Question about Grilling
1burner out of 6 is burning very yellow ,I know it must be getting too much propain ,adjusted damper, check holes in burner ,but still yellow?
    New Friend:
  • 4 Answers
...have you checked the orifice..you know where the gas leaves the manifold and enters the burner. Possibly corroded....
Posted on Oct 07, 2017
  • Grilling Master
  • 3,328 Answers
Its a blocked burner lack of air makes it burn yellow
Posted on Oct 04, 2017
SOURCE: burners with yellow tipped flames
I have a G.E. natural gas cook top. All 4 burners have a lot of yellow flame all of a sudden. Is there an adjustment for this I could make? Please explain the best you can.
Posted on Nov 10, 2008
SOURCE: How do I adjust the air flow to the burners?
Thanks, found it.
Posted on Nov 25, 2008
  • 82 Answers
SOURCE: yellow flame on our gas burners
Hello. Have you tried replacing the regulator? Sometimes spider webs can get into the burner valve orifices or inside the burner ports. You may even also need new burner valves. Let me know if you need to know where the regulator is.
Posted on Dec 03, 2008
  • 160 Answers
SOURCE: My surface burners are burning with a yellow flame
yellow flames indicates blocked gas jets... must be cleaned or replaced before using for safety reasons
Posted on Mar 21, 2010
woodchuck789
  • 4070 Answers
SOURCE: On Barbeque side burner it burns with a high yellow flame getting
Try using compressed air to blow out the burner and make sure the gas is turned off when you do it.
Posted on Apr 20, 2010
Front burner , yellow, flaring flames and sooty pans
Sounds like the front burner gas jet holes are either blocked in places or the gas regulation (air/gas) mix to that burner needs adjusting. Try removing the hub where the gas burns from and cleaning each hole with something like a paperclip and then blowing through it to expel any particals.
Dec 01, 2013 | Rangemaster Classic 90 (Electric) Kitchen...
SOOT PROBLEM CAUSED BY YELLOW FLAME
If they burn yellow then they are blocked IE lack of air causing flame to burn floopy yellow hence soot , clean burners and orfices to burners .
Mar 25, 2012 | Grilling
Left burner produces a normal blue flame, but the right burner produces a big yellow flame - how can I fix this?
Hi inomura...
Look at the left burner, pipe,air hole adjustment,etc because it is operating good.
You will see a difference to it compared to the on the right.
The right pipe, air hole, or the length the pipe that are iserted in the gas control valve is different from the left.
The yellow flame indicates that not enough air is getting to the flame getting to the right flame ignition point.
The left flame is nice and blue...normal, the right is yellow indicating that not enough air is getting to the flame ignition point...look to see if the air hole adjustment is different than the one on the left...there is something open more or less, improperly adjusted.
Once you have it adjusted properly the right flame will burn bright blue just as it does on the left.
Please take time to rate me
Sep 04, 2011 | Coleman Roadtrip Grill LXE 9949-750
Hi - I have a 4 burner GE gas cooktop. The clicking sound comes from all the burners but 2 of them are difficult to light. If I hold my hand over the top ... they will light! Is there an adjustment that...
Usually this happens if something has been spilled or a pan overflowed and is partially clogging some of the burner holes. Make sure the burner holes are clear and try poking them with a sewing needle to make sure. I am assuming the flames are a nice blue color and not a lazy yellow or yellow-tipped. If there is some orange, that is usually an indication you are burning off some food and will need to be cleaned. If that doesn't appear to be the issue, then let us know and we'll dig deeper. Douglas
Sep 18, 2010 | GE 30 in. JGP328 Gas Cooktop
Gas Grill Burners with yellow flames coming from beneath them
the flames should be blue and the burners clean. check gas pressure and the air mixture dampers. touch air will give you the same effect. if the burners are clean, it is the mixture. as far as the slots in the bottom. i have not seen that. but i work on commercial ranges.
Feb 27, 2017 | Char-Broil Commercial Stainless Steel...
Inefficient high pressure cast iron propane burner
Make sure you are using an adjustible high pressure regulator. Make sure there are no obstructions insde the burner tube or burner holes.
Oct 31, 2009 | Thermos 0210-1309 Turkey Fryer
Bright yellow flame, can't adjust
Check your burner tubes for spider nests. Clean the burner assembly and check all the holes. Eric
Aug 08, 2009 | Holland Grill Legacy (NG)
Lots of yellow - then very low heat
Are the flames still yellow? If so the burner just needs to be adjusted which is very easy? Look at the ends of the tubes that come out of the burner and end right at the back of the gas controls. You should see a small piece of metal that will slide or spin to close a hole. You want to close or open it a little at a time while the grill is burning. Adjust this until you only see blue flame or blue flames with a little bit of a yellow tip.
Jun 13, 2009 | Char-Broil Commercial Stainless Steel...
THE JENN AIR BOTTOM BURNER IN THE GAS OVEN IS BURNING YELLOW
check that the bake ignitor is drawing min 3 amps. if not change ignitor. if its ok yellow flame is not enough air for the amount of gas. check the orface(small brass fitting on valve) hole to make sure its clean. if yes adjust air shutter on burner
Nov 16, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Yellow flame on our gas burners
Oct 10, 2008 | Grilling
Grilling Logo
272 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Marvin
Marvin
Are you a Grilling Expert? Answer questions, earn points and help others
