Question about Logitech Harmony 890 LCD Remote Control
Battery went dead
My battery went dead after i purchased a new surge protector and found out the protector was defective. the remote charger was plugged into one of the outlets on the protector not working. now the charger has been plugged in for 6 hours and the remote still is not working. the remote face shows it is charging, but i cannot get it do respond. thank you Brian
If you live in the US, you can buy a new battery by calling 1-800-231-7717.
If you live elsewhere let me know and I will tell you how to get replacement parts for your Harmony remote.
Posted on Mar 05, 2010
I turned off my seike tv model number se321fb and now it wont turn back on? the surge protector has power how do i get it to come back on?
Even though the indicator light on your surge protector is on, the surge protector outlets may not be working. Test it by plugging in a different electronic to make sure it still works.
It could also be a problem with your remote, such as dead batteries or that the remote is no longer programmed with the correct codes.
Here are a couple of troubleshooting checklists that can help you identify the problem and what you can do to solve it:
Remote not working
No picture on TV
I hope this helps!
Aug 03, 2012 | RCA Televison & Video
Wii went dead after power surge
Please visit the site HERE it.You will find a solution to your problem.
I would also suggest holding the power button on the Wii Remote itself to turn it on, or unplug your Wii Console's power cable and audio/video cable for 90 seconds. Then plug power in first, then AV cable.
Goolduck..
Feb 23, 2008 | Nintendo Wii Console
Wont turn on
1.Plug the Inspiron's AC power cord into a power outlet and try to power on the laptop again. By far the most common cause of a laptop's not powering on is a dead battery.
2.Plug the AC adapter into a different outlet to check for a "dead" outlet. If you have the cable plugged into a surge protector, plug the cord into a different slot on the surge protector or "bypass" the surge protector by plugging the cable into an electrical outlet. If the Inspiron now powers on, replace the surge protector or have an electrician examine any "dead" outlets in the home.
3.Open the battery bay on the underside of the Inspiron by sliding the battery bay latch release lock upward and the battery bay latch release to the right. Once both latches are released, the battery bay should open.
4.Remove the battery.
5.Purchase a compatible replacement battery for laptop. Be aware that using an incompatible battery can cause damage to your computer. If you have any doubt as to compatibility, the best option is to purchase the replacement battery directly from your laptop's manufacturer.
6.Install the new battery by following the battery-removal procedure in reverse order. Once the new battery is installed, try again to power on the laptop. If there is still no power, seek professional repair advice.
I hope you find it very helpful.
Aug 25, 2011 | Gateway Computers & Internet
My laptop shut off and will not come back on, any ideas? its a new battery, just 2 weeks old.
remove the battery and plug in the AC adapter only directly to a working wall outlet. If it still does not turn on, you likely have a failed system board. take it to a local repair place or call Dell for service.
Feb 17, 2010 | Dell Inspiron 1501 Notebook
When I push the on button on my Gateway M-6843 laptop, all that happens is the battery LED on the front flashes 4 times an stops. The power LED does not go on. I purchased a new AC power cord adapter but...
We need to know what is defective and what is not.
  1. Remove the battery from the laptop.
  2. Plug the power cord to the laptop and plug it to the wall power outlet.
  3. Now, without the battery, turn your laptop ON.
  4. If it powers ON without the battery, then your battery is completely dead and needs replacement. If the problem is still the same, then it should be a motherboard problem considering that you have already confirmed that your power cords are working.
Try your luck. Post feedback if you need further instructions. The point is, you need to know if the battery is dead by removing it first then connecting your laptop directly to the wall power outlet. You can connect it to a Surge Protector or Automatic Voltage Regulator for safety purposes if you want.
Feb 11, 2010 | Gateway M-6843 Notebook
How do I reset s9....the green light stays on constantly and I cannot connect at all.
If you guys haven't found a solution, you might want to try this out. Have your S9 charger hooked up to the unit and plug the charger into a surge protector. Flick the main switch of the surge protector on and off a few times and it should turn off the unit. Then turn on and pair if need to and it should be fine. Hope that works for ya!
Cpl. Ramos
Jun 24, 2009 | Motorola Mobility S9 Headphones
Cannot get power to our canon mp830
plug in a light into surge protector and see if it works if not surge protector is bad or battery is shot if it has one!!i have numerous surge protectors that went bad try plugging printer into wall outlet and if working its surge protector!!!
Jun 22, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Problem with power cord/AC adaptor...maybe?
I would just go buy another battery charger pack. They are like 75 dollars to buy. Sounds like yours might have a short in it!
Mar 26, 2009 | HP Compaq nx6110 Notebook
The battery plug in area is dead but the surge protector side works
Hello Vicki,
What you are describing is usually a result of the batteries losing their ability to hold a charge.
The surge protector side does not rely on the batteries.
I found good batteries at a reasonable cost on ebay, but I think you're going to need to replace batteries at this point.
Hope this helps.
Charlie
Nov 18, 2007 | Cybernet Systems CyberPower 625AVR...
Logitech Harmony 890 LCD Remote Control Logo
61 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
ka4iup
ka4iup
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
