Question about Singer Sewing Machines
I keep getting the thread breakage message and there is no broken thread it is threaded correctly but it keeps saying that there is threas breakage can anyone help me this is for the futura 250
  • 55 Answers
Have you tried re-threading the machine, sometimes the thread can slip off the check spring for needle thread and cause a thread break message.
if you have re-threaded and cleaned the bobbin area (preferrably with compressed air) then most likely the thread break sensor is damaged and will require a tech to repair.
goodluck
scott.
Posted on Jul 28, 2009
Top thread keeps breaking and I do not think it is a bobbin issue. Thread seems to be getting snagged up in one of the upper threading spots. It has been professionally serviced many times.
Remove the top thread from the machine.
Install a brand new needle and confirm that the needle is correct for the thread and fabric you are sewing.
ALWAYS RAISE the presser foot and rethread from the beginning. Set the top tension to the midway point. Verify the thread path is correct.
When the presser foot is raised, the thread should pull through with very little resistance. Once the presser foot is lowered, the tension is activated and the thread should not pull through.
It could be the thread is catching a notch or groove. I have a machine that the thread has worn a sharp groove in the finish. I covered it with tape. Fixed.
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Does My Thread Keep Breaking While Sew
May 11, 2017 | Sewing Machines
Where are the oiling points and what would make the threads constantly break
Depends on your make & model machine. Newer computerized machines require little or no oiling. Consult your owner's manual AND use only good quality sewing machine oil.
Thread breakage:
#1--Avoid bargain bin variety and old thread!
Why Is My Thread Breaking How to Avoid Thread Breakage at Your Sewing...
Apr 07, 2017 | Sewing Machines
When sewing it skips stitches also the thread keeps breaking.
Remove the thread from the machine.
Install a brand new needle.
RAISE the presser foot and rethread the top thread.
Load and thread the bobbin case & install it. Verify it is correct.
Set the top tension at the midway point.
Re-test your stitch.
10 reasons for skipped stitches
Mar 22, 2017 | Sewing Machines
After threading the machine, start to sew and the thread breaks it seems that it gets caught in step 4 in Threading The Machine in the manual.
Not knowing the make & model of the machine limits out ability to help. What is Step 4? When threading the top thread, ALWAYS RAISE the presser foot. Verify that the thread path is correct--mis-threading is a frequent cause of broken thread.
Mar 16, 2017 | Sewing Machines
I have a Janome 1600P and the top thread keeos breaking
There are several common reasons for upper thread breakage.
Check that the needle/thread/fabric are compatible.
All About Needles
Remove the upper thread from the machine, install a brand new needle, ALWAYS RAISE the presser foot, and rethread from the beginning. Verify the thread path is correct. Set the upper tension to the midway point.
NMSU Checklist of Common Machine Troubles
Oct 29, 2016 | Janome Sewing Machines
Why the thread cracked with when i sticked with the machine
Thread breakage could occur for several reasons.
First, try a brand new needle.
Second, use only good quality thread--NOT old thread or bargain bin varieties.
Third, when threading the upper thread, be sure to ALWAYS RAISE the presser foot throughout the threading process.
Verify that the thread path is correct (consult the owner's manual). Incorrect threading will usually break the thread.
Check that the upper thread tension is set at the midway point between the high & low numbers.
Why Does My Top Thread Keep Breaking Sewing Machine
Aug 27, 2016 | Brother ES2000 Computerized Sewing Machine
Upper thread keeps braking
Usually thread breakage is a result of incorrect threading or the thread tension set too tight.
Remove the upper thread. RAISE the presser foot and rethread from the beginning (verify the threading sequence is correct).
Check that the tension is set at the midway point between the high and low numbers.
Retest. If still breaking, there are other less common problems (thread/needle incompatibility, burrs or knicks catching the thread, etc) that may be the cause. Check the following web sites:
Why is my thread breaking
Feb 11, 2016 | Brother Sewing Machines
My needle threads keep on breaking, I don't know what to do
  • Check the tension of the upper thread. If it's too tight, the pressure on the thread will cause it to break.
  • Check the thread you are using. If you're using two different kinds (one on top and one in the bobbin) that difference can cause the threads to break.
  • Are you using the proper thread for the job? Using a thin or light thread for sewing heavy fabric can lead to breakage.
  • Are you using the correct needle? Sewing knits with a sharp needle or sewing woven fabrics with a knit or ballpoint needle can also cause the thread to snap.
  • Is your machine threaded correctly? Incorrect threading can be another cause for thread breakage.
I hope this helps.
Mar 04, 2015 | Sewing Machines
My esante ese2 keeps telling me that I need to check if my upper threa is broken, but it's not! The tension is off but every time I try a different tension (I've tried them all) it just says the same...
I take it's a digital machine. Rethread it completely, bobbin too. look for any stray dust and threads that could be setting off the sensor
Sep 12, 2014 | Sewing Machines
I am trying to do letter embroidery on my Futura 350 and I keep getting constant error messages about thread breaking even when there is no visible sign of that. Also, the bobbin thread side is bunching...
Check out your threading with "Machine setup" Tutorial under Help submenu and whether the thread tension control on the front panel is set to "E".
P.S. The error message about thread breakage appears not only when the thread is really broken but if the sewing speed is not changing smoothly (for example if design is not optimised).
Oct 06, 2008 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
110 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
