Question about Kodak EasyShare Printer Dock Series 3
Unable to take out the catridge,it stick inside the printer,what can i do?
  • 295 Answers
Refer to www.kodak.com/go/manuals on how to take cartridges out. if that does not solve the issue, call Kodak @ 1800 421 6699 and they will resolve the issue.
Posted on Sep 21, 2009
I put a yellow ink cartridge in printer and it is new but the printer is saying yellow cartridge is empty so i am unable to print anything what do i do
Did you remove the plastic Seal undernith your ink Catridge, also check for any dry ink deposites where the yellow catridge sits in the catridge carriage box, if present use an alcohol cleaning pad to clean the carriage and re-install and verify.
Dec 03, 2010 | HP Officejet 6500 Wireless All-in-One...
Canon mp460 printer. refilled cartridge not recognised
Dear Sir,
This is deffinately due to catridge circuit problem.Canon suggest that we have to replace emptied catridges with new genuine canon catridge they dont suggest refilling and also not give any support for refilling catridges. So you can replace catridge with new one.
This Happens due to weakining of catridge circuit portion or may long period printer not in use.
If you not want to replace catridges i will give you the possible hints it may fix refilled catridges.
1.Clean the catridge circuit portion with soft cloth,care must be taken that there is no smudge or ink traces on catridge circuit.
2.Clean the ciruit of printer catridge placing box present inside the printer .wipe out the any sumdge or ink traces.
Then re install the catridges. give the print if it shows error press resume button continuosly. I think it will fix your problem.
If it is not solution is replace the catridge with new one.
good luck
Aug 26, 2009 | Office Equipment & Supplies
Printer keeps saying unable to print
Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer
Good Luck
May 06, 2009 | Brother MFC 420CN All-In-One InkJet...
Check Ink error on my printer and unable to clean to try and fix
Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer.
Good Luck :)
May 06, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Print unable 36
check the print catridge inside make sure it`s inserted properly
Apr 13, 2009 | Office Equipment & Supplies
Lexmark printer x6570 unable to allign after putting in new cartr
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer the Colour Catridge should go in the right side and the black on the left........ Good Luck
Feb 01, 2009 | Lexmark X2470 All-In-One InkJet Printer
Hardware error 0502, how do I fix this? What causes it?
It happpens when the Catridge is unable to Communicate with the Printer............. In this case what i would request you to do is............... Unplug the Power Supply from the Printer When u remove the cover of the Printer behing the Catridge carrier which holds the catridges u will see a thin long transparent strip which looks like a Tap........... Take a Dry Paper Towel and Gently wipe that tape from right to the left it is very delicate so pls do it gently............ Now Take out both the Catridges from the Printer.............. Move the Catridge carrier which holds the catridge, From right to the Left and From Left to Right for abt 10 Times............... Now u can insert both the catridges in and Turn On the Machine.......... Good Luck
Jan 31, 2009 | Lexmark X6170 All-In-One InkJet Printer
I am unable to get the black ink cartridge to print although I recently changed it and calibrated the printer. Computer recognises that it is not empty.
take the catridge out and reinsert the catridge after shaking it well and again place it inside the printer .....it will work ......
Oct 14, 2008 | Computers & Internet
Kodak EasyShare Printer Dock Series 3 Logo
100 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
