Question about Metabo W14 150 ErgoD Angle Grinder
I want to know if it is legal to install a deadman switch on a grinder yourself with a light switch and a spring??
    Brigadier General:
  • 4,090 Answers
Well laws for occupational health and safety differ between Staes and countries. I cannot see that it would be illegal to place an inline DM switch, but due to the difficulty of holding it whilst working might be awkward. I would make it into a footplate switch, as that would be much easier to incorporate it into the work place and have it passed for safety. The switch type would have to be robust enough to take the pressure and the plate small enough to allow the switch to activate if the foot was moved or lost contact from just a small deviation.
To confirm legailoty contact an OH&S representative in your local area
Posted on Jul 28, 2009
Took my mr coffee burr apart a little spring fell out now the grinder doesnt work where dose the spring go
Im first wondering why u took a good grinder apart ??? could it be that it was working only intermittently ?? if that is so , im betting the little spring is either the spring that pushes the start switch back up when u let go (otherwise it would run forever) or it might be a motor brush holder tension spring , that's most likely why its working only intermittently the brushes are worn down and need replaced , a neet hack 4 this is to use electric drill brushes ! I found they fit and can be sourced from a well stocked hardware store !!
Dec 21, 2016 | Coffee Makers & Espresso Machines
I bought a Skil 9290-01 angle grinder and a spring that is between the on/off switch and the motor broke after about two months of use. It is a spiral spring with a semicircular loop on the end, not a...
I checked several sources and agree with you, they don't want end users to be able to repair the tool apparently. I have a toll free number for Skil that might help it is 1-877-754-5999. I also found the breakdown and they as you know don't really show any parts. They might even replace the tool for you under warranty or repair it.
Jun 19, 2011 | Skil 9290-01-RT 6 Amp 4-1/2" Angle Grinder
Dear Sir, We have few Metabo grinder I have some doubt about Dead man switch can you explain me what is the function of dead man switch. Regards Nitin
Hello, a dead man switch functions in this manner. As long as you hold the switch down the grinder functions, and as you know when you release it the grinder stops. This is a good safety feature in that if you drop the grinder of lose control of it, if the grinder stays running it could cause a lot of damage to material or your body. The switch can seem to be a pain when having to hold it down all the time, but it is a safety feature that can actually save your life in the case of you losing control of the unit.
Mar 13, 2011 | Metabo W10 150Quick Angle Grinder W10 150...
I have a Buffalo B-10CB(CH) bench grinder and the on/off switch has broken, it's a push/pull type. What can I replace it with to make it work safely?
You could connect the wires of the switch together inside and bypass the switch. Then I would connect in the power cable a switch rated for 1 hp. You can use surface mount electrical box, with two cable connectors (one for the cable going into the grinder, the other for the cable going to the male cord end of the cable. Install a 120 volt switch inside the box (similar to the light switch in the wall). Make sure that the switch is rated for 1 hp. I would install the switch under the bench, under the grinder.
Joe
Feb 28, 2011 | Baldor 1022w 10" Bench Grinder, 1 Hp,...
Dewalt dw 400 grinder is locked up
Two things come to mind. One the drive head (gear box) has failed. Remove the cover from the gear box and see what is going on in there. Second, do you know the button you push to lock the drive so can remove or install (tighten) a new wheel? Make sure it is releasing. Most of these are spring loaded and if that spring fails the lock mechanism can stay engaged. Hope this helps.
Jun 14, 2010 | Dewalt Small Angle Grinder 4 1/2"
Powerbase model no 830806 9'' angle grinder the switch has broken -hardly used can I get a spare switch or is it worth repairing
The switch can be repaired if you have the patience. There are four springs inside and some contacts, which should be cleaned. The small springs are place under the contacts and the large springs fit on the end of the metal blade that is attached to the switch button, and the other end of each spring fits on a plastic spigot on the inside of the smaller switch housing. The switch is best assembled on the trigger and the outer housing placed over it once everything is in place.
Like I said earlier, patience is the key!
Oct 13, 2009 | Saws
Dewalt dw474 grinder quit
you need new brushes. carbon is meant to be touching the armature not the contact from the spring. Its worn down
May 10, 2009 | Dewalt DW824 5" Electric Angle Grinder
Can't get grinder to turn on. Checked brushes, cord, trigger/switch. Any suggestions?
Did you check continuity to the field/brush holders. They have a garter spring that sometimes became overheated and broke. It seems like you have done everything else. Let me know
Feb 25, 2009 | Makita 9005B 5" Electric Angle Grinder
Braun KSM1 XXU coffee grinder stuck 'ON'
The little plastic piece is part of the spring tension for one motor brush. It has been re-installed. I no longer need any assistance.
Feb 20, 2008 | Braun KSM 2 Electric Blades Grinder
Metabo W14 150 ErgoD Angle Grinder Logo
111 people viewed this question
Top Metabo Saws Experts
Vernon Taylor
Spud Howell
JOHN LAPIER
Are you a Metabo Saw Expert? Answer questions, earn points and help others
