Question about Grilling
Masterpiece smoker will not heat. Brand new out of the box. It turns on and heating light not on and not heater. What can I do? I unplugged and reset but not heating. Help. SOS
    New Friend:
    Problem Solver:
  • 7 Answers
If it turns on push SET TEMP button + or -. Mine starts at 100 and goes to 275, so I usually use minus. Then push SET TIME button to whatever. It should start in a few seconds. If it doesn't come on, return it. You have to set time for it to start. Make sure not kicking out electric supply.
Posted on Sep 29, 2017
SOURCE: brand new rowenta professional won't heat
The mostly problem in that case is the internal terminal from cord to iron is loose ,open it and fix the the terminal cord to iron,or go to the nearest shop to repair that.
Thanks & good day,
Edgz
Posted on Feb 16, 2008
SOURCE: My electric smokers heating element
I just had the same issue and almost had a Thanksgiving disaster! Try unplugging the connection between the smoker and control pad. mine looked like it was on, i could set the temp, time and get a reading of temp, but it must not have been sending the 'heat' command. also, bass pro has thios on sale tomorrow for 129
Posted on Nov 27, 2008
PartsCenter
  • 125 Answers
SOURCE: Rapid Heat Bath Heater - indicator light on but not heating water
Bathtub heaters will not produce the heat out a the jets like you would feel coming out of a return jet in a swimming pool.
Bathtub heaters will ONLY maintain whatever temperature water you put in there. they only heat 1-2 degrees an hour. that is for a 1500 watt heater. Many heaters today are only 650 watt or perhaps 700 watt.
Posted on Feb 24, 2009
bobiii84
  • 65 Answers
SOURCE: Have no heat. Have replaced heater core,
I don't know your vehicle, but does it have a blower door tucked in where the heater core is? If it DOES and that's broken then it could be the whole problem. It would mean it isn't switching from the A/C side of things to the heat side of them. Hope this helps, good luck! Also, just looked up the proper name for what I'm talking about, it's called a "blend door" and I think your car has one. It's what I would check, again, good luck!
Posted on Jan 20, 2010
  • 7 Answers
SOURCE: My Masterbuilt electric smoker stopped heating will cooking
I just bought a new Masterbuilt Smoker by default two weeks ago I borrowed a friend’s to smoke about 30lb. of Salmon to then can. Ran the smoker every day for three day. ON my last batch the heating element would not work. Talk about Frustrated! The Smoker was only 2 yrs. old.
Knowing I borrowed I felt I had to replace. So online to Cabelas and I ordered my buddy a new smoker and had it shipped. I then found this website... GOT TO LOVE the internet. I saw many other people had the same problem. Found an Answer...
The Problem was one of the connector to the heating element was poor quality and if you don't clean your smoker on a regular basis. The heat and moister caused the small copper connector to corrode and the wire to come loose. I took a wood chisel and cut off all the rivets on the back. I was then able to pull the back off with no damage and access the small box in the lower back. I found the connector. Went to the hardware store and bought a replacement for .75 cents. A pair of wire crimpers and the problem was fixed. I also bought ½ inch Sheet metal screws to secure the back it was good as new. So I returned the smoker to my buddy and kept the new one. When it arrived I saw Masterbuilt has since fixed the problem and provided an access panel to the element and connectors.
Mike in Alaska
PSU313@yahoo.com
Posted on Jul 03, 2010
Master forge electric smoker will not heat up
Hi, smoker heaters can be found on amazon (sounds like you need new one), here: Amazon com Old Smokey Electric Smoker Replacement Heating Element. I hope this was helpful. regards
Dan
Apr 13, 2013 | Grilling
Brand new heater won't start. Transformer buzzes. Power is good. led doesn't light. 3A fuse at bottom of circuit board keeps blowing as soon as the power to the unit is turned on. Problem?
There is a definite problem here with a dead short, honestly I would return the heater to where ever you purchased it from. To be brand new it should be out of the box and plug it in maybe a little programming and instant heat. Hopefully you are not to far away from the purchase place.
Jan 03, 2011 | Heating & Cooling
I am getting a EEAF fault code and the smoker will not heat. What is wrong?
To RESET control panel:
If control panel shows an error message, turn electric smoker off, unplug unit from outlet, wait
ten seconds, plug unit back into outlet, then turn electric smoker on. This will reset control panel.
ASSEMBLY, CARE & USE MANUAL
WARNING & SAFETY INFORMATION
MODELS 20070106, 20070206
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 25, 2010 | Masterbuilt 20070106 Electric Smoker
Mike in Alaska
PSU313@yahoo.com
Jan 24, 2010 | Masterbuilt 20070206 Smoker
Digital readout says eaaf
The unit will not turn on if the internal temp sensor is below 40 degrees. Warm it with a hot rag or hair dryer, or bring the unit inside to warm up and it will turn on. Once the unit turns on for a minute or so, it will work fine outside.
