Question about Maytag PYE2300AY Electric Dryer
The dryer is overheating. - Maytag PYE2300AY Electric Dryer
    Novelist:
  • 135 Answers
Fresh air is drawn in past the heating element into the drum out through the lint trap and exhausted outside the building. If the dryer protection systems are operating properly they will sense the over temperature and shut off power to the heating element via thermal switches. This will cause the elements to cycle on and off and reduce the drying ability.
Things to check.
First make sure you fill the dryer only about half full of clothes, usually the dryer capacity is around twice the washer capacity for this reason.
Second, make sure your lint trap and exhaust duct work from inside the dryer all the way outside are free from lint build-up. You should clean or have the dryer duct work cleaned either every year or two depending on the amount of drying you do.
Third, suspect is the dryer thermostat stuck in the on position. You may be able to test your drying temperatures by selecting (cold) fluff air setting, then the low setting and so on to see if that's working properly. If you can read electrical drawings, usually the manufacturer includes a diagram inside the control panel for service techs to refer to. You can test the flow of air out of the dryer by removing the hose from the exhaust, it should have a good volume of air when the dryer is running. After hooking the hose back to the exhaust duct work, check outside the building for the same air flow and don't forget to clean any outside flaps that keep the rodents out of the duct work.
Keep your lint low by not over drying your clothes. You will cut down on lint and prolong the life of your clothes! Dryers are one of the simplist appliances to figure out, unless they have complicated electronic control panels.
Posted on Jul 28, 2009
Thermal limiter maytag bravos dryer
a thermal limiter is a safety switch designed to keep a dryer from overheating, by either shutting off the heating element or the dryer itself if activated. They don't normally need replacing (unless you know your dryer overheated and activated it). If you have no heat in your dryer, chances are you have a bad heating element--the most common dryer problem
Jan 01, 2013 | GE DSXH47EGWW Electric Dryer
Blowing out cold air
That could be your heating element OR one of the components installed for safety reason's All dryers have limits which trip if their is an overheating problem. Overheating is cause mostly bu air flow blockage. Rarely by the heat control itself. But you cannot rule that out if the dryer is clear of lint and junk. Your basic service manual and more is on my dryer page: DRYER PROBOS
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 21, 2012 | Dryers
Dryer overheated now does not start
the most common cause are that one of the high limit thermal fuses has gone bad. they need to be checked for continuity and the one that has not continuity needs to be replaced
May 18, 2010 | Whirlpool GEW9250 Electric Dryer
DRYER WILL NOT SHUT OFF. CONTINUOUSY RUNS AND IS OVERHEATING.
The control board regulates the timer functions, yours may have failed
Nov 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Frigidaire dryer is overheating
Sound like the limit switch on the dryer is faulty and needs to be replaced. Hoped this helped
Mar 14, 2009 | Frigidaire Dryers
OVERHEATING DRYER
First make sure the vent is not blocked relieving air flow in back for examlpe remove exhaust hose and let it run with a window open for ventalation of course and let me know if this stops the problem
Jan 31, 2009 | Whirlpool LER4634J Electric Dryer
LG Dryer overheating
check vent outlet out side house is it blowing out air.
Dec 24, 2008 | LG DLE5977 Electric Dryer
Clothes dryer motor overheating
Have you repalced the thermostat?
Apr 28, 2008 | Washing Machines
Maytag PYE2300AY Electric Dryer Logo
310 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
