My PC-6re prints great when I'm printing single copies, one at a time. When I try to print 2 or more at a time I get a paper jam every time. I tried using the brush to clean out the orange groove, as described in the manual, but it still continues to jam. What can be done to correct this? Arthur Fishman arthurfishman@comcast.net
  • 4,472 Answers
Ok there are solutions out there you can buy to rejuvenate rollers. You can try to clean the pickup rollers first and that should help for a while or you will need to have them replaced. Being that one copy works I don't think its a sticky solenoid or the paper feed clutch. If the jams are happening after the paper feed on the right hand side of the copier you must remove the power supply assembly. They can get glazed over which then they need a cleaning or sanding a bit. These are common issues with the rollers due to use. Also here is a site with parts if you find any of them need replacing.
http://www.precisionroller.com/manufacturers/canon-pc6re.html
and here is the site for the rubber roller cleaner.
http://www.fixyourownprinter.com/specials/misc/chemicals/S03
You can also just try a little bit of water at first as well, and make sure they are dry always before using, as that may just get them dirtier then they were to begin with.If you have any other questions or need further assistance please let me know.
Thank you,
Lee
Posted on Jul 28, 2009
Samsung scx-4521f "paer jam 2"_ i've checked paper inside but i can't see any thing is jammed. if i turn off and on that time 1 paper will be printer ofter one same problem is repete. any advice sir
Sanjay,
I think you should take all unused papers out, close tray and predd print button. If there is paper in the system, it may come out. A red light may also flash asking you to load papers. Now lod the papers and the red light will go off. Put a printed paper and try copying. If it copies, you are ok. Now print from your cpmputer command. If it prints you are ok. If it does not and you get paper jam warning, there may be a small piece of paper stuck in the system. You have to open each feeder and see if you find anything. Good luck.
Jun 02, 2014 | Samsung SCX 4521F All-In-One Laser Printer
I have an imagerunner 2800 and it only seems to jam in the tray loading area, just bends the long side of the paper randomly. It changes it's performance just like the weather, sometimes I can get multiple...
A couple of things to consider:
Do not load the following types of paper in the paper drawer. Doing so may cause a paper jam.
- Severely curled or wrinkled paper
- Heavyweight paper
- Transparencies
- Paper on which color images have been copied.
- Paper which has been copied on using a digital full color copier (do not copy on the reverse side
either).
- Paper which has been printed on using a thermal transfer printer (do not copy on the reverse side
either).
Also, what # paper are you using?
Oct 12, 2013 | Canon (6981A002AA) for imagerunner 2200,...
My Sharp AL1530CS Copier is sick. I have a Sharp AL1530CS Copier. It has been great but has gotten sick. I replaced the AL110TD cartridge recently with a generic cartridge and toner leaked from it
Your machine is jamming (flashing p) because the toner that spilled has made the rollers slippery and they cant pull the paper out of the paper tray.
Apr 07, 2017 | Sharp Office Equipment & Supplies
We have a Ricoh Aficio CL3500N and every time we print the paper jams and we get the "Remove Misfeed A: Internal Path". I remove the jam and when it tries to print again we get the same thing,...
There may be an obstruction inside the printer. Try this....remove the paper from the paper tray and put paper in the handfeed tray (front of the machine) If it feeds from that tray it means that the feed rollers in the bottom cassette are worn.
Dec 17, 2010 | Ricoh Aficio CL3500N Laser Printer
I have an HP laserjet 1010. i got the paper jam
If you are getting correct test page without errors, simply unplug your printer's USB Connection from PC. uninstall Printer drivers and software. restart PC.. Re-Install New Copy of Drivers and Software.. THEN PLUG THE PRINTER USB CABLE TO PC.. try printing after proper driver is installed..
May 30, 2010 | HP LaserJet 1010 Printer
Continuous PAper jam error-message!!!
Sounds like a small piece of the jammed paper is stuck inside on a paper path switch OR in pulling out the jam you've dislocated a switch actuator so it is not working correctly. Careful checking of the paper path components should find it. Probably a slot in one of the guides is hiding it.
Jul 22, 2009 | HP Photosmart C5280 Printer
Paper Jamming when trying to copy or print
please check after you load paper on the paper tray and push it into the machine, should hear a click sound, if you don't hear that sound, that means you need to buy a new printer and that's no way to fix.
If you are able to hear a click, then please try to clean up your printer and check all paper loading rolls. if so, please replace it.
May 21, 2009 | Brother MFC 7420 All-In-One Laser Printer
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
Paper Jam every time I try to print
Where does the paper stop? Are there any sounds? Are there any marks on the paper? I need a little more information before I can help. Ed
May 31, 2007 | Brother IntelliFAX 4100 Laser Fax
jasbo
jasbo
