Question about Toshiba Satellite P100 Notebook
Pictures are all blurry
Im using hp 6535s and after changing battery setting all pics are now blurred ive reset ive restored and its still the same help me!
My pictures are coming out very blurry. How do I change this? Also is there a flash for the vivicam 5022?
The camera has a built-in flash...you can see it on the front of the camera. As for the blurry pics, set the camera on a firm surface and fire off a few shots...are the pics better? If so, then you are the cause of the blur because you move when you press the shutter button.
Oct 01, 2010 | Cameras
BLUR PICTURES
Memory cards don't cause blurry pics. Is your lens clean? Is the lens extending properly?
Jun 23, 2010 | Panasonic Lumix DMC-FX50 Digital Camera
All of a sudden everything is out of focus and very blurry, pictures and even through the view finder. we took a few pics tht turned out normal, set the camera down picked it up about 5-10 minutes later...
If the viewfinder is also blurry, it might be as simple as a smudge on the lens. Is the blur uniform and consistent on the pictures and in the viewfinder? Was there a curious dog nearby when you set the camera down?:)
Sep 20, 2009 | Sony Cameras
I have an I835 with blurred vision in the lcd screen. no matter how close or far the subject is its blurred
Remove the memory card. Reset the camera to default settings (Reset All in the Setup Menu). Don't worry, it won't erase any photos. Try taking a picture in a well-lit area at a moderate distance, with the camera resting on something to keep it still. If it still looks blurry, transfer to the computer and view it there. If that's not blurry, it's the LCD display. If it is, then it's the internal focusing system. Locate your receipt and call Polaroid for service.
Aug 06, 2009 | Polaroid i835 Digital Camera
Blurred images on the lcd screen and pics come out blurry
number 1,make sure you have lithium batteries,energizer prefered.2 put it on auto focus.3dont be too close on the object your trying to photograph,and 4 do not zoom in too close on object either.this should solve your problem,good luck,hope i helped
Apr 30, 2009 | Samsung S860 Digital Camera
Pics are blurry
Have you changed the settings in the camera? When are you getting this problem? Is it when you try to shoot in low light?Does it appear like the pictures are shaken or is it out of focus? If they are shaken, use a higher ISO to shoot. If it appears out of focus, first check the lens for some smears. Clean the lens with a clean dry cotton cloth.
Check if there is fungus on the lens (this appears like spider's web or crack marks). If there is fungus, or you are still getting pctures blurred, take it to an authorized service center.
May 07, 2008 | Olympus Camedia C-2020 Zoom Digital Camera
Pictures are blurred........... HELP
When you reboot your computer, hold down the "Delete" key. This should take you to a black screen and multiple options like "Safe Mode", etc. Choose "Last Known Good Configuration" then see if that helps.
If the pictures on the Internet are blurred, it's most likely due to a setting in your router/modem or web browser that is loading the page with minimal image quality and size to make browsing faster.
Mar 28, 2008 | E-Machines eMachines Desktop PC
Digital camera
you can try and adjust the contrast for that pictures. try also iso 300 for the picture to increase quality. downpoint is its size will increase. just explore the settings and try them all out. im sure you will find the perfect settings that you'll like
hope this helps.
fixya!
Jan 31, 2008 | Cameras
Blurry Pictures
Check that you have not got Macro set accidently.
If lighting level are low and the camera is selectinging a slow speed - reset to Apeture Priority -setting 'A' and and be very gentle with the release - the slightest movement will blur an image on long exposure.
Try these thing and if still introuble come back with more detail
Nov 11, 2007 | Panasonic Lumix DMC-FZ20 Digital Camera
Blurry pictures
try removing the battery and card wait for a minute then reinsert and operate. try tapping side by side, even jarring the unit makes wonder, but not to the extent of destroying your unit ha.. [;0)
Sep 07, 2007 | Casio Exilim EXZ75 Digital Camera
Toshiba Satellite P100 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
