Question about Sony Playstation 3 (PS3) Console
Turn on and immediately turns off
Turns on and immediately turns off - before it turns off it goes yellow, then beeps red, then continues until the on button is pressed again
cant get the disc out
Sorry, but i guess you have got the famous ''yellow light of death'' =/
this case, you should contact Sony as soon as you can for warranty procedures, because this yellow light means a very serious problem with your hardware, such as :
  • Hard Disk
  • Cooling system .
Posted on Jul 28, 2009
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
Dec 08, 2011 | APC Smart-UPS SC 1500VA UPS System
I dropped my ps3 it works but when i turn it on the green light apperas then in two seconds i8t makes the reset noise then turns yellow then red. The red light then continues to flash. What do I do now
Hello
With the PS3 in Standby mode (Red light on), press and hold the Start button until you hear a single beep, followed by double beeps.
Connect the controller using USB cable and press the PS button on the controller.
Now, the system restore screen will come up
You have several options here for restoring the system, some will unfortunately wipe up all your data, others will make you lose the file naming.
Good luck
Jan 17, 2011 | Sony Playstation 3 (PS3) Console
Light rolling from green to red
stephen I think you are in sleep or lock out mode. Try turning the power on and pressing the horn button twice see if it stops scrolling if it doesn't turn the power off then turn it on and immediately push the joystick forward until you hear a beep then immediately opush it to the rear until you hear another beep then release it to the center. If it is in lockout you should see it return to normal lights Hope this helps
Nov 14, 2010 | Pride Jazzy 1103 Ultra Standard Power...
When I switch it on it goes immediately on standby mode (with the red light flashing) and cannot make it to work
The best solution on earth!!!
the same thing happened to me. all you do is press the eject button until it turns yellow. when that happens, immediately unplug the ac cord, & plug it back in. repeat this process until the light stays green! trust me, it works. it saves alot of money too if your warranty has ran out
Sep 16, 2010 | Sony Playstation 3 (PS3) Console
My playstation will turn on, then turn off 10 seconds after i turn it on, then the red light flashes, i thought it was overheating, so i left it sitting for a while with no cords plugged in it. what is the...
Hi, you may try the recovery options: The PS3 stores a copy of firmware drivers on the hard-drive and will reload any corrupt files. To access the recovery menu, do this: Make sure the PS3 is turned off Press and hold the power button on the PS3 it will power on then power off. When it's off press and hold the power button again until you hear two consecutive beeps. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try) It will ask for the controller to be connected via the USB cable, Turn on the controller and you will have access to the menu. Be aware that you might lose all of your previously saved data.
This should work only if you didn't see a yellow led light, before the red blinking. If the recovery doesn't work and/or if you've seen the yellow light then you have to call sony technical support. Regards, Peter
Aug 05, 2010 | Sony Playstation 3 (PS3) Console
When you turn the unit on it goes to a green light then beeps twice and goes to a flashing red light?
This is an overheating problem.
Let it sit for about a day and then try it out.
Make sure it has ATLEAST 4 inches of open space all around it and is not near any heat-making devices, it makes enough heat on its own.
Also make sure it's not on carpet.
If it ever starts to immediately shut-off, blink green yellow and then repeating red with 3 beeps, you have the Yellow Light of Death.
This is a console killer.
Repost as a different question if it turns into the YLOD.
Feb 20, 2010 | Sony Playstation 3 (PS3) Console
Runs for 20 seconds then standy again
I'm guessing that there is a blinking red light in there somewhere...
If so, it's a overheating problem. Let your PS3 sit for a day and get it away from everything that makes heat, carpet, and atleast 4 inches away from everything in general.
if it escalates to immediately turning off and blinking yellow and then red with 3 beeps, you havbe the Yellow Light of Death. This is a console killer but can be fixed by professionals.
If that happens then remake the question on here saying you have the YLoD.
Feb 13, 2010 | Sony Playstation 3 (PS3) Console
Wont turn on
your ps3 is done. this is known as the yellow light of death.
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
From standby PS3 wont turn on.
that sounds like your main power supply unit
May 28, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
199 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
