Question about Mitutoyo Measuring Tools & Sensors
How to reset Mitutoyo 314-351 "V" anvil micrometer. It should not read "0" when turned all the way in.
    President:
  • 704 Answers
In order to reset the zero point for your specific micrometer, you will need to have a standard set of pre-set dimensional pin(s). You can check the attached link (page 71 of the Mitotoyo catalog) for the information you need). I guess you could try to find or make a pin with the same dimensions as those noted on the catalog page, but if you're using this in a manufacturing setting, you might have no choice but to purchase a set of gauges for calibrating your micrometer.
The only other option is to contact the manufacturer for an alternative method, but I doubt they'll be able to provide any alternative, as precision setting of the zero point is required for accurate readings with this specialty micrometer.
http://www.mitutoyo.co.jp/eng/products/micrometer/Micrometer_2.pdf
Posted on Jul 28, 2009
0-1 mitutoyo micrometer reads E--o5 i have replaced battery and cant make it go away?
A data sheet I got with my Digimatic 572
series scale says:
"Keep the scale unit free from water and oil.
Do not dip or sink the scale unit in liquid.
If E--05 is displayed, wipe the scale surface
with a soft cloth. Apply a slight amount of
low viscosity oil, such as CRC3-36, to the
scale surface to keep out water."
mitutoyo micrometer reads o5 Google Search
Mitutoyo Support
http://www.mitutoyo.com/
Jun 29, 2017 | MADE Computers & Internet
How do I shut it off
Digital micrometers with LCD displays usually do not have a power on.off feature. Older units have an "on" button only that is used to turn them back on after a predetermined time-out or period if inactivity to conserve battery capacity but newer Mitutoyo mics cannot be turned off.
Feb 26, 2015 | Mitutoyo 317-351 Digital...
How to fix E-05 error on a micrometer?
On the older ones, it means you overrode its ability to keep up with movement of the slide. Either you moved the slide too fast, or it has water, oil, or dirt on it. Reset by turning it off and on. Clean the scale first and wipe with a VERY lightly oiled rag.
But that reading looked like this: E--e5. If yours says Err 05, it's probably a newer one. In that case, call Mitutoyo to find out: 1--888-648- 8869.
-- Ed Huntress
Aug 15, 2014 | Mitutoyo 293-335 Coolant Proof LCD...
How to reset depth micrometers , any style , easiest method for Mitutoyo line
The nut on the end of each rod is for calibrations. On a clean flat surface check your reading at "0"and see if adjustment is needed either left or right on the nut for getting before zero or after zero readings. Adjust the nut as little as possible and re check for zero multiple times because the nut is sensitive. hope this helps.
Jun 29, 2011 | Mitutoyo Depth Micrometer 0-6"
I lost my owner's manual and need to know how to reset the micrometer to zero
This is based on an old Brown & Sharp guide book. 1. Carefully clean the measuring surface by pulling a piece of soft paper between the surfaces while the anvil and spindle are in light contact with it. 2. with the anvil and spindle apart, unlock cap with spanner wrench (supplied with unit), then tighten cap lightly with fingers to bring slight tension between thimble and spindle. 3. Bring anvil and spindle together by turning SPINDLE and set zero line on thimble to coincide with line on barrel. 4. Move spindle away from anvil by turning SPINDLE, NOT by turning thimble. 5. Holding thimble only, tighten cap with fingers. Do Not Touch Frame. Lock cap with wrench, still holding thimble only, and adjustment is complete. NOTE: Check zero setting after adjustment is made. Hope this helps
Jun 04, 2010 | Mitutoyo #117 107 0 1 Uni Mike Micrometer...
The locking nut on my micrometer does not lock anymore, can i fix this?
yes. Just remove the screw in the lock, lift the lock arm off its shaft, and reposition at different angle. (put to lock, take off without turning, and set back on at unlocked position...may ned adjusting)
good luck
Mar 28, 2010 | Mitutoyo 0 1".001 Fric/Thimble Mti Outside...
0-1 OD Digital Mic Mitutoyo hard to spin
You have a nice micrometer! Your problem could be caused too many different things. I would take the lead screw spindle off first and then clean both assemblies. (You can use W-D 40) this will allow you to clean the I.D. I do not know how much you understand how a micrometer works and would caution you not to adjust any of the adjustmants on the micrometer because it could end up out of calibration. I would be happy to take a look at it and free it up and calibrate it for you! I was the Manager and working Supervisor of a precision Tool Room for over 25 years and have quite a selection of parts. I would not want any compensation for the help and I would just ask that you include a prepaid return package. I am retired now and miss the work and I am constantly cleaning all my tools and I could do it then. Here is my e-mail address jedriscoll@rcn.com
Good luck, Jack
Aug 18, 2009 | Mitutoyo 293 340: Test & Measurement...
Micrometers out of calibration
Micrometers must be calibrated at 4 spots around the barrel and at zero and full scale to be truly accurate. You will have to send it to a calibration lab or back to Starrett for a full calibration because they will check it with gauge blocks of known length and verify the spindle and anvil surface flatness.
If you are only concerned with the zero and not as much about the full accuracy of the tool, then you can reset the zero yourself. With the mic fully closed (spindle and anvil touching), turn the barrel with the funky, half circle shaped wrench that came with the mic in the box. There is a little hole in the barrel where the nub on the wrench will fit then you just turn it until it reads zero. Good luck.
Mar 07, 2009 | Starrett T216XRL-1 - MICROMETER, DIGITAL
Thimble on 0"-1" micrometer is tight.
spray some silicone into the thread areaand open and close it a few times.
Mar 04, 2009 | Mitutoyo 0 1".001 Fric/Thimble Mti Outside...
Measuring Tools & Sensors Logo
852 people viewed this question
Top Mitutoyo Measuring Tools & Sensors Experts
Doug Adams
Doug Adams
Glenn
Glenn
Are you a Mitutoyo Measuring Tool and Sensor Expert? Answer questions, earn points and help others
