Question about Nikon Action Binoculars
The rocker adjusting lever does not move the eye pieces . What does it take to fix them? I can remove the entire eyepiece section anf if remove the pivet cap I can see there is nothing in the "tube to move the eye piece. Also it looks like there is a pin sheared off on the eye piece "axle" fittting in under the rocker lover.
  • 43 Answers
When you remove the eyepiece assembly and look at that "sheared pin" you will see it is actually screwed into the shaft.
If you can grab it with a pair of long nosed pliers and unscrew it then a simple self tapping screw with a head of similar diameter to the original screw can be screwed in once you have replaced the assembly. This will enable the focus to work once more.
Posted on Mar 02, 2010
  • 112 Answers
Sounds like its a dead duck ?
Posted on Aug 06, 2009
My left eyepiece on my Zhumell 20X80 will not turn to allow me to focus it. The right one works just fine. I don't want to force the left eye piece. Is there a locking mechanism I'm not aware of? Is this...
Typically the left eye piece is not adjustable. You focus the left eye with the center adjustment and then focus the right eye with the eye piece adjuster. I hope this helps.
Dec 12, 2010 | Zhumell SuperGiant Astronomical Binocular
I was wondering about the calibrations in the center between the eye pieces' and how they are used
It's there to help you set the binoculars quickly to your own inter-pupillary distance. Just make a note of the number the pointer on the scale is at when you find a comfortable setting for your eyes and then when you next use them just set the pointer back to the same number. The scale is the angle of the yoke, and you'll often (but not always) find that the scale works on other makes and models as well to help you quickly set the binoculars up to your own preferences. The left eyepiece will also have a dioptre scale (not always accurate) so when you have sharp right eye focus, adjust the left eyepiece until you get sharp left eye focus as well.The scale on the eyepiece indicates how many dioptres (+/-) your left eye is different to your right eye. If you know the left eye setting and the yoke angle, you can quickly adjust most binos to your own comfort settings. Fixed focus binoculars are different in that they have dioptre adjustment on both eyepieces, so left eye settings from regular binos are not directly useful on fixed focus binos, but the yoke angle may still apply.
Sep 01, 2010 | Bausch and Lomb Legacy 12-1056 Binocular
The diopter setting eyepiece has come out of the body of my Bushnell 10X42 ''Waterproof'' binoculars, model 13-2410. I see keyways inside, but cannot screw it back in more than about 1/4 turn, which is...
The entire diopter setting eyepiece was off.I separated the eye cup from the rest of the diopter setting eyepiece, and aligned the channel guides on the lens piece to slide it into place. Then holding it in place, taking care not to gum up the lens, I experimented with how to screw in the retainer ring so that its white dot registered correctly. Finally reattach the eye cup and focus. It's like new!
Apr 10, 2010 | Bushnell Waterproof Binoculars
Seeing double when I look with both eyes. Out of
Step 1.
Adjust the eyepiece or both if both are adjustable back to zero. It should be printed on there. If it's not, then halfway. To find halfway turn them to one end, count the number of turns like 1 and a half turns for example, and then half that atnd turn it that ammount. You've now reset the binoculars to zero.
Step 2.
Now to focus. Pick your target that you want to look at thoguh your binoculars. Look through the binoculars and close the eye with the adjustable eyepiece or your right eye if both are eadjustable and focus the image on the left eye with the central focus knob. Once you've got it focused close the left eye, open the right eye and if it's not in focus adjust the EYEPIECE focus, not the central one, until it's in focus.
If you can't get it in focus because the eyepiece focus won't turn far enough in one direction, turn the OTHER eyepiece in the opposite direction at max, start the process again from step 2.
If it's all ok now you need to adjust the distance between the eyepieces. Open the binoculars as far as they go, look through the binoculars with both eyes on the target and move the binoculars inward slowly until you remove any black edges around the image, then move them very slowly inward until you see only one image.
If you've got more problems come back as ask. :-)
Nov 27, 2009 | Vector Audubon 8x42 Binoculars
I'M MISSING THE ENTIRE EYE PIECE ASSEMBLY FOR 525 POWER TELESCOPE
You will NOT get 525 power from that small telescope. Yes I know the box said that but it was a lie.
An eyepiece might cost as much as you paid for the entire telescope. NEVER buy a telescope that advertises magnification on the outside of the box.
Here are some eyepieces:
http://www.agenaastro.com/Eyepiece-Size-s/128.htm
Sep 19, 2009 | Edu-Science (10166) Telescope
How to focus my Zeiss 10x40B TP binoculars
Your binoculars are known as the Zeiss Classic or what was once known as the Dialyt. They focus differently from the usual binoculars like those mentioned. The rear wheel is to focus both binocular barrels while using them. The front focus wheel is adjust the right eyepiece to suit your right eye. Binocular manufacturers take into account each eye is slightly different. To focus the Dialyt...First close your right eye and turn the rear wheel until the image is sharp in the left barrel. Leave the focus wheel alone. Now close left eye and adjust the front wheel until the image is sharp for your right eye. The image should now be clear and in focus for both eyes. It should not be needed to use the front wheel from now on. The rear wheel is what you will use to change the focus from near to far objects.
May 31, 2009 | Zeiss Classic B/GA 524013 Binocular
Insta-Focus focusing problem
first open and close the binoculars untill they fit you eye width,now adjust left eye with the flat section located on the center hinge,now turn right eyepiece till clear. note: once you have adjusted right eyepiece you only have to leave it in that position in order to focus from near and far.........good luck......larry@reichinstruments.com
Nov 24, 2008 | Bushnell "Insta-Focus" Binoculars
Cant see out of 49114500 telescope
You're on the right track since you can see something with the large eyepiece. The smaller ones will work the same basic way, but only for objects that are farther away. When you use a smaller eyepiece, the magnification goes up, and usually, the higher power eyepieces may not work for close objects.
Try looking thru the middle size eyepiece at a very distant big object, that is much further away, like at least 1/4 or 1/2 mile, in daytime. Try adjusting thru the entire adjustment range slowly, and at some point, you should see the image appear, and sharpen up.
The middle eyepiece will be typically be harder to focus easily, since the focus range is smaller. Likewise, the smallest eyepiece will be even touchier, but its the same process. Just turn the adjustment knob slowly.
It also helps sometimes to hang a weight like a book from the center of the telescope or tripod to help stabilize everything.
All of this will be easier in the daytime first to get practise, and to learn how careful you have to be. Good Luck.
Dec 27, 2007 | Bausch and Lomb Professional 200 (200 x...
Nikon Action Binoculars Logo
105 people viewed this question
Top Nikon Optics Experts
Mark Campeau
Level 1 Expert
Are you a Nikon Optic Expert? Answer questions, earn points and help others
