Question about Sony Handycam DCR-TRV740 Digital Camcorder
My Sony camcorder DCR-TRV740 has an error code that comes up. I was told by a camera repair person that the problem is the battery on the memory board. How do I get to this battery to replace it?
  • 4 more comments
  • scarter1283 Jul 28, 2009
    C31:42
    When I answered you before, I was going on memory. Since then, I got the error code to come up, and it is C31:40. Does this make a difference?
    I'm sorry, but no go on this. More info. Everything seems to work without a cassette in the carriage. The carriage opens up and closes as it should. But when a cassette is in the carriage, it will not close, and when the cover is closed as far as it will go, against the carriage, this is when the error code shows up.
  • scarter1283 Jul 29, 2009
    Will someone please answer my first question. That battery is not going to last forever, even if the problem is not the battery now.
    The error code is C:31:40. The cassette carriage will not close with a cassette in it. It works fine without the cassette.
    You are the first one to mention a power reset. This camera does not have a "button" to press and hold. It simply has a Power select lever that selects the different functions when not in the "Off/charge" position.
    I did try holding the system 'reset' button in. But still no solution to the problem.
  • scarter1283 Jul 31, 2009
    No the camera is not under warrenty, and I fully believe that I am quite capable of changing a battery and while observing ESD practices to protect the circuity since I just retired from working as an Elect. Tech for 45 yrs.
  • 11,896 Answers
You will have to full dismantle the cam-corder, by removing all the screws. You will then have to find the batty pack and most likely have to use a soldering iron to remove it. After you have received your replacement, then reverse procedure.
You can purchase the part at any of these sites:
Camcorder
s.BizRate.com
ebay.com
Sony.PartStore.com
Posted on Jul 31, 2009
    President:
  • 2,185 Answers
What does the error say?
If you are referring to the battery on the memory board, it is advisable to take your camcorder in the nearest authorized service center by Sony as this can be sensitive to do-it-yourself.
If the camera is still under warranty, then the better.
Posted on Jul 30, 2009
  • virtualhost
    virtualhost Jul 31, 2009
    Can you tell me the error code?
  • 453 Answers
If I can have the error code you get on yuor camera I will be able to help you further.
Posted on Jul 29, 2009
  • Sai Kiran Camsarapalli Jul 29, 2009
    I would like to know if a power reset was done ?
    Else remove the battery. Remove the power cable remove the cassette and Press the power button for about 1 minuter and put everything back on and try turning on the camera.
Hi there
What is the error code and message that appears?
Posted on Jul 28, 2009
  • Anonymous Jul 28, 2009
    Thank you.
    This may sound strange, but the problem is not with the battery, but rather there is a component inside which is getting warm. As it is very sensitive to temperature, many people with error C31:42 for the Sony DCR-TRV740 have had success getting the unit to work by simply cooling it using a hairdryer.
    In most cases this always fixes the problem. I know it sounds crazy and completely unrelated, but what you need is a hairdryer which can blow warm and cold air. Please try the following:
    1. Open the video tape area
    2. Remove any tapes
    3. Use a hairdryer to blow warm air into the empty video tape compartment for about 20 seconds
    4. Now, switch the hairdryer to blow cool air into the same compartment for a further 30 seconds
    Try using the camera now (you may need to turn it off and on). In most cases it will fix the problem (as weird as it sounds!).
    Best regards
    nLinked, FixYa
    This has to be one of the strangest solutions I have ever dealt with! The the error you provided previously is fixed using the hairdryer method. The error you've just provided (C31:40) is actually fixed (and I know its another crazy one) by doing the following:
    1. Turn on the camera
    2. Remove the tape but leave the tape carriage open (ejected)
    3. When you get the error, give the camera 4 firm thumps on the base of the device with the bottom of your hand
    4. Place the tape back in and close the carriage
    5. It should work
    Just to be clear I am not being funny with these solutions (that would be unprofessional!). They are the weirdest I have come across yet but it should fix the issue. If it doesn't, please try the above method again, but this time turn off the camera when you get the error, and then hit the base with your hand 4 times firmly and turn it on again. Did it work?
    I would be very interested to hear how you get on.
    Best regards
    nLinked
Sony DCR-HC28E Camcorder tape won't eject
I\'ve got a Sony DCR-HC28E Camcorder power switch off position but it's turn on automatic when I put power AC adaptor in DC inlet and battery not charg
Dec 29, 2009 | Sony DCR-HC28E Camcorder
Sony dctrv250 error code C:31:23
I will forward a link to page where you can get more information regarding the issue.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C79466
Please try Power Resetting the Camcorder.
First, please turn OFF the Camcorder.
Then, remove the battery pack from the Camcorder.
Then, press and hold the POWER button on the Camcorder for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
Jul 10, 2009 | Sony Handycam DCR-TRV740 Digital Camcorder
Video camera not focusing
hi ! i Jasdeep working with superb broadcast equipments and maintenance as an service engineer where we need to service the camcorders and vtrs of sony.
you need to take it to the nearby service centre .
they will adjust the focus by adjustment remote commander and would not charge you more then their service charges . because nothing is needed to be change in the camcorder they will just put the data by remote commander.
