Question about Kenmore Refrigerators
Have Kenmore model 106.8609380 serial E01427191. It has an intermittent problem. It still cools great, so I still keep it around. I check its operation once or twice a day to make sure it is working. Sometimes I find it not running (the light is still functioning) and I physically ''thump'' the front of the icemaker with my fist, and it kicks on the compressor. There is a plug/receptacle from the icemaker to the cabinet that I figured is loose. I have checked it several timess, looking for a loose connection, but don't see any problem. It will run normally for days sometimes with no issues. Other times, it has to be thumped 2x a day or more to make it kick on.
    President:
  • 1,723 Answers
This is going to be a loose connection, that you already know. The trick is finding it! It will require a bit of time to get into the back and get to the compressor unit and check the connections there. You need to go through the connections and check every where you can get to. The thermostat and all the connections in all the locations you can get to.
Take the time to turn the wire nuts that have wire in them. Give them the 'tug test', pull on the wire and make sure they don't come out. Start right where the power cord comes into the back. You may want to unplug while you do this.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Aug 25, 2009
I have a Kenmore gas dryer purchased in 1989 which shuts off half-way through the cycle. This is a heavy duty, soft heat unit, model #110 87874800 serial #MX0816640.
Your motor is overheating and shutting off on the limit switch. You should check the vent hose, it needs thorough cleaning. Also, you must take the front panel off and vacuum the inside of the dryer and around the motor. It may be too late for the motor but you have a chance. If you have an air compressor, it is best to blow high pressure air into the motor to get thorough cleaning.
keeping the vent and inside of the dryer clean can reduce drying time by more than 50% and operating cost by as much as $20.00 per month
Oct 13, 2015 | Kenmore Dryers
Kenmore model 721 850 the cooling fan doesn't run all the time
This could be due to a intermittent micro switch, or a faulty cooling fan. This is critical in keeping the magnetron cool when cooking.
Apr 04, 2012 | Kenmore Microwave Ovens
Kenmore refrigerator 598586 intermittent cooling. when not cooling only condensor fan runs. evap motor has been replaced by service company same problem. thanks
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 16, 2010 | Kenmore 58522 Side by Side Refrigerator
I have a Kenmore refrigerator side-by-side with water/ice in door. Model number 363.9534783 serial number L431 12755. It is now intermitantly leaking water on the floor. A couple of days could go by with...
1. A door open partially will cause a frost build-up then thaw and run down to the floor. Check all doors for proper closure and educate other users.
2. An issue with an unhappy animal is quite common
3. Door switch intermittently causing a light to stay on ora fan to not run
4 Ice build up around ice door chute .
5. Water dripping into ice tray and overflowing. Replace water valve.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 18, 2017 | Kenmore 57029 Side by Side Refrigerator
My freezer in my refrigerator keeps over freezing...
you may have a gasket leak letting hot air in check around the door
Apr 16, 2009 | Kenmore 9.5 cu. ft. Apartment Size Top...
USB port connection
I had the same problem. I bought a USB to Serial Adapter (IOGEAR). Works great. I believe I got mine from Wal-Mart last year for around $25.
Look here: http://www.iogear.com/main.php?loc=product&Item=GUC232A&PHPSESSID=119a3d80d289daeb12185ff1ee32e7ff
Dec 17, 2007 | Kenmore 19001
Refrigerators Logo
16 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
