SOURCE: tempature on fridge won't stay @ 38
might be freezing on the evaporator faulty defrost timer or drain is blocked water should run down back bottom tray
SOURCE: Zanussi Tumble Dryer
Sounds like the condense pump is bad. Replace it, or look if there is lint in it. ;)
SOURCE: Can you Help?
Check your blower inside the unit, blower frame may be deformed causing the blower to touch the frame make some noise.
SOURCE: Zanussi TC 7114 W Condenser dryer leaking water
Maybe it's the water collector's upper side which leaks...
