Question about Psi Garden
2100 psi 2gpm ex-cell 4200cu is leaking gas from the airfilter
  • 305 Answers
The valve on the throttle body behind the filter may be stuck open.....remove filter and spray throttle body housing with lubricant
Posted on Jul 29, 2009
What is the red tube inside the airfilter, it constantly leaks a stream of gas
ALL I CAN TELL YOU IS THAT THE TUBE IS DISCONNECTED @ ONE END OR THE TUBE HAS A HOLE ON IT ! "look" @ THE AREA CLOSELY...YOU WILL FIND IT!!!!!
May 23, 2014 | Craftsman Garden
How long is a 1" black pipe with 30 psi supposed to hold pressure without dropping. It lost 6psi in 22 hours. For a NG installation.
Unless your using that black pipe for an air line, 30 psi is too much. Most gas pressures are around 14"wc, which is about 1/2 psi, or less. I would just let it out to 15psi for 15mins. If it holds and NO pressure loss is found. Your good to go.
Nov 10, 2013 | Plumbing
I have a Sharp Model AY1204J Serial No. 5101022 which leaks water from the front of the unit onto my carpet. How do we stop this?
Common problem! Water leaks due to :
1. Indoor coil and airfilter dust blocked-clean it.
2.Drain pan blocked.- clean it.
3.Less rpm of fan motor.-check and replace capacitor.
4.Short of gas.-check leak and arrest. And re charge gas.
Jan 04, 2011 | Sharp Heating & Cooling
Frozen pipes coming from my outside heat pump and going to my inside unit
Frozen in suction line (bigger pipe) line due to indoor coil,airfilter and blower wheel dust blocked. Service the unit.
Second reason is short of gas. -Find out the leak and arrest it. And then do gas charging after vacuuming.
Dec 26, 2010 | Heating & Cooling
My 1998 honda civic ex. It cranks but Engine does not start . I could not locate the fuel injectors fuse. I openned fuel line and fuel spurt out when it cranking. But I smell no gas at airfilter intake.
How many miles are on it? Have you changed timing belt? Was there any symptoms prior to non starting? Pull a spark plug see if you are getting spark. If not it is probably coilpack on distributor have it tested. Common problem I have had experienced with civics.
May 03, 2010 | 1998 Honda Civic
Can't find throttle lever on gas karcher pressure washer
hi, almost all honda engines have a trottle lever between gastank and airfilter. originally there is almost ever a turtle for low rpms and a hare for higher rpms goodluck
Feb 13, 2010 | Karcher 2500 PSI Pressure Washer
Gas leaks from airfilter housing
Sounds like the needle/seat (in Carb) need attention.
Feb 26, 2009 | 2005 Yamaha TT-R 125 L
Garden Logo
93 people viewed this question
Top Psi Garden Experts
John Trevino
fordexpert
Jay Finke
Jay Finke
Are you a Psi Garden Expert? Answer questions, earn points and help others
