I cannot locate the air conditioner control module on my 1997 GMC Yukon. Can you specify the location on the vehicle. Carl Bowmer
  • 2 more comments
  • cfbllc2 Jul 29, 2009
    Rylee: There is power on the brown wire going into the a/c control unit and power coming out of the unit on the light green wire. However, there is no power on the light green wire at the low pressure switch. On the other side of the low pressure switch, there is a dead short on the dark green and white wire going back to the vehicle control module. Your thoughts? Thank you. Carl Bowmer
    Rilee: NO problem with the blower, it works fine. The problem is no power to the electric clutch which activates the compressor. Thanks. Carl
  • cfbllc2 Jul 31, 2009
    The problem has been fixed and it did involve the wores going back to the control unuit. thanks, Carl
    Brigadier General:
  • 8,619 Answers
Hi Carl
Please check this link fro detailed info. regarding 1997 GMC Yukon A/C controller . Its the one just off of the blower motor under the dash on the passenger side.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 28, 2009
  • Rylee Smith
    Rylee Smith Jul 29, 2009
    Hi Carl
    Purple wire is 12V+ and black is ground. With the switch on high, there should be power and ground present. Remove the Blower Resistor and check for continuity across all of the coils and the resistor.
    Also check the HVAC Control Module which includes the rotary switch. Check the wiring harness around the heater housing for signs of overheating. Also check the blower motor resistor and they go bad and you will have no power to the motor, it will look like this-- Blower Motor Resistor
    Thanks
    Rylee
  • Rylee Smith
    Hi Carl,
    You need to replace these wires (dark green and white wire going back to the vehicle control module) as I believe that may have gone bad due to the dead short.
    Thanks
    Rylee
Where is the air bag control module located?
SDM airbag tech info - GM Air Bag, Black Box, EDR, Event ...
www.airbagcrash.com/sdmairbagtechinfo.html
GM air bag black box / EDR / event data recorder / SDM / deployment crash data ...Buick, Cadillac, Chevrolet, Pontiac, Oldsmobile, GMC, Hummer and Saturn ... control module, pcm, event data recorder. edr, truck, airbag testing, air bag ... EDR 'black box' air bag module location list posted below. ..... Suzuki 2007-2014
Chevrolet Tahoe location air bag module Questions ... - Fixya
www.fixya.com > ... > Cars & Trucks > Chevrolet
Ask your Chevrolet location air bag module related question. Get free ... How do I fix my ABS control Module for 2001 Tahoe ... How to reset airbags in a 2007 tahoe ... Where is the Air Bag computer modual located for the 2005 Tahoe Z71?Missing: hevrolet ‎avalanche
BCM Basics 101 (03-06) - Chevy Avalanche Fan Club of North America
chevyavalanchefanclub.com > ... > CAFCNA's Sperry Tech Center
Aug 8, 2015 - 3 posts - ‎2 authors
The Body Control Module (BCM) performs multiple body control functions. The BCM can control devices directly connected to its outputs based ...Missing: hevrolet ‎bag
Jan 12, 2016 | Chevrolet 2007 Chevrolet Avalanche 1500...
Will a 2008 yukon run with a missing fuel pump relay
{: ) Yes, if the vehicle is equipped with a Fuel Pump Flow Control Module (FPCM). The FPCM is located underneath the vehicle, left side chassis, near the Electronic Brake Control Module. Sometimes, when you check fuse and relays at the underhood fuseblock, you can still see labels and alloted space for the fuel pump fuse and relay. But the circuit is actually internally omitted or modified inside the fuseblock if the vehicle is using FPCM. An FPCM controlled fuel systems doesn't have fuel pump relay at the fuseblock, and instead you may find a FSCM fuse 20amp which gives battery power to the FPCM.
Jun 16, 2011 | 2008 GMC Yukon
I'm looking for the interior light relay location in a 1999 GMC Yukon SLT. Where is it?
There is no relay,only an interior control module located in the center of the dashboard,sorry. Thanks Ray if you need more help get back to me.
Mar 05, 2011 | 1999 GMC Yukon
How to replace the heater core in a 1998 gmc Yukon.
Heater Core Removal & Installation To Remove:
  1. Disconnect the negative battery cable.
  2. Drain the coolant from the engine.
  3. Recover the refrigerant.
  4. Remove the glove compartment.
  5. Remove the floor air outlet.
  6. If equipped with a diesel engine, remove the powertrain control module.
  7. Remove the kick panel trim.
  8. Remove the blower motor.
  9. Remove the steering column.
  10. Tilt back the instrument panel assembly.
  11. Remove the coolant recovery reservoir from the engine compartment.
  12. Disconnect the heater hoses and the evaporator tube.
  13. Remove the accumulator.
  14. Remove the fasteners and the HVAC module assembly.
  15. Remove the cover plate on the bottom of the HVAC module.
  16. Remove the heater core and seal from the HVAC module.
To Install:
  1. Install the heater core and seal.
  2. Install the cover plate on the bottom of the evaporator case to the HVAC module.
  3. Install the HVAC module in the vehicle.
  4. Install the accumulator.
  5. Connect the evaporator tube and heater hoses.
  6. Install the coolant recovery reservoir.
  7. Install the instrument panel.
  8. Install the steering column.
  9. Install the blower motor and cover.
  10. Install the kick panel trim.
  11. Install the powertrain control module and tray.
  12. Install the floor air outlet.
  13. Add coolant to the cooling system.
  14. Connect the negative battery cable.
  15. Evacuate and charge the A/C system.
  16. Check the system for leaks.
Nov 06, 2010 | 1998 GMC Yukon
2003 gmc Yukon 5.3 ..2WD air conditioner blows
A vacuum hose that controls the little door that switches where the air blows from is off, its gonna be a real chore the find which one and take the dash out to get to it, but you might get lucky and be able to look underneath the dash from the passenger side and actually see it, good luck
Jun 19, 2010 | Cars & Trucks
Where is the body control module located on 2000 yukon
under the dash on the drivers side. above the break pedal
Feb 06, 2010 | 2000 GMC Yukon
2003 yukon denali---relay locate for blower
the relay is built into the speed resistor or motor control module ) depends if you have automative or manual heater controls. is automatic it will be motor control module and manual is the resistor module. these units are located beside the heate fan motor. the motor helps keeps the unit cool. just unbolt the module, unplug it and install new one. Just check to make sure the connector is good.. The heat created by the connection sometimes melts the power or ground leads (red or black) and if this is so you will need to replace the pin.
Sep 01, 2009 | 2003 GMC Yukon Denali
Air Conditioner Problem
the most common problem here is a defective air temperature control blend door actuator, this is what moves the door that controls air flow across the heater core or the ac evaporator core, to replace this requires u remove the dash assembly.
Aug 13, 2009 | 2005 GMC Yukon Xl Denali
Interior dash years and crossover
You need a dashboard from a 1997-1998 model. In 96 there was no passenger air bag, and in 1999 there was another update, so you are kind of limited. Stick with a 1997-98 Chevy or GMC dash and you should be okay.
Nov 28, 2008 | 1998 GMC Yukon
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
