Question about Wolf Range WKGD-1 Gas Single Oven
I have an old wolf convection oven pilot lights, not the burners
I have an old wolf convection oven with a manual pilot and a baso gas valve. after following the leads from the motor and lights, I managed to get the lights to work. I changed the switches for both the fan motor and the lights. The unit was working well for half the day, but now the pilot comes on but the burners wont fire up. I jumped the thermostat and it did not solve the problem. I was tapping the solenoid on the baso valve and when my screwdriver touched it and a small electrical "fliberdigibit" behind the valve, the burners fired right up! I dont know what the thing is behind the valve but it has a lead coming from the solenoid valve and a lead coming from the t-stat. help! It wont fire up again... could the solenoid be failing?
mgprice
  • 744 Answers
SOURCE: no gas to oven
Hello, even though the igniter is glowing it does not mean it is drawing the correct amps to open the safety valve. If your igniter is glowing orange replace it. Igniters should glow brillient yellow to the point where you cant look at it. replace the igniter and you will be good to go. Good Luck!! Mike
Posted on Oct 01, 2009
  • 25 Answers
SOURCE: soap and water just don't cut the built up grease
Use de-greaser, soap, and brillo pad.
Posted on Dec 01, 2009
johnrodgers1
  • 73 Answers
SOURCE: How to light a Wolf Gas Oven, model PW362718,
you cant !!! need power to operate if it has a glow coil ignition
Posted on Feb 06, 2010
  • 93 Answers
SOURCE: Electric gas igniter will not turn off when I turn
You may have top burner misaligned or bad electrode.
Posted on Mar 02, 2010
rickead1
  • 1998 Answers
SOURCE: I've owned a 30" Wolf
heres about the cheapest solution to try goto www.marcone.com under contact us there is a 1800 number this is the cheapest appliance parts dealer and the largest in the world .Yes you can replace the ignitors and the leads would be termed as harnesses not quite sure what you are refering to switches that sit on top of gas valves though do you have a site or a picture also send your model number as well and when you goto marcone just get a quoted price from them and then check wolf as well the manufacturer if you have any further questions message me back and please remember when our chat has concluded to rank how this opinion has helped Thanks again Rick
p.s about the most reasonable path would be to take out the ol multimeter and assure that you have the same amount of voltage going to each ignitor in most ovens this is controled by a spark modulator you can also remove each ignitor and do continuity tests on them to assure they are functioning properly as well remember to message me back your model number
Posted on Jan 07, 2011
Royal commercial oven pilot
replace the thermocouple first. it can be purchased at you local hardware store.
if that does not fix it, you will need to replace the Baso, pilot safety. that can be purchased at partstown.com
Jul 07, 2013 | Ovens
Pilot light issue
you cannot light the pilot on that oven manually. that oven is eletronic ignition. take off the panel under the doors, turn on the oven, and turn the thermostat to 350.
if you see sparking on both the right and left burners, you and it doesnt light, you need to see if the gas solenoid on the right side of the burner is getting power. if it is and nothing lit relace it.
if it is not, replace the ignition board
Jun 30, 2013 | Ovens
How do adjust the pilot on a wolf commerical oven
screw is next to the pilot tube where it attaches to the safety valve. unscrew to find the actual adjustment
Jul 26, 2012 | Wolf Range F0027WS36 Gas Oven
I have an american range gas convection oven i think lightning may have struck them but they still run but the gas will not come on the igniter just keeps ticking and no gas
there posible pilot burner is clogged, you may want take off the gas pilot tube and make a quick turn on to see gas is come out from pilot tube or disconnect from gas valve pilot connector...have fun....
Sep 23, 2011 | American Range Ovens
I have a gas garland convection oven 10-15 years old. I see the red button to relight the pilot light but I can't find the pilot light itself. Can you tell me where I should be looking?
On the main bake burner is going to be a small pilot burner,got to lift off the oven floor to get to it. It is going to look something like this picture and is attached usually to the side of the main burner.To light the pilot,push that red button light the small pilot burner..hold in the red button for about 20 seconds..release the red button..pilot should be on..if goes off the thermocoupler is going to be in need of replacement
Aug 26, 2011 | Ovens
THE OVEN BURNER WILL NOT LIGHT. THE IGNITION SYS IS WORKING. I CAN HEAR AND SEE A SPARK, BUT THE PILOT WILL NOT LIGHT.
If you can hear and see the spark lighting that acually means there is no gas entering. please check that you have have the pilot knob in possition and and and the pilot pibe and orifice is not blocked with dirt.
Jul 29, 2010 | Wolf Range F0027WS36 Gas Oven
Where is the pilot light in oven?
Pull out the bottom tray of your oven...under there you will see the heat shield over the burner...take out the screws holding that and the ignitor is all the way in the back beside the burner...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 15, 2010 | Wolf Range WKGD-1 Gas Single Oven
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    Pilot light still going out
    If this oven has a "stack" (where the hot gases & heat vent to your hood) air could be blowing down the stack affecting the pilot. Simple test, Bic lighter lit at the top of the stack in the middle of the opening. If the flame is being sucked down the stack, then you have air blowing the pilot out. How old is the thermocouple on this unit ? Pilot flame heats this up to send a signal to your main gas valve to open up so the burners light. A weak t-couple could be your problem. Hope this helps
    Jul 23, 2009 | Bakers Pride FC-616 Gas Single Oven
    Main Burner not lighting
    This is caused by a faulty pilot safty valve. it will be the tee looking valve with the red dime sized button in the middle.
    Hope this helps You
    please rate me
    Oct 18, 2007 | Blodgett DFG-100 Gas Single Oven
    Wolf Range WKGD-1 Gas Single Oven Logo
    194 people viewed this question
    Top Wolf Range Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you a Wolf Range Oven Expert? Answer questions, earn points and help others
