What's a "tab".. round.. oval..??
Yellow Pill Identification Wizard Drugs com
BACKGROUND - When you turn on the machine, close the top cover, or press [Code]+[Reset} (on some models) the print head
moves to the side, the daisywheel spins, and the ribbon jumps up and down, that
is the machine resetting its self.
If a reset does not work
the reset tab may be out of alignment. If a reset does not correctly reset the
daisywheel, I would
CAUSES - This reset tab most often gets out of alignment by a child playing with the machine, or when a foreign object is in the machine when the print head is moving.
To answer your question yes the print wheel can be changed, BUT that is not your problem. The machine needs to be reset or the reset tab needs adjusting.
Background;
When you turn on the machine the print head moves to the right side, the print wheel spins, and the ribbon jumps up and down, that is the machine resetting its self.
I would
