SOURCE: Amana stove stuck in 'lock' mode, door won't open
try hitting cancel is it displaying any error codes like e2 f3 try turning the breaker for five seconds then back on
SOURCE: What does F-1 mean on the electronic display of stove?
F1 is a failed thermistor control in the control board. Board must be replaced to fix. Part is in vicinity of $120.00
SOURCE: Kitchenaid gas/convection stove oven door locked & won't open
F5 - E7
Self clean latch will not unlock
Remedy:
1. If door latched:
2. If door not latched:
3. Measure door switch (door open = switch open small low voltage
terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light
contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control.
Press and hold any key for 1 minute to clear R failure code from memory.
F2 will appear. Press CANCEL and observe for 1 minute to ensure
operation is correct.
6. If failure remains, disconnect power and replace control.
Note: Applies to all F5-E... codes.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: I am going to buy a new free standing self cleaning stove.
Remember this is a new feature and not sure of how it is going to work. I do know that if you have a problem down the line the repairs will be costly. Hope this helps.
SOURCE: Country Stoves Firestar, free standing gas stove.
needs to have the thermal pile cleaned I have to do this once a year
