Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire Washer GLTR1670AS0: broken shocks + chipped rear shell
I have a Frigidaire Tumble Action Washer model GLTR1670AS0 which is 6 years old and I love this washer. A couple days ago, while it was running I heard a loud cyclic, throbbing sound which occurred during the spin cycle. The drum seemed much looser than usual, as if it wasn't properly attached. I opened the back and found one of two shock absorbers was broken, and a piece of the solid body rear shell that encloses the tumbler was chipped off, leaving an opening near the top with about a 1 inch diameter.
I am going to replace the broken shocks. It's in my financial best interest to spend as little as possible, so I was thinking about gluing the chipped shell piece back on. What type of glue should I use? Perhaps some strong superglue? I cannot tell what material the shell is made of. Does this seem sensible?
    President:
  • 704 Answers
Check the diagram for the part you described as missing a chunk, it might be possible to get it as a replacement part for not much money. I would caution against trying to use any type of "super glue" since it doesn't have the durability to withstand the repeated shock and vibration that this part will experience. If the broken part is item #22 (shell/rear bearing) then the cost for the part is $170.00 - check the diagram to verify what your broken part looks like at the following link:
(copy and paste the entire string, as the hyperlink doesn't always load on the fixya site)
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=GLTR1670AS0&productCategoryId=0153200&brandId=1428&modelName=WASHER&diagramPageId=00003&componentDescription=WSHR TUB,MOTOR&documentId=R0111530&backToLink=Return to Sub Components list
IF I was going to attempt to repair (glue) the part, I'd use something like JB Weld for plastics as it would likley provide better results and I'd try to keep the inside as free as possible of any excess so as not to snap clothes, etc. Good luck to you and hope I've helped.
Posted on Jul 28, 2009
Where is the motor coupler located on a Frigidaire washer front loader model no. gitr 1670 aso? year 2003.
Hello friend, thank you for your post!
I understand that you are searching for the location of the motor coupler on your Frigidaire washer, GLTR1670AS0. I was able to locate the parts manual and it does not show a part labeled motor coupler. I have attached the link for you to access the parts manual for further assistance. I hope this is helpful. -Matt
Frigidaire Manual Search Results
Oct 08, 2014 | Frigidaire Washing Machines
I have a 7 year old Frigidaire washer (Model #GLWS1349AS1) and the water drains really slow and the spin starts before all the water is drained and then the washer leaks as water is still in it during spin...
you have a restriction in the drain somewhere or there is something inside the pump housing,chk every line from the tub to pump to drain pipe and hoses for blocks or kinks
Apr 09, 2010 | Frigidaire FTF2140ES King Size Front-Load...
Frigidaire tumble action washer will not agitate or spin. Drain water fine. One of the shock absorbers is broken. would this be the problem? The belt is fine.
Yes there are several balance switches in the unit and if the shock is broken at least one switch has been activated. If you were to some how bypass the switch the unit would be very dangerous to even be near during the spin cycle as it would try to walk, tumble or jump across the room! The switch is a safety feature for all concerned.
Please get your machine repaired.
Thanks for using FixYa!
Kelly
Mar 10, 2010 | Frigidaire 14 Cycle Tumble Action Washer
Frigidaire Tumble Action Washer buzzing door lock
you might have a damaged door lock mechanism.it might be jammed in the closed position,and should be changed
Feb 06, 2010 | Frigidaire 14 Cycle Tumble Action Washer
Frigidaire front loader makes banging noises in spin cycle
hi there.......if this problem has just recently appeared...its quite possible that 1 of the tub suspension springs has broken resulting in the tub lying at an angle and causing this unbalance....you can check this by tilting the machine and looking at the tub susension points
regards Sir Galahad
Aug 16, 2009 | Frigidaire 14 Cycle Tumble Action Washer
I called in an electrician/plumber - thanks !
Jul 01, 2008 | Frigidaire 14 Cycle Tumble Action Washer
Load noise in final spin cycle
turn the tub on the inside if it feels ruff as it turns and makes a noise then most likely you have a bad rear bearing, if it is smooth in turning and no noise then turn to drain or spin possibly something stuck in drain pump. the drain pump will start up first if you hear the noise then the drain pump is accessed from the front lower cover, if its the rear bearing probably not worth fixing about 400.00 in parts and alot of work.
Feb 14, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Shocks broke, now drums spins freely
What you need to check thoroughly are the belt & the 2 shocks (dampers). The dampers should be replaced & fitted tightly, broader ends fitted below.
Oct 16, 2007 | Frigidaire GLTF530DS Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
533 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
