Question about Dryers
Dryer has no heat.
Our older Maytag dryer runs but has no heat. Also, the overhead flourescent light goes off when the dryer is turned off or the dryer door is open. This has never happened before.
    President:
  • 1,922 Answers
Youve got an open circuit somewhere and its using another circuit to find ground
Posted on Jul 29, 2009
Electric dryer runs but no heat. all thermal and motor and heater element have continuity.
Dryer Diagnostic - Not Heating up - Repair ... - YouTube
? 11:16
https://www.youtube.com/watch?v=3Vns05qIjGs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your trusty Maytag Electric Dryer suffering from some of the ... However, in REGULAR mode, it runs normal too, but theheat stops ...
Maytag Dryer Not Heating - How to Test the Heater and ...
? 4:12
https://www.youtube.com/watch?v=_zjiZ0sbCgI
Oct 12, 2013 - Uploaded by Bill Newberry
How to test the heating element on a Maytag Dryer. If you Maytagdryer is running but not heating these are what you need to check. ... The dryer runs but does not heat. .... Not heating Maytag electric dryer - Duration: 19:38.
Not heating Maytag electric dryer - YouTube
Jan 13, 2016 | Maytag Dryers
I have a Maytag Neptune model number MDG9700A gas dryer...When I first turn the dryer on the dryer will get hot for about minute then the gas turns off and will not heat up again...It glows fine after...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 01, 2011 | Maytag Neptune MDG9700A Gas Dryer
Maytag dryer mug15pdaww won't light, the ignitor
heatman101
Jun 16, 2011 | Maytag Dryers
Admiral Gas dryer will start to heat when first turned on then goes cold. The dryer will not stop running but will not heat. Any help would be appreciated. Thank you Jason
heatman101';
May 27, 2011 | Maytag ADG7005AWW Gas Dryer
Our Maytag Neptune gas dryer is exhausting a natural gas odor now... This smell only occurs when it has been running for awhile and never when it's turned off. Also, it ONLY smells outside the house via...
The burner is not lighting right...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I have a older Maytag gas dryer DG612. The igniter comes on the gas lights, runs for about 5 seconds then shuts off. The process repets its self over and over again. It is trying to start but shuts off the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 16, 2010 | Maytag MDG7600AW Gas Dryer
My Maytag Alliance gas dryer won't heat up at all. The dryer keeps running due to the temperature not changing. There is no heat at all. I ran out of propane - the dryer stopped during the cycle, the...
heatman101
Sep 05, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Dryer Tunrs on and runs with no heat and timer never moves
heatman101
Aug 02, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
Magtag Dryer MDE2400 Dryer won't turn off
On our Maytag dryer, the looping marquee lights mean that the dryer is in "wrinkle" mode. This means that the wrinkle mode has been selected. In this mode, the dryer continues to rotate on and off after the heat cycle has ended. It does this to keep the clothes from wrinkling -- and it displays the looping lights.
Jul 24, 2009 | Maytag MDE2400A Electric Dryer
Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Jan 21, 2009 | Dryers
Dryers Logo
43 people viewed this question
Top Dryers Experts
