Question about Canon Cameras
Reset option and clean sensor option are not visible in set up menu. Canon D20 I had a two spots that kept appearing in the same area of the photo so I looked at the manual and did the clean sensor function a couple of times and the spots remain. I had also done a reset all functions since my stepson gave me the camera and I wanted to restore it to its original settings. Now I don't see either the clean sensor option or the reset in the set up menu. Help!
  • 60 Answers
First of all - great camera! Check out http://www.dpreview.com/reviews/canoneos20d/ for a lot more information on the functionality. The sensor clean function only raises the mirror and exposes the sensor so that it can be professionally cleaned so that may not solve the problem of the spots. Furthermore, be extremely careful if you have the lens off when doing this as you can make the problem even worse. I would recommend you take it to a good local camera shop and ask them to clean the sensor for you. In the UK it costs around GBP30.
Posted on Jul 28, 2009
Canon A530 black spot on LCD which is visible in the photos tried to clean the lensa but was in vain canyou help pls?
A blck spot on your pictures, means there is something blocking light on the sensor. Could be dirt, but more lightly is there has formed some mould.
Because you can't open a compact camera to clean the sensor, I think you can't solve this problem. Opening the camera is no option, because without skills, tools and manual, you won't be able to put the camera together. A repair shop most likely won't start the job, because the repair will cost more than a new camera.
Sorry I can't bring a more positive story.
Jan 26, 2014 | Canon PowerShot A530 Digital Camera
Tip
Stamp Date and Time on Photos in Canon Digital Cameras
Hello Dear,
In all Canon PowerShot and IXUS series cameras date and time can be stamped on the photos shot in Post Card Size, to set the Camera into this mode do the following:
On Camera in Shooting mode (Live view is visible on LCD)
Press Function/Set button once
From right-left move to the Post Card Size
Press Function/Set again.
Now, Press Menu Button
From up-down move down
On Stamp Date (Option Name written, Visible on the Right top Corner of Screen)
From right-left move and select you want only Date or Date and Time both.
Press Menu again
Now, you are ready.
For more clarification please revert.
Warm Regards,
Joseph Manoj
on May 26, 2010 | Cameras
All of the icons are still visible, but otherwise, the screen of my t99 is showing up blank. The camera still takes pictures, but the photos are black and so is the display. Please help! No temperature...
This may be due to the CCD Image Sensor failure in the Camera.
To confirm the issue, please check if the previously captured images are displaying normally. The previously captured images and icons will get displayed normally if the CCD image sensor issue is there in the Camera.
If this happens only with the live view, then try Initializing the Camera.
The Initialize option can be done only if the Menu of the Camera is accessible. To access Initialize select MENU-->SETTINGS-->MAIN SETTINGS-->INITIALIZE-->OK.
You may also try power resetting the camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally.
If the issue is not resolved after resetting, service may be required.
Thanks for using FixYa.
Jan 18, 2011 | Sony DSCT99 Digital Camera
How to clean EOS 60D sensor manually?
I would not try this as the sensor cleaning system is pretty effective, but if your still getting dust spots I would A. get it sent back to canon for a dust clean (should be free in the first 2 years) or B
use the bundled software DPP to take out the spots. theres a setting in the camera which asks you to take a shot of a blank paper then send this photo to the DPP software. it then maps out the spots on that image and it batch process all you images thats has dust spots in them and removes them. it works really well and canon has had this in their cameras since the 30d.
I dont have the camera with me but if you put the camera into a manual mode them press the menu key and make your way to the yellow area of setting it would be there but first install DPP which would be on the CD that came with your camera.
Failing that if your in the camera settings i believe in the yellow area again there is a setting called "cleaning mode" which will lift the mirror without a lens on so you can use a rocket blower. this setting may have been taken out on the 60d as its not recommended
Jan 09, 2011 | Canon EOS 20Da Digital Camera
I HAVE A NIKON D40. A DARK CRESENT SHAPED BLIMISH APPEARS ON THE SKY AREA OF PICTURES. THE CONDITION EXISTS WHEN DIFFERENT LENSES ARE USED.
The main reason for such things is a dusty sensor. Mostly the sensor dust comes out on sky areas just like you said and especially when useing a small or a medium aparture usually starting from f5,6.
I would recommend you to do a test photo. All you have to do is make a picture of a white thing e.g. paper with an aparture f8 or more. Then you can see all the dust spots on the sensor. If there are not many of them then you can just use photoshop to remove them from every picture, b ut I would recommend you do take your camera to the nearest service and let them clean the sensor or you can buy a sensor cleaning kit e.g. Visible Dust and clean it yourself.
May 06, 2009 | Nikon D40X Digital SLR Camera Digital...
White spots on photos
No setting can cause white spots on the picture, this is a fault.
By the way you can reset settings on this camera to initial state by simply removing and putting back camera batteries.
Alternatively you should have a reset command on camera settings menu.
My opinion is that this is a fault and not a settings problem.
Typically there are three kind of faults that can cause this problem:
1 - Dirty lens or water inside the lens:
The lens may be dirty inside, for example because of water condensation on internal surfaces, this will cause blurred dots or black dots. The lens must be taken apart and cleaned in this case.
2 - Defective CCD sensor.
The CCD sensor is the chip that detects the picture, if you get well defined white or colored spots on picture that is probably a defective CCD. I think this is the more likely in your case. To fix this the sensor must be replaced.
3 - Defective video chip on internal board.
This can cause any kind of problems, however it is quite unlikely.
It is an expensive repair.
Feb 09, 2009 | Sony DSC-T70 Digital Camera
Oil spots on sensor 5d
Are you sure what's on the sensor isn't dust and not oil? Cleaning a sensor is a delicate operation though I've done it in the field where I had no options to save a shoot. If there is actual debris on the sensor and it cannot be CAREFULLY removed with a LIGHT, INDIRECT burst of air or a very clean, fine lens brush then I'd send it in to have it professionally clean. Canon has a fast turnaround time and pretty reasonable.
Oct 24, 2008 | Canon EOS-5D Digital Camera
Spots on Image sensor?
put in p mode and go to the sensor cleaning function you need whats called a lens pen it will clean those spots easy just be gentle.
Nov 10, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Cameras Logo
85 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
