Question about Yamaha 12V Air Pump
YAMAHA FX 1100 HO 2006 ROUGH IDLE WAVERUNNER
Can anyone let me know what the idle speed should be? I am getting mixed imput, is it 800 to 1000 or 1500? Please help befor I spend good money. The ski runs great otherwise. I think it is one of the best skis out there today.
I have a Yamaha fx 1100 that starts real slowly the battery is fully charged but the bike sounds like its not got alot of power going to the starter can anyone help solve this also battery terminals are clean and not corroded
Posted on Jun 30, 2010
    President:
  • 1,124 Answers
Right around 1000 (give or take is ok)..
Dose not have to be exact.. 1500 is on the high side..
Posted on Jul 28, 2009
Saw will start but will not idle
Someplace near the carburetor should be an idle mix screw and an idle speed screw. There may also be a high-speed mix screw. Try turning the idle speed screw in 1/4-turn at a time until it idles. If you turn it too far, the clutch will always be engaged so the blade will never stop.
Once you get it to idle, adjust the idle mix screw in or out 1/4-turn at a time until it idles at the highest speed. Turn the mix screw in JUST until the idle speed starts to drop a little, then back it out 1/4 turn.
Now adjust the idle speed screw again until it idles smoothly at a low enough speed that the blade stops.
Jul 08, 2014 | Husqvarna Partner Gas Powered Cut Off Saw...
Yamaha 1100 2006 v star engine will not idle
Hi, Anonymous and the usual suspects are:
1. Idle speed improperly adjusted.
2. Air fuel mixture screws not properly adjusted.
3. Inlet system air leak.
4. Leaking accelerator pump.
5. Loose low-speed jet.
6. Plugged low-speed jet.
7. Contaminated or plugged low-speed circuit.
8. Enrichner valve/choke not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have a nice day.
2004 Vstar idle only on full choke problem
2003 Star 1100 Custom won idle without choke aftermarket exhaust
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
OEM parts for Yamaha
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarOwner%20Manual.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 29, 2014 | 2006 Yamaha V Star 1100 Classic
Runs but will not get up to speed. When you first give it throttle it will take off fine, at first, then it bogs down to rough idle if not shutoff.
have you got any water in the fuel tank ?? very basic ski 2cyl 2stroke ! i recomend stripping the carbs and clean and check the diaphams have not gone hard also ! dont try and run it to clear the problem because if one carb shuts off the fuel feed then you will melt a piston !! then boo hoo no more play time !
Apr 02, 2014 | Yamaha 2004 WaveRunner XLT 800
2004 waverunner fx cruiser, ran great last time out. Now hard to start and wont run on high speed. Nothing over 6 mph.
How old is the fuel? Ethanol causes major problems if left too long. You may need to empty the fuel and clean out the fuel system. Try changing the fuel filter and adding some seafoam to the fuel and running seafoam thru the fuel system. Hopoe this helps.
Mar 15, 2014 | Covercraft UltraTech Custom PWC Jet Ski...
Yamaha waverunner won't idle and losing power
L stands for limp mode
it is a mode that the ECM selects to prevent serious damage to the engine ( from you lack of oil )
have the fault codes read then reset with the scan tool
Mar 31, 2017 | Water Sport
I have a 1994 nissan altima that has a rough idle, loses power
Before you start buying new parts, I have two suggestions. First, have the computer scanned for diagnostic trouble codes. Any fault codes that relate to your problem should be investigated.
Second, spend the money for a compression test of the engine. What you are describing could very well be a bad exhaust valve that leaks and causes high gas consumption, loss of power, poor idle, etc. A compression test will verify if there is such a problem, or not. And, if it turns out that compression is good and high and even in all cylinders, you will have peace of mind knowing the internal condition of your engine is fine, and you will have no problem with putting money in it to get it running right again.
Jun 17, 2012 | Subaru Legacy Cars & Trucks
Got high emissions on my x reg 1.8 sel passat first fast idle test was0.621% got to be 0.300% and on the second fast idle test was 0.606% also on the natural idle test was 3.494% got to be 0.500% can...
At www.reliable-store.com get complete guide on whether to repair or not, service it, and how to repair etc, along with wiring diagrams, electrical diagrams, torque specs, error codes, everything.
Mar 01, 2018 | 1999 Volkswagen Passat
First I replaced the pipes on my 06 650 yamaha v star custom with V&H cruzers. I then re-jetted the carbs. Now I can't get a low idle. I checked and adjusted the float level. replaced the pilot jet (#...
FIRST, YOU DIDN'T NEED TO REJET THE CARBS. I WOULD PUT THE STOCK JETS BACK IN IT WILL RUN JUST FINE. YOU NEED TO HAVE IT RUN ON AN EGA MACHINE TO TUNE IT PROPERLY.
Nov 09, 2010 | 2006 Yamaha V Star Custom
2004 fx CRUISER ho WAVERUNNER DOESNT WANT TO IDLE OR RUN AT TOP S
did you mean 900 cause 9000 is overrived and the engine may be blown
Jul 08, 2010 | Boating
Yamaha 12V Air Pump Logo
1,974 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
