Question about Refrigerators
Fridge does not work at all and trips the fuse when turned on
  • 27 Answers
The only way to determin what component is faulty is to disconnect them all and test each one with a megameter. you should get a technician to look at this problem due to eletrical hazards.
Posted on Jul 29, 2009
Testimonial: "many thanks"
Fridge blow fuse. What can be wrong?
There could be a lot of reason but most common reason for unit tripping breaker is bad compressor .
Disconnect compressor and turn breaker back on and if breaker didn't tripped then it's definitely the compressor. If breaker still tripped then there are other issues .Check all electrical wiring because something is grounded
Jun 01, 2017 | Refrigerators
Samsung rsh1nhmh fridge freezer not turning on and tripping electrics.
sounds like electrical fault within your freezer any small fault will throw your contact breakers on your consumer box without blowing the fuse in the appliances plug
Aug 30, 2015 | Samsung Refrigerators
Circuit breaker tripping
Sounds like the electric motor in the fridge may have shorted out some of the windings which is causing it to draw more current. You should get one of those clamp on amp meters to see how much current it is drawing when it first kicks on.
Jan 23, 2014 | Admiral 26 cu. ft. Side-By-Side...
Amana refrigerator sparked by plug and now won"t turn on even when plugged into another outlet with extension cord should i repair or replace?
i am in the uk so i dont no if this will sound right,but have you tried changing the fuse in the plug of the fridge? make sure you put the same size fuse back in.
Oct 12, 2017 | Kenmore Refrigerators
Whirlpool fridge freiezer keeps tripping power
Does it run for a while than trip the power or does it trip it as soon as it is turned on?
Jan 30, 2013 | Refrigerators
My fridge tripe the earth leakage everytime I switch on the fridge.
call ana accredited electrician to check the insulation of the wires and for vermin infestation that is across electrical connections
it could be a faulty capacitor or failed motor as the earth leakage breaker is also a fuse for excessive current draw
Jun 08, 2017 | Whirlpool Refrigerators
Why does my caravan fridge trip out when connected to 240v
The heater element is almost certainly to earth. Work it on gas until you can fit a new heater.
Jul 01, 2012 | Refrigerators
THE MAYTAG fRIDGE/fREEZER BLOWS OFF I.E. IT SWITCES ITSELF OFF AND THE MAIN FUSE TRIPS OFF. THE PLUG FUSE NEVER BLOW OFF THOUGH.AFTER COUPLE OF DAYS,WHEN WE PLUG IN THE THE FRIDGE/FREEZER IT WORKS FINE AND...
what's the model number,i don't understand what you're asking,are you saying the fuse keeps popping in the house fuse panel?or the fridge stops running and the house fuse is ok.what is i.e.
Feb 07, 2018 | Maytag Refrigerators
Bulbs and bottom pcb blew, replaced but still not working
the start and run capacitors of the compressor can go short circuit and cause a big spike that can blow the bulbs, trip fuse etc. Inspect the capacitors for splits etc, you may well find that the start cap has blown and so there will not be enough current to get the compressor running.
Mar 18, 2008 | Zanussi ZX99 / 5 Bottom Freezer...
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
