber's build a nest in these and when cleaned fire right up and run ! If you need to adjust the carb passed the preset screw limits the a carb rebuild kit is likely!
Sep 17, 2009 | Craftsman 25cc Gas Line Trimmer
2 year old Charmglow 4 burner grill barely heating to 200 on high
check the burners for debris such as..... a mud dobbers nest/ spiders.
Mar 22, 2009 | Brinkmann Charmglow Stainless Steel LP...
Duo-therm a/c
We had this issue also and dirt daubers had built a nest on the end of the fan blade
Jul 28, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
151 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