This isn't the ideal solution, but it will work. I don't know why they don't want the smoker to turn on when it is cold out (unless they are worried that the quick change in temp will damage the heating coil).
Nov 26, 2009 | Masterbuilt 20070106 Electric Smoker
The heating element does not operate -doesn't heat
How true: I love this smoker but until the heating element doesn't work. I am on my 3rd one now. Each have had the heating element go out. Luckily the 1st 2 smokers I took back to where I purchased them and they "Cabalas" gave me a new one "NO questions asked". Now I have this 3rd smoker. Guess what! Not heating again. I decided to take this thing apart myself and investigate the problem. Since the unit is all sealed I need a Drill, dremal cutting tool to open up the backside to get at the heating element and wiring. What I found was that the CONNECTOR to the heating element was BURNED up. All wiring was fine! I believe MasterBuilt is not putting in a high enough temp connector and also the connector looks to me of dissimilar metal which will cause metal breakdown when heated. I then went to Ace Hardware and found some High temp connectors and replaced the originals. All working now!
My friend has the same smoker with the same problem ... He called Masterbuilt and got the song and dance and how much it would cost to fix - so went out and purchased a Different Brand. Knowing that I had fixed my smoker I ask him if I could take his apart .... Well and behold ..... It had the same CONNECTOR problem. I wish I had my 1st 2 smokers back to check those out also. But my theory is that they also had the same problem.
Here is 1 more problem I have seen with this Smoker ... I store my smoker on my deck all seasons (covered up when not in use). During the winter when it is cold out my smoker control panel will not come on. It always works when it was warm out. So what I have found is if I take the control panel off and bring it inside to warm up .... Then reinstall it all works fine! My theory is that the control panel has a liquid crystal that is freezing causing it not to work.
Sep 11, 2009 | Masterbuilt 20070106 Electric Smoker
My electric smokers heating element does not get hot-after only about 20 uses-Any suggestions-The manufacturer said they would need to send me a new box for $199-Seems rediculus this cant be fixed?
Oct 30, 2008 | Masterbuilt ESQ30B Smoker
Tripping the electrical Breaker
I have used the charbroil bullet electric H2O smokers for years (wore 2 out - currently on my 3rd). I won't use anything else (having used many, many others - HOWEVER - as with every product made there are things to watch or overcome. Learn to use it properly and look forward to many years of great BBQ.
Ambient (outside) air temp below 70 (depending on wind also) will affect these smokers drastically - highly recomend getting or making a "smoker blanket" (got mine at cabelas years back - if you can't find one welding blankets from an industrial supply store can be made into one) to insulate the sides - this drastically reduces heat loss and reduces the electrical load.
Another MAJOR mistake many people make is extension cords - avoid the use of them at all if possible - if not possible then purchase the heaviest gauge you can find.
Always pre-heat your smoker - Always use boiling water (or other liquid) in the H2O pan added after smoker is pre-heated - Always minimize opening the smoker once cooking has begun.
The heater element can be cleaned when cold with a very mild detergent and room temp water.
If you have the large 2 rack but are only smoking enough to use a small amount of rack space on only one rack remember that you are heating a whole lot of air - i have a couple (different size) wood boxes wrapped in foil to take up excess air space - this means less air volume to be heated and better heat control - DO NOT use cardboard boxes or other low temp combustable items in the box construction!
Make sure the house outlet you are plugging into is a 3-prong GROUNDED outlet on a 20 amp breaker.
Finally, make sure your smoker is level and remember there can be up to a 20 degree cooking temp swing in temp between the bottom rack and top rack (top rack 5-20 degrees hotter than bottom).
The heater element will cycle on and off during normal use.
Good smoking and enjoy.
Apr 28, 2008 | Char-Broil Electric H2O Smoker
Power light on, no warning light, doesn't heat up at all
Your resettable thermostat turned off the high power heater circuit and the red warning light. The heater got too hot when the boiler became empty of water. This is to keep the heater from burning out if the boiler becomes empty. To reset the thermostat, turn the micro casa a leva over. There is a yellow plug near the center of the bottom which is easy to pry out. Stick a screwdriver, pencil, toothpick, chopstick or whatever else is lying around into the hole and gently reset the thermostat button. You will hear a click when it resets. You are then ready to go.
Jan 04, 2008 | Elektra micro casa a leva S1CO Espresso...
Electric water smoker low heat
Make sure the house outlet you are plugging into is a 3-prong GROUNDED outlet.
Dec 04, 2006 | Char-Broil Electric H2O Smoker
Grilling Logo
210 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Marvin
Marvin
Are you a Grilling Expert? Answer questions, earn points and help others
