Question about Philips 42PF7320A 42 in. Plasma HDTV
I have a 42"PLASMA PHILIPS. It has a red flsahing light. will not turn on. I unplugged and it worked for 1 day & did same thing again.
    Sergeant:
    Champion:
  • 227 Answers
Check the power supply for bad capacitors if they are ok then replace the power supply boarrd.
good luck
Posted on Jul 29, 2009
Philips flat screen 42" flashing red light 7 times it stops for 5 seconds and 7 more flashes if i unplug and plug it a few time it will come on
my 42 inch phillips, i turn it on green light comes on for 10 sec then red light comes on and flashes 4 times then stops for 5 sec then repeats.
Apr 20, 2010 | Philips 42PF9631D 42 in. Plasma Television
Blinking red light and tv will not turn on.
problem on power supply , u may have 2 bAD capacitor
Apr 14, 2010 | Philips 42PF9631D 42 in. Plasma Television
My plasma philips tv dosent turn on and red light blinks 6 times
Power supply board have dead capacitors.U know how to solder?Replaced these capacitors that bulge up,puff up or burst open.Should get ur power back.Or replaced a whole power refurbish power supply buy it at Shopjimmy.com,Ebay.com.
Feb 06, 2010 | Philips 42PF9631D 42 in. Plasma Television
Flashing red power light
probably some capacitors need to be replaced. i just replaced to in mine today and the tv works great.
Jan 25, 2010 | Philips 42PF9631D 42 in. Plasma Television
42"doesn't turn on
your power supply board is going out.
Dec 06, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Red light blinking
You have a bad main board most likely. You can try unpluging it for 5 minutes.
Sep 03, 2009 | Philips 42PF9631D 42 in. Plasma Television
Philips 42 inch HDTV - "FlatTV" Plasma -- does not turn on.
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Jun 20, 2009 | Philips 42PF9631D 42 in. Plasma Television
7 red flashing lights, won't power up..
Check the power board for capacitors with the tops bulged up. They are 3300uf 10v. There are either 2 or 4 of them depending on your set.
Jun 01, 2009 | Philips 42PF9631D 42 in. Plasma Television
Phillips Plasma 42" TV
It is most likely a power supply failure and if there had been no signs of problems in the video display, it is probably the main power supply rather than one dedicated to the plasma display itself.
You might leave it unplugged overnight to give any stored charge inside the unit a chance to bleed off, the remove the back panel.
The primary supply is normally on a separate board and is characterized by having mostly larger components, including one or more transformers with black ferrite cores. The main supply will be associated closer to the AC input while the high voltage supply which may or may not be separate is not.
If you can locate the board with some confidence, check it visually for any signs of heat such as discoloration of board or components. If it seems OK it may be a candidate for exchange or repair by Philips.
I wouldn't advise removing and sending it before you talk to Philips to see if this is a familiar problem to them.
Dec 16, 2008 | Philips 42PFL5603D 42 in. LCD HDTV
Philips 42PF7320A 42 in. Plasma HDTV Logo
292 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
