Question about Danby DKC645BLS Compact Beverage Cooler
Danby kegerator not cooling
I can't get my Danby DKC586BL to cool, my temp is reading 72 and when I push the temp setting it responds but nothing kicks on therefore the temp remains at 72. It's less than 2 years old but since I dont have a reciept Danby is being less than helpful
  • Clint Heard Jun 16, 2013
    I have the same unit, less tha two years old and it will not cool. the front digital readout seemd to be working as is is showing the right temp and will adjust. the compressor will not kick on. did the front panel solve your issue?
  • 4 Answers
I just had the same problem. Mine was outside on the patio and the key pad on the front was the problem. cost me $2.27 plus shipping and it took me 5 minutes to fix call Danby back and wait on the phone for their parts and tell them you need the keypad sticker. Good Luck
Posted on Aug 07, 2009
Did you try this and did it work? I too have the same issue.
Posted on Sep 17, 2010
Danby Kegerator runs but does not Cool
sounds like maybe no coolant in system if compressor is working. you know like in your car a/c unit, sometimes refrigerant needs to be added. just a guess, I'm not an expert.
Nov 08, 2012 | Danby DKC645BLS Compact Beverage Cooler
I've owned it for about a year and have not had any trouble. But my Danby Kegerator just started beeping and flashing EE on the display one day and it won't cool. I had to unplug it. Any ideas
An EE error code means that you have loose connections (loose temperature sensor connections) check all the wires for a loose connection
temperature touch pad
the units main control board
the control board is in the back of the unit there is a panel covering in the middle lower back near the compressorInside your unit on the left side in the lower rear theres a vented piece of plastic pry that off thats the temperature sensor make sure all the connections are tight
If the error does not clear then your temperature sensor is faulty
you can get a new sensor at
www.repaiclinic.com.or
or at
www.appliancepartspros.com
hope this helped
Good Luck!
May 01, 2012 | Danby DKC646BLS Full Size / Pony Beer Keg...
Kegerator is flashing "EE" and
I bought a new kegerator and the same thing happened right out of the box.
The display was not pluged in.take Take screws off top and check to see if it pluged in.
Nov 18, 2010 | Danby DKC645BLS Compact Beverage Cooler
I have a danby kegerator and i just tap the keg and all its doing is spitting air with some foam and i tasted the beer it was completly flat i need help asap!!!
try changing kegs sounds like the tube in the keg is broken the keg has a tube that runs to the bottom of the keg inside and u push air into the keg to push beer thru that tube and into a cool glass and down to ur gulletbut it sounds like u have a defective keg or an empty keg
Feb 24, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
Kegerator is on but not cold- dkc586bl
1 foot from the wall , unplug for 15 mins and plug back. satisfied , vote for me
Sep 16, 2009 | Refrigerators
Danby Kegerator is beeping and flashing EE and won't cool
I am having the same problem seeing if you found a fix??
Aug 26, 2009 | Danby DKC645BLS Compact Beverage Cooler
Temperature - Is fan supposed to constantly run or is it controlled by thermostat
You said ,Top half of Danby DKC645BLS refrigerator 10 degrees warmer than bottom half. Bottom half cooling to approx. 34 degrees.
Is it running all the time without cycling off and on as it should be doing?
Sorry to have to tell you this news.
But this would mean a bad thermostat or insufficient freon in the cooling system.
The same issue with the fact that one compartment is warm and the other is cool!
Let me know that service tells you!
Thank You
Huuum
Please remember toleave a rating
Oct 19, 2008 | Danby DKC645BLS Compact Beverage Cooler
Danby DKC645BLS Kegerator not keeping beer cold
insulate the tower with pipe insulation, there is a hole in the bottom of the tower. don't over insulate or it will freeze.
Aug 12, 2008 | Refrigerators
Temperature light control (kegerator DKC645BLS)
Not sure u have a problem.. all appliances dont HOLD a certain.. Temp.. They cycle.. come on for awhile reach a temp the shut down.. goes so low the comes back on... the middle of the cycle is the avarage temp... yours being 36 from what you posted
Sep 04, 2007 | Danby DKC645BLS Compact Beverage Cooler
Thermostat
It's the Danby "auto-defrost" feature. It cycles off every 24 hrs to defrost, at which time the temp rises (as the unit isn't running!). Not much you can do. By the way, the blue LED temp display isn't accurate. It NEVER gets 36 (liquid temp) inside the Danby unless you do the following: Open the door and look to the back left. There is a small grate covering the temp sensor. Remove the grate and place the sensor into a small cup of water. The sensor will now read the "liquid" temp inside the keg, and not the "air" temp. The Danby will then cool the inside to a more beer friendly temp, and should not only cut back on foam, but taste better.
Sep 03, 2007 | Danby DKC645BLS Compact Beverage Cooler
Danby DKC645BLS Compact Beverage Cooler Logo
2,744 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
