Question about HP Color LaserJet 2600n Printer
Paper jam--cannot figure out how to extract paper.
  • 44 Answers
Here is a link to the manual, click on problem solving, clearing jams, there is a section on where to locate jams. It has pictures of locations.
http://cob.fsu.edu/tech/printermanuals/laserprinters/HPLJ2600n.pdf
Regards,
Paig
Posted on Jul 31, 2009
  • pat gilmartin Aug 02, 2009
    apologies to RYAN who already posted the correct solution first.i did not realised this.
    Sergeant:
  • 336 Answers
Okay, I have attached a link for the users guide to your printer. Once it is open go to problem solving, then clearing jams. That should help you. If you still need assistance I would suggest that you call HP, and they will help you.
Thank You,
Ryan Frame
Creative Energy Associates Technical Center
Posted on Jul 28, 2009
Paper Jammed
I have had the paper jam in my shredder which was not a Fellowes. I removed the power plug from the wall and used old dentist tools to pick the pieces of paper out of the shredding mechanism from underneath. I did not need to remove the cover. After extracting some paper try using the paper reverse option.
Apr 02, 2014 | Fellowes P70CM Shredder
How are you? My name's Richard Park. I put some paper into paper tray and click "ok" for printing.After arranging the printer, when it starts and slide in paper along the tray. But it has...
People, please use the correct product category, and provide the brand and model number of whatever device has you asking for help!
I deduce this is some sort of printer, but I can't figure out where the CD/DVD COPY comes from; I never heard of a printer that also copies optical disks.
Assuming it is conventional paper printer, there is probably a shred of paper stuck inside the printer from a previous jam. It isn't in a paper jam sensor, since the printer doesn't detect it. When the new sheet of paper goes in, it gets bent over by the paper shred and jams. You should be able to figure out just where the offending piece is by carefully noting how far the sheet went before it was stopped, and examining the folded-over part to identify how far from the edge of the paper path the foreign object is located. You may have to use a dental pick to extract the shred, paper clip or whatever it is. Be patient and be careful not to break anything. If the problem is a paper shred, you may have to tear it apart and pull it out in pieces because it is probably all bunched up and stuffed in tightly. If in doubt, consider partially disassembling the printer to get at the problem area.
Nov 04, 2010 | Computers & Internet
Paper jam in back, accordian fashion, cannot extract lexmark e328
There might be a access door in the back of the printer, remove the door and gently pull the paper out.
May 26, 2010 | Lexmark E322 Laser Printer
My brother mfc 465cn keeps saying paper jam. I do
The paper sensor is either stuck or dirty.
Just open it and follow the paper path and you should see where it is.
Otherwise, the sensor may be bad.
Apr 18, 2010 | Brother MFC-465CN InkJet Printer
Canon PC 941 copier. Paper jam indicated with no paper.
Can be that sensor of the passing of the paper or was broken off flag, or sensor has wedged in position james, more often such can be in block of the fastening, when paper stuck extract. Try its see, this possible behind do. Good luck
Sep 04, 2009 | Office Equipment & Supplies
Paper Jam
Have you opened the back cover to see if you could extract the paper there?
Have you removed the paper tray, and attempted to extract the paper from the bottom side of the unit?
Apr 26, 2008 | Brother HL 1440 Laser Printer
Piece of paper 1 inch by 2 inches jammmed and won't eject when I touch start button. I can't even see it with the cover open.
you have to open up your printer covers to extract that jammed paper. However, if you haven't tried tinkering with anything electronic before you will have to seek technical assistance from a qualified expert, but if you're willing and determined to extract that piece of paper, i suggest first you unplug any power connection from your printer, then unscrew the visible screws of the cover which is nearest the jammed piece of paper. never turn any cylinder if it resists your effort, however, try to manually turn cylinders where that small piece of paper is wedged until it comes off. Try to pull down on that piece of paper using a hair puller or forcep.
Apr 01, 2008 | Computers & Internet
Horrid paper jamming issue on left side
if you have time you cant take out the fusing unit there is a 1 or 2 sensors and solenoids, whats not working correctly. install them correctly and should work
Oct 12, 2007 | Konica Minolta magicolor 2430 DL Laser...
Paper Jam in OKI B4300 Led Printer
This printer is designed with a dual toner/drum chamber. Do not separate these two parts. Upon opening the lid, you will find the toner/drum assembly right in front of you. Pick it up with both hands and pull straight up. After that, you should be able to take the jammed papers. Know this: once a paper is jammed, printing another paper will NEVER take the first out. Just make sure to remove the complete papers. If they break, make sure you extract all the pieces.
Aug 22, 2007 | OKI B4300 Led Printer
HP Color LaserJet 2600n Printer Logo
313 people viewed this question
Seeker5211
Seeker5211
