The Bernina 730 sewing machine was manufactured between 1963 and 1982, before Bernina came out with their first computerized sewing machine, the 1130 model.
Are you asking about the Bernina Artista 730 sewing machine, instead? If so, the answer is MAYBE.
Contrary to what Bernina has said about their software (Bernina Embroidery Software v5), that particular software CAN be installed AND ran in Windows 8 with no issues whatsoever. When you install it, it will perform normally (not go to a blue screen like Bernina says), then it will ask you to insert the dongle. After installation, go to the Bernina Embroidery icon and right click. Select troubleshoot compatibility. The computer will run a test to see what system you should run the software as. It should say Windows XP Service Pack 3. Select next. Now double click your Bernina software and it should start up fine. Hope this helped.
Problem is that the Bernina software you are using expects to talk to a 'COM port and the PC's USB serial interface doesn't automatically default to a COM port. Make sure you have installed the software that was delivered with your USB-to-Serial adapter and look on your PC's 'Device Manager' under 'Ports' - you should see the USB adapter listed and it should be assigned to a COM Port number. You need to check what COM port numbers are accepted by the Bernina embroidery software (sorry, I cant remember and haven't got one here presently) - it should be in the Options menu. You have to ensure that the USB 'virtual COM port' is the same as that which is set in the Bernina software. If the Bernina software doesn't support the COM port allocated to the USB interface, go to 'Properties, Port settings, Advanced, COM port number and set this to the same as the COM port number in the Bernina software - hopefully this should set up the link OK, provided you haven't got a COM port clash - to avoid this, it's usually best to choose a COM port number of 2 or above.
