if latch closed use a screw driver and insert into latch ussh pull Handel as would to open and push latch back with screwdriver to open latch --if latch just flops back and forth latch damaged and will need repair or replacement
You will need to take inside door panel loose which is a little hard with door shut but it can be done and probably replace door Handel if the Handel it's self is not broke it's most likely just a little plastic clip that holds the rod to the lock
Disconnect negative battery terminal. Pull out inside door handel,then remove screws from behind it then pry out the door handel bezel.Pry upwards and out on the armrest switch control plate and disconnect electrical connections.Remove the door panel screws through the armrest opening .remove the screws from under the door pull handel as well.Pry out the interiory lamps mounted in the ends of the armrest and remove the panel screws from behind it. Also make sure there are no lamps hidden from view like under the armrest if so pry out lamp and remove panel screws from under it.Next start at the bottom of the door and trim panel and pry out each retaining clip. Clips are approximately 8 inches apart.Once all of the clips and screws are removed from the door panel it can be removed by gently lifting up and out on door panel.Ihope you find this helpfull,good luck.
How to remove a door panel, first u must open the door and unscrew the screw that is in the door handle then with a flat head screw driver unhook the plastic conectors to the cover of the handel becarfull not to pull to hard gently pull it as needed then pull the door handle as if opening and then pull the cover of handle out wards and then un detach the electric conector for the door locks then on the bottom handel unscrew the screw that is in the handle then pull out the case that holds it. then unscrew the screws that are on the inside towards the interior of the car there are two then two on the bottom then on the side that opens there should be on or two then pull the panel upwards and then towards your self you should be able to also detach the electric conector for the windows then when your done fixing it the instalation is reverse make sure that you conect the window and door lock conectores and make sure that the door falls in place with window latch. good luck buudy.
This is usually caused by a broke plastic retaining clip.the inside handel should have a insert covering a screw pop out the insert and remove the screw. If there is no rod atached to the handel (broke clip) locate the rod in the door (a metal coat hanger works good) pull on the rod towards the front of the door and it should open.Replace the clip or sometimes the handel itself breaks needing replaced.
remove vertical screws from arm rest. ther may be other screwscovered by plastic caps. pull small triangular cover at top near dash covering mirror mounting bolts. pop window and lock switches up and out of the door pannel and be carfull when removing electical connections from those switches. then pop plastic panel around inner door handel out and turn to free from handel. Now u can start to remove the door panel. U can by a special tool at your parts store to pop the clips on the inside of panel or just pull it off starting from the bottom and working yourwhay around the sides and up to the top. then push upwards from the bottlm and the top lip should pop free of the door.
hope this helps
using small hook tools and tack pullers shaped like mini wonder bars, you can remove the door panel. once removed, you can fish around on the bottom middle of the door and pull the cable to unlatch the door.
you need to push in on door panel at same time in between the door panel and Handel their is a horse shoe clip you will need a "Mechanics DENTAL PICK! to pull it out to release the crank Handel! most part stores will carry that tool!
