SOURCE: it is leaking muliple substances. one is red
The "Red" is transmission fluid, the "Clear" is most likely power steering fluid, or it could be "refrigerent oil" from the A/C. I don't know what could be leaking in the rear of the car maybe oil from one of the rear struts or maybe brake fluid. Do the brakes seem to work OK yet? If so it's probably not brake fluid. It could be condensation coming out of the muffler, there a weap hole in the muffler to allow excess water to run out. It might be picking up some color from the muffler. The transmission and the power steering are the biggest concerns you don't want to let the fluid level get low on either of those. If the transmission is leaking on the right side it's most likely the axel seal or maybe the pan gasket. Neither of these should be an expensive fix. But, you should get it to a shop and have it checked out. Try to find an independent shop instead of the dealer the independents are usually cheaper and do just as good of work. Get an estimate!!
SOURCE: The A/C does not get cold and I have an oily
your have a leak in your ac system.try to tighten the fittings on your system.most ac systems require a certified ac tech to stop leaks and repair problems.
SOURCE: oily substance leaking under dashboard of a 2000neon
could be antifreeze ,have a taste and if its sweet then it is most likely antifreeze ,if directly under the pedals then it could be brake fluid thses are the only two things that would leak under the dash on this vehicle that i can think of offhand
SOURCE: 1998 Isuzu rodeo running hot.
running hot.
do post all sighs of that. there are many,
is Rad full dead cold, with rad cap off? look there?
1: guage reads too high.
2: steam?
3: water blasting to side plastic side expansion tank.
4: engine pings.
5: loss of power,
6: water leaks.
7: water found at rugs of passengers toes. (below cab core)
8: that oil is tranny cooler leaking or something else.
9: oil found in top of rad cap hole floating on the water.
10: water found in engine, pan (on dipstick looks like milk chocolate)
11: water in transmission , same test, different stick.
12: running 50% antifreeze or just water.....?? latter dead wrong.
we test the % each each fall with a $2 tool.
13: did you let the engine sit out in sub freezing levels with no 50% AF?
14: are the fan belts tight.
15: did you replace the RAD cap.,
16: try a new thermostat? both cap and stat are easy cheap fixes.
17: do a RAD pressure leak down test yet?
18: is rad fan working
19: is rad core outside packed in junk,.
20: is A/c core (condensor) same, packed in junk.?
21: question, does it over heat moving or only parked or both?
and more, im tired