Jun 25, 2009 | Sony Handycam DCR-TRV740 Digital Camcorder
How do I transfer 8mm & Hi8 tapes to DVD using my computer?
just go to this link:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRTRV740&SelectOS=7
download the usb driver for your camcorder. install. Set power switch to Camera or VCR. Select USB Stream to ON in the menu settings. then connect camcorder to pc.
Mar 31, 2009 | Sony Handycam DCR-TRV740 Digital Camcorder
Video camera displaying Error code C:31:23
I have been fighting the same problem. I just now picked up the camera and a small rubber roller fell out of the tape door area. I was not sure where it came from but looking closer there are 4 small rods sticking up on the right side inside the area where the tape is located. It looked like this was where the roller went so I placed it on the center rod and replaced the tape. This solved the problem and I am now able to view and recored as before. There most likely is a part that has either fell or broken off or is loose inside the tape area.
Feb 17, 2008 | Sony Handycam DCR-TRV740 Digital Camcorder
Sony error code
cheak batteries and the tape your using
Feb 03, 2008 | Sony Handycam DCR-DVD305 DVD Camcorder
Error code sony dcr trv25 c:31:23
Sony says the unit needs a power reset (error 31). Unplug the camera, remove the battery and wait several minutes before re-attaching the battery and/or AC cable. Then power the camera back up. The 23 code says you need to use a InfoLithium battery-- apparently these are smart batteries that give data back to the camera. These error codes seem to be quite common however, and so a hardware issue may be the case. Some users have said that removing the battery while the camera is powered on will clear the codes. Others advocate "smacking" the camera, I would not however, recommend this. www.sony.com is a good place to look for more information.
Nov 19, 2007 | Sony Handycam DCR-TRV80 Mini DV Digital...
Black lcd
Previous 1 2 3 4 5 Next Notice to Owners of Sony Camcorder October 3, 2005
Thank you for your support and patronage of Sony Camcorders.
It has recently come to our attention that a limited number of Sony Camcorders that incorporate an image sensor device, CCD Chip, manufactured from October 2002 through March 2004 may exhibit the following condition:
When the Camcorder is used in camera mode, the LCD panel and/or electronic viewfinder will show either a distorted image or no image.
We have determined that this condition only occurs to a limited number of units.
In its effort to ensure customer satisfaction, Sony has elected to offer a free repair to the owners of applicable Camcorders if the image sensor device, CCD chip, causes one of the above-mentioned conditions. Accordingly, customers who have a Sony Camcorder as outlined below and if such Sony Camcorder exhibits the above-mentioned condition caused by the image sensor device, CCD chip, may contact the special call center number below for free repair:
CCD-TRV108E
CCD-TRV208E
CCD-TRV218E
CCD-TRV228E
CCD-TRV418E
CCD-TRV428E
DCR-DVD100E
DCR-DVD101E
DCR-DVD200E
DCR-DVD91E
DCR-HC14E
DCR-HC15E
DCR-HC16E
DCR-HC18E
DCR-HC20E
DCR-HC30E
DCR-IP45E
DCR-IP55E
DCR-IP5E
DCR-IP7E
DCR-PC101E
DCR-PC103E
DCR-PC104E
DCR-PC105E
DCR-PC106E
DCR-PC107E
DCR-PC115E
DCR-PC120E
DCR-TRV12E
DCR-TRV145E
DCR-TRV147E
DCR-TRV14E
DCR-TRV16E
DCR-TRV18E
DCR-TRV19E
DCR-TRV22E
DCR-TRV238E
DCR-TRV239E
DCR-TRV240E
DCR-TRV245E
DCR-TRV24E
DCR-TRV250E
DCR-TRV255E
DCR-TRV25E
DCR-TRV265E
DCR-TRV27E
DCR-TRV33E
DCR-TRV340E
DCR-TRV40E
DCR-TRV460E
DCR-TRV50E
DCR-TRV738E
DCR-TRV740E
DCR-TRV940E
DCR-TRV950E
DCR-VX2000E
DCR-VX2100E
Please Call
UK - 08705 143480
Eire - 021 434 8993
Note: If the fault is not the CCD chip, then normal Sony Central Services charges apply (please call for details).
We apologise for any inconvenience caused and we thank you for your understanding of this situation.
Sincerely,
Sony
Private information control policy
Personal information, such as your name and/or mailing address, provided to the contact above will be kept and used only for the free repair service. The information will be strictly controlled and will not be used for any other purposes.
May 16, 2007 | Sony Handycam DCR-HC30 Mini DV Digital...
DCR-TRV740 handycam
heads are dirty , tension may be a little low. worth having Video Tech service in sacramento look at it.
May 28, 2007 | Sony Handycam DCR-TRV740 Digital Camcorder
Sony Handycam DCR-TRV740 Digital Camcorder Logo
132 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
