Question about Eureka 2596A Upright Wet/Dry Vacuum
Water leaks out of Eureka Atlantis Steam cleaner...
As soon as I place the water tank into the machine it leaks ( pours) all over the floor. I'm wondering if I'm missing a rubber valve in the bottom of the machine, where the water tank sits? There is a black rubber washer/valve in the bottom of the soap dispenser section, but not in the water section. In the water section, it is just a pin that the tank fits onto that triggers the value to release the water.
Does anyone have a parts doagram that shows this?
Thanks for any help! :)
  • 161 Answers
SOURCE: need replacement for shampoo bottle on eureka atlantis
I googled Eureka Vacuum Parts and found 1-888-209-8113 svcvacuum.com (USA only)
Posted on Dec 23, 2008
SOURCE: No suction or spray - Eureka Atlantis Steam Cleaner
I got the machine working. I think because it hadn't been used for awhile that the seals were dried out. I wet them and let it sit for awhile and then I could push the containers all the way in and seated them properly. Then it started working no problem and I got to clean my carpets.
Posted on Oct 06, 2009
renevacdoc
  • 84 Answers
SOURCE: I need an upper handle release for my Eureka
i have a vacuum shop in albuq, n.m. and i have a used atlantis release handle if you are close or you would like me to ship it to you , thanks Don the Vacuum Doctor
Posted on Nov 06, 2009
  • 100 Answers
SOURCE: My eureka atlantis 2590 deep steam extractor will
is the spray pump making a noise? if so, clean spray jets with a lime/calcium remover like "clr."
If the pump isn't making noise, try the rest fuse button.
If that's not it, your pump motor or solenoid is toast.
Posted on Sep 28, 2010
  • 11800 Answers
SOURCE: Eureka Atlantis 2591A No
No suction means that the motor for the fan isn't working. You must dismantle it to access the motor and find out if it's powered. If it's not then you must check the connectors and the start button. If they are ok then the motor itself has failed. In that case you can throw the entire vacuum away, a new motor will cost you as much as a new unit.
Posted on Dec 13, 2010
Where can i get the shampoo? Can i find the owners manual online?
you should be able to get the shampoo at wal-mart and any place else they sell the steam cleaners. You do not have to use the eureka shampoo for this unit, however, it is more recommended.
I mean you can use the hoover, and dirt devil shampoo if you can find that, or something generic. Because the machine is mixing the soap for you with the water, anything will work.
As for the owners manual, you can get it here.
Nov 19, 2010 | Eureka Atlantis 2595A Upright Wet/Dry...
My Eureka Deluxe Enviro Steamer doesn't steam, I had no directions with it so I'm not sure how much water to put in it. It comes out the bottom before it heats up sometimes.It never seems to get hot...
You will need to pour two measures of water using the measuring cup or 12 oz of water. The reason why water comes out of the bottom is because the floor cloth is too wet or you had too much water in the tank
Click on the link below to view the owners manual:
http://www.eureka.com/service/manuals/70359.pdf
Jun 22, 2010 | Eureka Deluxe Enviro Steamer Vacuum
Oct 05, 2009 | Eureka Atlantis 2591A Upright Steam Vacuum
Eureka Atlantis 2590 Deep Steam Extractor will not spray
I cannot find a shampoo canister for my Eureka 2590 Series extractor. They are not made anymore.
Jun 07, 2009 | Eureka Atlantis 2590A Wet/Dry Vacuum
Need replacement for shampoo bottle on eureka atlantis
Nov 16, 2008 | Eureka Atlantis 2595A Upright Wet/Dry...
Leaking
Could be that the despensing tank has melted and deformed at the connection point. This is what happened to me when I put in really hot tap water. The heat allowed the connection (where the water/soap outlet is) to deform when using it. Now when I fill the tank and place it in the machine the water just leaks out all over the place with no control.
If you look at the bottom of your tank, where the water comes out, you may be able to see that the plastic is mis-shaped or deformed slightly. It probably doesn't take much for the seal to be broken.
TEA
Sep 22, 2008 | Eureka Atlantis 2591A Upright Steam Vacuum
if it drips out while the tank is off the machine it couldbe the spring load mechanism in the cap. try soaking it in hot water for a few minutes to swell the rubber then with a pen push the spring plate up and down to lubricate the rubber. then try and see if that works. usually they are gravity fed systems but only works when the tank is in the unit.
Jun 08, 2008 | Eureka Atlantis 2591A Upright Steam Vacuum
Eureka Atlantis 2591A Extractor - Won't spray
Hard to say without seeing it, is there a function type knob that you would switch from carpet to hose? Did the hose attachment lid close ok? Other then take, if this is new, it has a years warranty on it, just take it to a waranty shop for repair.
Apr 20, 2008 | Eureka Atlantis 2591A Upright Steam Vacuum
Leaking Carper Shampooer
I have an Eureka Atlantis Deep Steam Extractor and it does the same thing. It's not new but it hasn't been used much.
The manual says to "push the tank in until it snaps into place". Everything looks fine across the board so I believe this particular model is just a bad design overall.
My recomendation: Get a new carpet cleaner from Target or Wal-Mart.
Please let me know if this helps. Good luck!
Feb 28, 2008 | Eureka Atlantis 2595A Upright Wet/Dry...
EEureka Atlantis 2595A Upright Wet/Dry
I have an Eureka Atlantis Deep Steam Extractor and it does the same thing. It's not new but it hasn't been used much. The only thing the booksays is to put the tank in until it snaps into place. (Like we didn'ttry that.) Apparently it's a bad design. The seal on mine looks fine.
If I was doing the floor I'd just keep going but I'm trying to do my couches and I don't need a huge puddle on the floor.
Nov 04, 2007 | Eureka Atlantis 2595A Upright Wet/Dry...
Eureka 2596A Upright Wet/Dry Vacuum Logo
294 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
